Question about Dell A940 All-In-One InkJet Printer
Clear plastic ribbon came out of printer
My 20 month old son somehow removed a clear ribbon like piece of our printer. The ribbon is about 15 inches long and maybe 1/8 of an inch wide. It is clear and has square openings on each end. Where does this ribbon go? Is this something I can fix myself or do I need to take it in?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 74 Answers
Firstly, see if the printer still works. Print something. Then I suggest bringing it into where you purchased the printer. If a twenty month old child pulled it out I am sure it was not burried inside the printer and a Rep at the store can fix it immediately with out cost. Do not let them charge you. Just let them know that this ribbon came out and you do not know where it goes. If the printer works without it, don't worry about it, but keep the ribbon tucked away somewhere and when you go back to the store, when it is convient, have them take a look at it. Let me know how it goes.
Cynthia Charczenko
Posted on Jan 15, 2008
I'm getting an error message when trying to print
Error 6C10 appears on certain Canon printers. It is a "valve cam sensor error". Here are some things to try to fix it:
Solution 1:
  • Move the printhead to the center.
  • Disconnect the printer and check on the right: is the purge unit ok? Is there a paper jam or piece of paper stuck in it?
Solution 2:
  • Do a reset of the printer by performing the following:
    • Turn the printer Power ON
    • Hold down the "Resume" button (triangle in a circle) for 15 to 20 seconds.
Solution 3:
  • Power off the printer.
  • Open the door.
  • Power on.
  • When the cartridge is in the center, close the door.
Solution 4:
  • Open the lid and allow the ink cartridge carrier to center itself.
  • Looking to the right, you will see a row of white rollers behind the carrier.
  • At the end of the rollers there is a small, clear piece of plastic that sticks up. Take a small piece of a paper towel and wipe all of the ink off this piece of plastic. When that is clean move on to the ink pad.
  • About 1 inch, towards the front of the printer from that piece of plastic, is a small square, about 1/2 inch per side, that is a small foam pad. This is where the excess ink is collected.
  • Take a piece of paper towel and press into the foam. Do this until the paper towel is no longer collecting ink. Close the lid, turn off the printer then turn it back on.
Solution 5:
Solution 6:
  • Remove case and look for the micro switch that is being pressed by one of the purge unit cams. Clean the switch and the cams. If the problem does not clear, replace the micro switch.
Aug 31, 2015 | Canon Office Equipment & Supplies
Error message 'out of stock' I have tried re-calibrating, it is not successful, any ideas how I can fix this would be greatly appreciated
Slide out the Media Sensor (green plastic bar that sticks out over the labels) about 1 inch from all the way in ("in" = left if looking from front). Then press Feed to clear errors. If still get same error, then look for piece of label or ribbon stuck in that error - ok to blow out with canned air.
Oct 21, 2013 | Datamax I-4308 Thermal Label Printer
Keep getting a check supply error
Oct 04, 2013 | Datamax DMX-I-4212 Label Printer
Ribbon fault
Hold in the Feed button for 4-5 seconds, which causes the printer to attempt to "Auto-calibrate." If that doesn't solve it, then slide out the Media Sensor (green plastic bar that sticks out over the labels) about 1 inch from all the way in ("in" = left if looking from front). Then press Feed to clear errors. If still get same error, then look for piece of label or ribbon stuck in that error - ok to blow out with canned air. Then try holding in Feed again for 4-5 seconds to Auto-calibrate again.
May 08, 2013 | Datamax I-CLASS DMX-I-4406 Thermal Label...
6C10 error cannon printer MP640
This error could appear on these Canon Pixma printers: MP110, MP540, MP630, MP620, MP640, IP3600...
Solution 1:
  • Disconnect the printer and check on the right: is the purge unit ok ? No peace of paper ?
Solution 2:
  • Do a reset of the printer:
  • Power on
Solution 3:
  • Open the door.
  • Power on.
Solution 4:
source: http://fix-your-printer.blogspot.com/2011/06/how-to-fix-error-6c10-on-canon-printers.html
Jul 04, 2012 | Canon MP640 All-In-One InkJet Printer
Out of stock
Oct 19, 2011 | Datamax I-4208 Thermal Label Printer
Carier Jam
Sounds like the carrier sensing strip (It tells the printer the location of the carrier) most likely time to replace
Apr 19, 2010 | Dell 926 All-In-One InkJet Printer
There is a thin strip of plastic that my son somehow took off ?
Hey ashley,
Do you know what area he ripped it off from if it was up top my the paper or where the paper comes out also what type of printer is this?
Feb 13, 2009 | HP Office Equipment & Supplies
Transfer ribbon
Remove the transfer cartridge, loosen the ribbon slightly and put it back in. This works for me!
Aug 23, 2007 | Teac P-55 Thermal Printer
Dell A940 All-In-One InkJet Printer Logo
153 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
