Question about Polaroid FLM-3232 Television
Polaroid lcd hdtv 27" buzzzz
My tv is less than a year old and it started buzzing from the back. I changed inputs and turned the volume off and that did not efect the buzzing
  • 2 more comments
  • Anonymous Jan 24, 2008
    I have the same problem...Polaroid sent me new box for the back but it's still happening.
  • ksj2967 Aug 13, 2008
    my sound to my tv quite working there is a picture but no sound
  • Anonymous May 21, 2009
    Model tdx-02610b -
    TV would boot - show splash screen and input for a couple of seconds then go black. Disconnected the cable DVD Drive and unit started functioning normaly again.
  • Anonymous Mar 12, 2014
    Samsung LE40B530P7WXXU lcd tv
    Sergeant:
    Champion:
  • 362 Answers
Thre are several components that can make a buzzing sound, especially a bad power component or capacitor. check the capacitors to make sure they are installed in the board correctly. the stripe on the cap must line up with the white mark on the board under it. remove the back panel lay the tv down on a blanket turn it on and see if you can isolate the noise component by ear up close. and visually check for swollen capacitors the top will be pushed up round if bad if good it will be flat on top. warning if tv is less than a year old make the place you bought it replace it. so you dont void the warranty.
Posted on Feb 25, 2008
Today I bought SONY KDL37EX402 LCD TV. Immediately when I turned it for the first time I noticed an unpleasant sound like a “buzzzzzz” from the back of the TV. As I worked it for more then 5 hours I...
It can be from the power supply is not able the supply enough power due to failing components in the power supply module such as DC filter caps or loose transformer core is vibrating or from the backlight inverter transformers. You will have to take a close listen to find out exactly where the noise is generated from first.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Oct 23, 2010 | Sony BRAVIA KLV-37S310A LCD TV
Take it back and see if another does the same thing before you get out of the store. There's something loose in the backlight circuit, like a power inductor. They shouldn't do that.
Apr 08, 2017 | Sony Televison & Video
Today I bought SONY KDL37EX402 LCD TV. Immediately when I turned it for the first time I noticed an unpleasant sound like a ?buzzzzzz? from the back of the TV. As I worked it for more then 5 hours I...
I'm pretty sure that the buzzing sound is a not normal thing for an LCD TV. I sell Flat Panels during my spare time and it should be as quiet as a CRT types. It is more likely a defect and you should return it ASAP.
Hope this helps.
Oct 23, 2010 | Televison & Video
Buzzing TV- Polaroid 37" FLM-3732
i fixed one by put 2 new caps in c112 and c113 1000uf 10v
Jun 13, 2009 | Polaroid FLM-3732 Television
Buzzing sound coming from TV Speakers and any external speakers
change your pre-amp ic sure it will work. or maybe cold solder from the board.
May 05, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
We have a polaroid flat panel tv and have a surround sound hooked up to it. so the sound is completely turned off of the tv itself. there is a buzzing sound coming from the tv sound panel. it is not all of...
It sounds like feed back issues or maybe your rca plugs are plugged into wrong inputs it should be connected to audio output on tv and ensure the same color plug in connected to both the ins and outs on tv and audio receiver.
Apr 04, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Tv screen has turned blue and I can't watch tv
i think by accident you have changed the input when you went to change the volume. look for a button labeled " input" or "video" select on the remote and scroll through the various choices. you should get your picture back.
Jan 21, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Clicking and buzzing when turned on takes 30min to 1 hr to come on
The fix to the black screen problem which is posted on Fixya has a pretty good chance to fix this too.If you have a soldering iron it costs less than $10 and will eventually have to be done anyway.The site has very good instructions,just follow them carefully.
Aug 27, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Buzz from back of the tv
It is likely that one of the transfomers is buzzing due to heat and laminations or wire is ringing.
It should not cause any issue except annoy you. it must be replaced. or glued back down which is usually very difficult as they are wrapped and/or sealed.
Only way to find out is to open the unit and trace it down.
If it is dust buildup then you should be hearing a crackling. zzzztt sound.
Jan 15, 2008 | Polaroid FLM-2632 Television
Polaroid FLM-3232 Television Logo
750 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
