Question about Xerox Phaser 8550DP Printer
Smearing papers Hi. I've had my Phaser for a little over a year. Shortly after the warranty expired I started experiencing problems with the paper smearing-printing double or triple exposure- nearly all the time. It has been completely cleaned, all the diagnostics run, a new 10,000 page drum- nothing has fixed the problem. Xerox wants more to fix it than it costs to buy a new one. It never had a single problem in the first year. Please help if you can. I've invested a lot in this printer. Many thanks- Harvest
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 74 Answers
Try telling them that it has not even been a year yet and you are having these problems, since it is just over a year. Let them know of the fixings you've done and threaten to make a BBB complaint against the organization if they do not accommodate repairs for your printer. This is corporate bull crap. They set it up for this to happen and hope that you'll just buy the new printer. Stick with your guns and make them repair it. Let me know what happens.
Cynthia Charczenko
Posted on Jan 15, 2008
Xerox 4620 is printing smears all over the page. I replaced the drum but it is still happening. Not sure what could cause this prblem
ask yourself this . Is the paper warm or hot when it has been printed on ?
check fuser unit .
No heat equals unbonded toner on paper equals smearing of toner on paper.
Oct 20, 2015 | Xerox Laser Printers 4620/DN Phaser 4620DN...
How to clean phaser 7750
Included general maintenance video and how to clear smears from the paper.
Solution: Remove Print Smears / Printing Fuser Cleaning Pages
7750 Support Knowledge Base Remove Print Smears Fuser Cleaning...
With Troublshooting highlighted on the printer display perform the following steps:
  1. Press OK.
  2. Press the Down Arrow and scroll to Print Quality Problems.
  3. Press OK.
  4. Press the Down Arrow and scroll to Remove Print Smears.
  5. Press OK. The printer will print 5 cleaning pages.
Repeat this process five or six times, to remove stubborn toner buildup from the fuser.
Always make sure you are matching the type of paper loaded in the printer tray(s) to the correct Paper Type front panel setting. When you load a tray with paper, the front panel will ask you to indicate the type of paper you loaded. For correct print quality and printer operation, be sure to set this correctly.
Phaser 7750 Video Instruction Maintenance for the Printer Phaser
Apr 23, 2014 | Xerox Phaser 8550/SDP Color Laser Printer
My Xerox Phaser 6125 smears black (!) toner, extra obvious and totalley unacceptable on double sided printed sheets. Different types of paper all show the same problem.
This would normally be the cleaning unit to blame. If in doubt go,to the website and investigate further.
Good luck.
Sep 24, 2013 | Xerox Phaser 6125 Laser Printer
8400 Phaser has paper jams which leave junk on the drum.
hi david i hope i can help you? you may need to give the machine a good clean, if there is any rubber wheeles? give them a clean with meths. little rollers check to see if any carbon brown in colour. its caused by constant use. i hope this has helped you? top tip you must make sure all the brown is completly away. to make your machine run better.
May 04, 2009 | Xerox Phaser 8400 Laser Printer
Phaser 8200 Smears on Linen Paper
Your maintenance kit is running low on oil and needs to be replaced. Since the image drum is not getting enough lubrication, some of the ink from the previous page is sticking to the drum and carried over onto the next page. Also, try to match the printer paper type to the paper you are using. It will adjust speed, temperature, etc. to optimize print.
Mar 24, 2009 | Xerox Phaser 8200 Laser Printer
Repeated paper jams
These errors are usually caused by a cracked DM Camshaft (Drum Maintenance). This was a very common problem for Xerox, they usually broke while under warranty, but there a heck of a lot out there that are just now going bad after a year.
You may or may not need to replace the "Motor Process Drive Gears" as well as the DM camshaft.
You might be able to talk Xerox into doing this as a warranty repair, if you ***** real loud.
Mar 12, 2009 | Xerox Phaser 8550DX Laser Printer
Pinstripes in image after print (phaser 8560)
Appropriate cleaning procedures, as listed in the following tables, should be
performed when specific print-quality or paper transport problems occur.
All cleaning procedures are detailed in the printer’s Phaser 8400 Reference Guide or
the Phaser 8500/8550 User’s Guide.
Light Stripes or Missing Colors
Problem type Solution
Missing or light-colored
stripes on prints.
Select the automated procedure Eliminate Light Stripes from
the Control Panel.
Ink Smears, Oil Spots, or Random Ink Streaks
Ink smears on the front,
back, or edges of a page.
Select the automated procedure Remove Print Smears from
the Control Panel.
Check the maintenance kit for ink and paper-dust build-up on
the wiper blade.
Oil (drum fluid) on top edge
of print.
the Control Panel.
Hope this helps
Nov 24, 2008 | Xerox Phaser 8560DN Laser Printer
Xerox phaser 7700 having problems printing transparencies and accumulator belt problems
Hi xander4265:
Streaks in direction of paper travel
There are dark lines running along
the page in the direction of paper
travel from the leading edge to the
trailing edge (B-size print shown).
The printer displays no error code.
Note A-size prints are processed
through the printer with the short
edge of the print parallel to the
direction of the paper path --
making horizontal print artifacts
parallel to the shot edge of the
B-size prints are processed
through the printer with the long
paper path -- making horizontal
artifacts parallel to the long axis
of the print.
1. Check the end of life for each of
the consumables by printing the
supplies usage page. From the front panel’s Printable Pages Menu, select
Print Supplies Page.
2. Run the solid fill test pages; From the front panel’s Printable Pages Menu,
select Service Pages, then select Print Solid Fill Pages. If the missing bands
only occur in a single primary color, replace the print cartridge of the affected
3. Swap print cartridges and run another test print.
Note Under some circumstances, streaking may occur in the margin of
SRA3-size paper. This is due to the edges of the paper extending
beyond the end of the imaging components. print-quality in the
margins of SRA3 paper is not guaranteed.
4. Inspect the Accumulator Belt cleaner; replace the cleaner, if necessary.
5. Run the Remove Print Smears routine. From the front panel’s Support Menu,
select Improve Print-Quality?, then select Remove Print Smears.
6. Replace the Developer Housing Assembly (RRP 27, on page 7-171).
7. Remove the print cartridge and (with a flashlight) check for debris along the
edge of the developer housing.
Leading Edge
hope that this will help you.
Sep 18, 2008 | Xerox Phaser 7700 Laser Printer
Phaser 7300n Printing on Double Sided Glossy Paper
At first I didn't think the paper was the problem, but I looked up the specs on it and is seems to be a paper designed for an offset press.
I suspect after reading the information on the paper that the coating is not designed for the high temperatures of a laser printiers fuser heat of over 350 degrees.
I do suspect the paper is the issue.
sounds like you are melting the coating.
Dec 30, 2007 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 8550DP Printer Logo
50 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
