Question about ViewSonic G810 21" CRT Monitor
I bought this one used and it pops out of a great color picture into a yellow tint. Is this fixable or do I need a new monitor?
  • 56 Answers
If that is a new and have a waranty why did back to the store and need for the replacement if the monitor has a warranty ...so just bring that and need for replacement...
Posted on Jan 28, 2008
How can I fix a synmaster b1630 monitor that has green tint on screen now?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 27, 2014 | Samsung SyncMaster Computers & Internet
Tip
I have the overall yellow tint in my lcd monitor there are no magnets close to...
The discoloration problem is due to the near by magnetic field appliances like speakers which are very near to monitors ...
so what you have to do is just keep some distance to the monitor from the speakers and other magnetic appliances and then press menu button & just give degauss..
on Mar 16, 2008 | Sony SDM-HS73P 17" LCD Monitor
Not able to get red tones on TV
the problem is at the crt base .there r three red,blue n green o/put.verify if there is dry in the soldering n check the red cathode voltage it must b around 150 .if not then check the resistor that feeds the red o/put.it could b 12 to 15k. all crt have 3 driver color red blue n green,whenever one driver not working the color changes.that wat happened to ur tv now i do not know wat model u have.the drivers may b transistors or now its ic that r being used like tda 6103q.best of luck
Jan 03, 2010 | Toshiba 27AF45 27" TV
Viewsonic VP930b color problem - Red tint
Go to the setup menu on the LCD panel by pressing button 1 on the front. See if there is an option to reset the lcd to factory settings. Reset it and report if it helps not.
Jul 29, 2009 | ViewSonic VP930b 19" LCD Monitor
My aopen f2925 monitor has a green tint.
The solution: hidden menu within the main menu itself. Hold the Menu button down while pressing Power to power on, and release power button only when the screen comes up, still holding the menu button. The menu will appear and there will now be a hidden selection, "Auto Color", printed in a red-on-black font at the bottom of the menu. Use the +/- buttons to access it, and press Menu. My green/yellow tint went away! Now my picture works great, and the setting lasts through Auto-Adjusts and Resets!
Apr 08, 2009 | AOpen F70PS 17" Flat Panel LCD Monitor
My viewsonic monitor is not working
Considering the price of monitors versus the cost of repair. It would cost less to replace the monitor.
Mar 12, 2009 | MPC Computers Viewsonic E771 17 in.CRT...
Color
on your monitor press menu button and select degasaus.please rate solution.
May 31, 2008 | ViewSonic 17" CRT Monitor
ViewSonic VE710b 17 inch yellowed photograph look
Check and make sure that there is no speaker, power supply or UPS around your monitor.
Mar 16, 2008 | ViewSonic VE710b 17" Flat Panel LCD...
White colour is displaying as yellow
Your monitor is missing blue drive. Most likely a component failure on the CRT board. Bad color ICs, bad solder connections or defective capacitors can cause the problem.
Aug 25, 2006 | ViewSonic E50C 15" CRT Monitor
ViewSonic G810 21" CRT Monitor Logo
77 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
