Question about KitchenAid KGRA806PSS Gas Kitchen Range
Kitchenaid Superba Gas Range
I've recently noticed that when I use the oven on my Kitchenaid Superba Gas Range, it's taking longer each time to preheat. Has anyone else experienced this? What can cause this problem?
  • 3 more comments
  • Anonymous Oct 09, 2008
    My Kitchenaid Superba convection gas oven has the same problem. It used to preheat in 9 minutes (the instruction manual says it should take 10) but now it takes 20 to 30 minutes.
  • newkgar Jan 23, 2009
    Our range is just 2 years old and will not preheat. Very disappointed, there are only 2 of us and the oven is used a maximum of 3 days a week.
    Before calling Service Man I was interested if others had similar problems.
    Thank you,
    Kathy
  • mirrub Jan 30, 2009
    I have the same problem. It now takes 1/2 to 1 hr to preheat. This is ridiculous. Repair man want $60 just to look at it and $10 for every 10 min. Could it be the controller?
  • Anonymous Mar 22, 2014
    Alarm where time is saying Fe25
  • Anonymous Mar 30, 2014
    kitchenaid superba model ykerc507ht4 electronic control pad not working
It appeared to be something to do with the plenum and cleaning - repair man came - cleansed and it was okay. MK
Posted on Aug 31, 2008
  • sylvainpaque
    sylvainpaque Dec 21, 2012
    wath did you mean by plenum and cleaning my oven have the problem the broil is working but at bake it just stay at lo
Oven preheat times
It gas not electric. There is NO hidden element. It a bad sensor.
Mar 08, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have a KitchenAid Superba KEMC308KSS0 that is about 9 years old. In the past few months it has been cooking really slowly. Whereas in the past, in convection mode, things cooked faster than...
I have a Superba built-in YKEBS 177 D56 ( dual convection/convention)...I think it might be about 10 years old. I noticed the same thing starting last year..the temperature seems a litlle off and the cook time on the convention seems to take longer. I've never used the conventional oven so I don't know if the temperature is OK on that component.
I don't have a manual. and I've been searching for it...does anyone know which one I need?
Sorry I couldn't help with your problem, mine is similar to your though!!
Jan 22, 2011 | KitchenAid KEMC308K Double Oven
KitchenAid Superba Gas Range error code F3 E0 when trying to strat the range
The F3 E0 means
Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse Good luck
Nov 27, 2010 | KitchenAid Kitchen Ranges
I noticed my oven was taking longer and longer to reach the preheat temperatures I was setting. As time went on, the stove was not heating up past 285 and now the temperature never increases but I can...
It is probably as simple as changing the ignitor...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 16, 2010 | Maytag MGR5770 Gas Kitchen Range
Kitchenaid Superba Gas Oven Touch Pad not working
We have a gas kitchenaid KGST307HBL9 and the touch pad is blank, but we discovered that you can still touch the buttons and it will work. (example touch bake; temperature; start). It will beep when the target temperature is reached.
Just so we don't forget and leave the oven on, we turn the oven light on as our signal. A little work, but not wanting to "fork" out the money at this time to repair.
Also, if you are handy RepairClinic.com has many items and can also answer question. We've used them for several of our appliance repairs.
Jun 03, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
KitchenAid gas range superba not reaching/registering right temp.
Always preheat your oven and let it cycle at least 2 times. Your unit may show 350 but the manufactures know that it is not 350. When it registers preheated, it really means that it is at an acceptable temperature to start cooking. If you think that it may not be calibrated correctly, your owner's manual will have instructions on how to recalibrate your oven. You will be able to raise or lower the temperature by + 25 degrees or - 25 degrees. As far as the gas smell, you will from time to time smell a gas smell with a gas oven especially if you are right at it when it ignites. If you are smelling gas when it is not in use then you should be extremely concerned.
Mar 14, 2009 | KitchenAid KGST307 Gas Kitchen Range
Takes long time to preheat oven
you can increase the sides of the flame, by opening the orifice inside the oven, the location is where the burner sits on, what supplies gas to the burner. that will speed up the time.
Dec 09, 2008 | GE Spectra JGBP35 Gas Kitchen Range
Oven takes a long time to preheat
You don't list a full model number or how old this range is, or how long / how often you have this problem, but generally it sounds like the oven ignitor is not quite drawing enough amps to allow the gas valve to open regularly. It could be a low voltage related issue, but most likely is a failing oven ignitor. ( WB2X9154)
Sep 04, 2008 | GE Spectra JGBP35 Gas Kitchen Range
Oven takes up to 25 min. to preheat
I would suggest looking at how long before the bake burner ignites. If taking longer than 5 minutes before it ignites, then you are looking at a possible bad ignitor. The ignitors just don't last more than 5 yrs with regular use.
Jan 06, 2008 | Tappan TGF320 Gas Kitchen Range
KitchenAid KGRA806PSS Gas Kitchen Range Logo
2,259 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
