  • 1 more comment
  • STIGAMOW Jan 15, 2008
    Hoover model WMA35
    I should have identified the machine as a Hotpoint model WMA35
  • robert samples May 11, 2010
    whats your brand and model number we will try to help
  • 1,314 Answers
Have you removed the back panel from the control panelthere should be a tech sheet wireing diag there
Posted on Jan 15, 2008
I'm getting an E10 error on my Electrolux washing machine but only in the cotton cycle - it's not progressing onto the rinse and the fill times out. Is this a faulty valve or the control board?
There is problem with intake water.
Could be: inlet valve, wiring, control board
If in other programs it takes water then I would eliminate the control board and I would suspect that it is a faulty winding of the intake valve or wiring between the control board and the intake valve.
Mar 22, 2017 | Electrolux Washing Machines
What can cause noisy spin on wd960 hotpoint ?
bad bearings, seal leak let water in bearings
Tub seal leaking letting water get to tub bearings need shaft and bearings replaced. takes special tools
Aug 31, 2014 | Hotpoint Washing Machines
Bosch was28440au logixx 8
What happens when you select the spin, or drain cycle? Does the washer drain the water and commence with the cycle? If the water does not drain then the door will not unlock on it's own. The pull cord should open the door regardless. If the water is not draining, remove the lower right access panel and check the strainer for excess debris. Pleazer Appliance...
Apr 13, 2014 | Washing Machines
My maytag washer model #sav5710aww shakes badly and
if its a neptune front load washer you need new tub lip seal and bearings for the drum as the seal is leaking water into the bearings that hold the inner drum,it will only get worse,you need to remove the inner drumto replace the seals and bearing it takes from 2 to 6 hours depending how hard the old bearings come out of the race
Apr 02, 2010 | Washing Machines
Washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Mar 19, 2010 | Washing Machines
Washing machine problem
- Lid open error Lid is open during wash cycle. Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board "OE"
- Water overflow error Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord.
· Check water inlet valve
· Check pressure sensor switch
Apr 30, 2009 | Washing Machines
Washer won't spin correctly after fitting new bearings
there are no others sensors in the drum, the module (a circuit board) controls the actions of the timer, it may be one or so wires were disturbed at the time of repair, check all connections, any out of balance sensors would only work with a heavy loaded drum? You did not comment as to the motor / drum action when washing from the start of the cycle?
Sep 01, 2007 | Zanussi FLA1001W Front Load Washer
Washing Machines Logo
248 people viewed this question
Top Washing Machines Experts
