Question about GE Spacemaker JVM1640SJ Microwave Oven
Fan started running and will not stop when off button is pushed
  • Anonymous Dec 16, 2008
    the fan will not shut off unles I shut it off at the breaker
  • ballard_bike Jan 04, 2009
    Wife used some cleaner and it appears the cleaner affected the fan- it won't shut off...
    Master:
  • 619 Answers
Hi , the door lock switch are stuck./ the contact switch are not stick together need to replace new.
Posted on Jan 18, 2008
The microwave keeps stopping
If you are actually selecting heating time rather than pushing the "quick heat" button, the control board may be defective.
Aug 22, 2016 | Microwave Ovens
Just start 15 minutes and then stop
Pull the cover if necessary to see if the fan is spinning. If it's running 15 seconds, your door switches are probably ok, and the touchpad is working, main fuse ok. All that leaves is the circuit board and the magnetron.
Personally, I prefer microwaves with twist timers, not touch pads. A lot less to go wrong.
Nov 22, 2013 | Panasonic NN-S969 Microwave Oven
Work light and fan stopped working
sounds as if your touch pad ,and,or the circut boaed it's connected to is going bad.
Nov 08, 2013 | Kenmore Microwave Ovens
Microwave jes1142
If the timer counts down and nothing else happens, the secondary interlock switch is bad. This switch completes the cook circuit and this is why it doesn't run. You need an ohm meter to diagnose and find the right switch. Switch failure is caused by opening the door when it is in cook mode. Push the stop button first before opening the door and this failure will cease to occur. BE CAREFUL !!
Oct 09, 2013 | GE JES1142SJ Microwave Oven
Vent blower won't stop
I had the same problem with the fan not wanting to shut off after the repair. Once I set the clock though I was able to push the button to shut the fan off. So try setting your clock first and see if that helps.
May 07, 2013 | GE Profile Spacemaker Over-the-Range...
Cooling fan hums and turns slow.
You will need to replace the cooling fan motor. Remove it and check the numbers on the fan and then do an online search for the motor. you can also contact a website called the repairclinic.
Oct 20, 2017 | Whirlpool MH1170XS Microwave Oven
Fan stopped running while heating something up
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
uyiu4
Mar 17, 2009 | Amana ACO1860 Microwave Oven
GE XL 1800 touchpad motor sound
that sound comes from fan motor, please replace or service fan motor ..
Sep 25, 2007 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
152 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
