Question about NEC LT 260K Multimedia Projector
No video I can see the lamp is on, but there are only vertical bars being displayed.
  • steve260 Sep 04, 2008
    when the projector is on, there only vertical bars displayin.plus my projecter need a security code to open it
    Problem Solver:
  • 10 Answers
I had the same problem. I opened the projector and there was a connector that had come loose. It was a long multi-pin connector in the centre of the projector.
I hope that helps someone.
Feo
Posted on Jun 21, 2009
    Problem Solver:
Open your projector cover. Search for orange-chrome wire connecting between your lens card( i guess ) and above main board.Maybe this wire doesnt connect properly
Posted on Sep 06, 2008
Vertical black bars screen
Try connecting an external monitor to the 15 VGA (video) plug on the laptop and see if it displays properly on the monitor. You may have to direct the video from the laptop to the monitor by holding down the blue <FN> (key next to the space bar) and then press down the <F8> key.
If the display on the external monitor is correct, then you either have a problem with the laptop's LED display screen or cable that connects the LED to system board. Here is a link for the service manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-9300_service%20manual_en-us.pdf
Feb 16, 2013 | Dell Inspiron 9100 Notebook
We have a Sony WEGA KDF-55WF655 that has suddenly developed a problem. When you power on, the power light flashes for about a minute with no display, then the display shows very thin vertical color bars....
I have seen and repaired this a few times. It's not a lamp... your need a Q box! PN: A-1058-689-A. This is not an easy repair. Changing this part by yourself could put you in tears. You should call a serviceman and request a quote. An experienced serviceman should be able to replace this part in 30-45 minutes. I hope this helps.
Mar 16, 2010 | Televison & Video
2 vertical bars on tv screen
OPEN THE TV AND BLOW IT OUT ..THOSE BARS ARE THE EFFECT OF DUST INSIDE THE UNIT CLEAN OUT AS WELL AS YOU CAN AND THAT SHOULD FIX
YOUR PROBLEM
Feb 06, 2018 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Color bars only on KWorld PC to TV - Composite and SVideo
found this reference it may be of help
This product appears to be defective. I connected it to a working video camera that produces an excellent picture on a standard monitor. I looped the video from the camera through the monitor to the converter which is connected to a new ACER LCD display. The LCD display workes perfectly when connected to my computer. Using the converter, the results are poor. You can see the desired picture in the background but in the foreground there are horizontal bars that scroll vertically through the picture. I'm returning it for an exchange - will try again.
Jul 26, 2009 | KWorld PC to TV (0872880887527) Video...
Vertical bar about 3/4" from top to bottom of monitor
panel is done. economical to repair. new panel is about 90 percent the cost of the tv new
Jun 03, 2009 | Fujitsu Plasmavision PDS-4233 42 in....
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Dark Grey Vertical Bar
1. try connecting laptop to an external monitor and check if this vertical dark gray bar appears. if yes it means video is the problem. you need to boot in safe mode then uninstall the video driver. boot to notmal mode then download and install the latest video driver. if still same problem then replace video card. if video is built in with motherboard you need to replace motherboard.
2. when the vertical dark gray bar did not appear in the external monitor then it means issue is with the LCD panel. Do this turn off laptop. press and hold D key then press Power button at the same time or Press and hold on the Fn key then Power button check if the test will run. Color displays full screen when you keep pressing on N key when the colors appears check the vertical dark gray bar if still exist in the test, this means LCD panel and LCD cable needs to be replaced.
Oct 31, 2008 | Computers & Internet
Green translucient vertical bar on left side of screen
Cover green CRT lens with towel and see if red/blue video is normal......= bad CRT ?.............................T.
May 09, 2008 | Toshiba 57H82 57" Rear Projection...
NEC LT 260K Multimedia Projector Logo
130 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
