Question about EliteGroup P4M800PRO-M Motherboard
RAM DIVIDED INTO HALF
I don't know if this problem was raised before, yet anyways, I have 2 pcs of Kingston KVR / 1GB / DDR400 rams and put it on my ECS P4m800Pro-M motherboard. Yet the system can only see 1GB. I remove 1 ram and the system can only see 512KB.
I don't know what to do anymore. I am planning to update my bios but from the forums that i read, changing bios also pose problems.
What should i do?
  • Anonymous Dec 21, 2008
    I have the Elitegroup P4M800PRO-M Motherboard and it only sees half of my installed ram.I have 2x 1 gig chips installed and it only sees half of each chip.When I remove one chip it shows 512 megs of ram insted of the full 1 gig on the chip, also when I have the full 2 gigs installed it only shows 1.
I have the same problem on the same motherboard, it has been suggested by the ram manufacturer that chip density on the ram is too high, i am sending back the ram & having it replaced with ram of the same size but twice the no. of chips on each module
Posted on Feb 23, 2008
    Brigadier General:
  • 3,614 Answers
It sometimes happen that for some Motherboard or in any computer hardware that has a factory defect. Pheriperals and other clip on hardware much probably does not work, or maybe it works but there's much more possibilty to have / make problem.
Updating the BIOS i think it may not help, try to install the other ram you been using before and if its read the same capacity then its probably your 2KVR has the problem.
Posted on Jan 15, 2008
Can i use ddr2 kvr800 for my pc
Product Details Kingston DDR2 800 2G Memory Ram 1).Capacity :512MB.1GB.2GB 2).Model:KVR800D2S6/2G 3).Interface :DDR2 SODIMM computer ram,memory ram,laptop ddr ram,memory module Product Description User Rating: 0.0/5 Kingston Technology Kingston ValueRAM Computer RAM 2 GB - of DDR2 SDRAM, KVR800D2S62G KVR-800D2S62G KVR800-D2S62G KVR-800-D2S62G KVR800D-2S62G KVR-800D-2S62G KVR800-D-2S62G KVR-800-D-2S62G KVR800D2-S62G KVR-800D2-S62G KVR800-D2-S62G KVR-800-D2-S62G KVR800D-2-S62G KVR-800D-, ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices. Product SpecificationsModelBrandKingstonModelKVR800D2S6/2GType200-Pin DDR2 SO-DIMM
Apr 03, 2011 | Computers & Internet
Hi Dear ; When I install memory RAM of 1.0GB .. get ERROR
Cant find your motherboard on the support page, is the memory your trying to install the same speed?
Jul 16, 2010 | Intel Computers & Internet
Where do i put he memory
From the manufacturer's web-site:
http://www.msi.com/index.php?func=proddesc&maincat_no=1&prod_no=557
look at the "green" slots in the picture of the motherboard.
That's where the RAM goes -- note that the RAM has a "notch" that is *NOT* in the "centre" of the stick; so, the RAM only fits *ONE* way into the slot.
On that web-page, it says:
• Supports six memory banks using three 184-pin DDR SDRAMs.
• Supports up to 3GB memory size.
• Supports DDR400/DDR333/DDR266/DDR200 SDRAM
Note: PC3200 (DDR400) maximum 4 banks only.
So, if you buy DDR400 RAM, the maximum is 2GB (2 sticks @ 1GB/stick); if you buy DDR33 RAM, the maximum is 3GB (3 sticks @ 1GB/stick).
Dec 01, 2009 | MSI Microstar KT6 Delta (MS-6590)...
Motherboard ESC k8m800-m2 (v1.0A) 2x1Gb RAM
You have to verify the in the motherboard book if the brand name or vendor of your merory stick is compatible with your computer's motherboard, there all written : Kingston, Samsung, micron etc... Check all details if meets your motherboard's model requirements and make the change if necessary.
If all details are correct, check in your motherboard's manual if there is a special configuration to respect (in withc bank you should place your memory stick and witch order etc)
Sep 02, 2009 | Computers & Internet
In my Asus P5S800-VM motherboard, it won't accept 2 ports of RAM
Check the RAM in another machine if it worked then the RAM slot might have some problem....
Mar 30, 2009 | ASUS P5S800-VM Motherboard
CHILL WILL'S (motherboard E210882) WOES!!!
It seems like you have done everything right but im not 100% sure that your memory is correct. read through the description here carefully and you will see that this memory comes in two different packages. One of them is the 400 (the ones you bought) and another in the 333 flavor. I am hoping they did not make a mistake and gave you the wrong ones. Look directly at the memory and make sure. I am also including the system manual for your computer. Hope this helps.
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/index.htm
Kingston's ValueRAM KVR400/1GR is a 128M x 64-bit (1GB) DDR400 CL3 SDRAM (Synchronous DRAM) memory module. The components on the module include sixteen 64M x 8-bit (16M x 8-bit x 4 Bank) DDR333 SDRAM in TSOP packages. This 184-pin DIMM uses gold contact fingers and requires +2.6V. The product is shipped in retail packaging and includes installation instructions.
Apr 27, 2008 | Dell (E210882) Motherboard
Motherboard ASUS P5RD1-VM ram problem
More people should complain with Asus support. Checking Asus forums, you'll find there's an obvious problem with a PCI-E video addon + 2 used memory slots. In my case, I had 2Gb (1 + 1), mb with bios version 1104, and it worked fine; when I installed a new PCI-E card, the system was very... very sluggish. Now I have uninstalled 1 memory, I'm using only 1Gb of RAM with the PCI-E card, and it's working well.
Again: checking Asus forum, this is a reported problem, and a bios bug... Asus should release a new bios version, but they seem not to bother, as this is a relatively "old' mb...
Feb 16, 2008 | ASUS P5RD1-VM Motherboard
Memory issues acer t180 ud360a, no boot up with all (4) ram slots filled...
i had same problem with mine, i have the acer aspire ast180-ud360a, dont put the same memory next to each other, u have to stagger it, so it looks like
------------> [1gb] [512mb] [1gb] [512mb] <--- correct setup
and not like
------------> [1gb][1gb][512mb][512mb] <--- incorrect setup
Nov 25, 2007 | Acer Aspire™ T180 PC Desktop
EliteGroup P4M800PRO-M Motherboard Logo
172 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
