Question about MSI 845E Max2 LR Motherboard
FIC KTBC51G Gateway 5088 Motherboard
I can't seem to get the connections right. when ever I power it up the monitor goes down and all I get is the HDD light and the fans work. my post card shows 50. I have replaced the PSU the Ram the CPU and the mobo.
  • 5 more comments
  • Anonymous Jan 17, 2008
    I have the exact same problem, only the fan and HD power up, its like the MB is not receiving power, system will not boot at all, not even to bios
  • bigtk Jan 18, 2008
    no its not ok, i have no idea whats wrong and i dont wanna start throwing parts at it hoping i find the defective part eventually
  • Anonymous Feb 08, 2008
    Have the same problem monitor reads no signal as if mother board is not working. Built in video card. Is this the board?
  • Anonymous May 09, 2008
    I have the same fricking problem. My video kept going out, just turning black and saying no signal. Now it doesn't even boot up anymore. I've been trying to find what went wrong. Tried calling Gateway, they wanted to charge me to find out. Went to Best Buy to get a diagnostic done for $60.00. "We don't know what the problem is." Yay, great, $60 down the drain for nothing.
    Then by some miracle, it worked again. Don't know how or why, but it did. Then I moved my computer desk to another spot. The PC hasn't booted up since the move. I don't know if the power supply affects the motherboard at all, I never changed anything, but that's the impression that I get.
    So now my options are to pay $200.00 for a new motherboard to replace this piece of ****, or buy a new tower for $500.00 and strip this POS of it's hard drive and RAM.
  • Anonymous Jun 21, 2008
    mb get no power
  • towmater143 Sep 05, 2008
    I have the same issue. then i put a video card in the pci slot then it worked for about 3 weeks. and all the sudden the pice of **** took a dump and does not wan to show anything on the screen anymore.
  • pintu_song Oct 24, 2008
    i have same pc and it wont detect any video card on PCI- Express slot.
    so Hopefully i get any solution
I am having basically the same type of problem.....most of my video blanking occurs during my playing WOW online. I have replaced the onboard video with another video board but still having problem. My computer has also had the problem of not booting up too. On inspection of the motherboard I noticed that some of the capacitors on the board around the power input section have started puffing up on top....becoming rounded instead of being flat. This is a classic symptom that occurred on another MB that Gateway had in another model some years ago. This causes the MB to not boot and depending on which capacitors go bad, can cause any number of symptoms. my opinion the solution is to replace MB.
Posted on Sep 17, 2009
First I went to safemode removed the onboard nvidia driver then rebooted then went to bios. Had the same issue with the pci express until I went to the bios there was a video memory allocation up to 128m. I totally disabled that feature then F10 to save and then rebooted an the pci express card took fine. I like the Ati card I bought from newegg worked fantastic no more lock up or stall. I think Nvidia is always trying to do bleeding edge technology which can make their stuff unstable. I'm not saying they are a poor company they just try to hard.
Posted on Sep 19, 2008
I am having the SAME problem with my computer and am in the process of having the motherboard replaced. What a crock on this nice, expensive computer. I hope that'll work too.
Posted on Sep 02, 2008
Check this out guys. I've determined the problem to be bad solder of the onboard GPU on this motherboard. What I've done to bring these things back to life in the past is pretty simple. Pull the board out of the case, and flex it a little bit. NOT SO MUCH THAT YOU BREAK IT (like you have anything to lose anyway) but enough so that you should hear some faint crackling sounds. Put the board back into the system and power it up. Once booted immediately go into the BIOS and turn off the onboard video. Save your settings and power off the system. Install whatever video card you want to use.
I've used a heat gun on all the boards since I found the problem. If you are familiar with the XBox 360 RROD (red ring of death) then you know what I mean. The idea is to heat up the board enough to HOPEFULLY get the solder melted back into place. You hit the board with a heat gun for a good 15 to 20 minutes, swaying the gun back and fourth, covering the entier underside of the board. Try not to stop for any extended periods of time in one spot.
Posted on Aug 23, 2008
Have same problem.
Fixed the solution by adding a PCI video card, but problem reaccured after reboot.
Have tried several things including reseting CMOS, changing PCI slots, complete power down.
Posted on Mar 24, 2008
Have tried bus card for PCI-express 16x, card unresponsive, No POST beeps, even when RAM removed. Suspect board is DOA. Net research reveals is COMMON problem and Gateway is incredibly unresponsive, especially when they price their Media Center PC's at close to $2k, and only put a one year warranty on them.
Give up - Start shopping for microBTX Socket 939 boards. Good luck!
Posted on Feb 10, 2008
    Brigadier General:
  • 3,614 Answers
Try to replace the video card or insert another video adapter into your comp.
Posted on Jan 15, 2008
  • micromaster
    micromaster Jan 17, 2008
    Hi a good day..!
    --How's you PC doing now, it is all ok?
  • micromaster
    micromaster Jun 07, 2008
Most PC equipment is interchangeable. Seems like a there are chipset variations in the boards as well as a few spec variations. Most of the I/O configurations seems the same, so everything should hook up OK. The processor socket and memory support is also the same. I would expect you should have no problem with this as a replacement.
Nov 11, 2013 | Gateway Computers & Internet
Gateway gt4016 motherboard
It has Parallel ATA
PATA or also generally known as IDE,
1) Harddrive:
101311 - Western Digital, 200-GB, 7200RPM, PATA harddrive,
2) Motherboard:
105553 FIC KTBC51G
Product Views; F - Primary IDE Connector,
Left side of motherboard, near the black long Ram Memory slots.
This is where the Harddrive plugs in.
Product Views; E - Secondary IDE Connector;
Near the black long Ram Memory slots, and next to the blue Primary IDE Connector.
This is Serial ATA, or also known as SATA,
Uses this style of SATA data cable, and connector on motherboard,
(NOTE* Color does NOT matter for cable connector.
Color really doesn't matter, for a SATA connector on the motherboard, either.
You are supposed to plug the Primary SATA harddrive, into the SATA 1 connector, on the motherboard.
The beauty of SATA is, that you can plug into any Ol' SATA connector on the motherboard, that you want to.
BIOS will find the harddrive with the Operating System on it, and will find all the other SATA devices plugged into the motherboard, too )
You do NOT have SATA.
[You may be interested in this,
What's Inside: Computer > Computer Hardware > Explore These Categories,
Also to the left;
Computer Peripherals
Computer Security
Computer Software
Click on the headings at the top;
Case, (Computer cases), Cooling, CPU, (Processor), Input, Memory, etc.
Has basic information leading up to technical ]
Nov 30, 2012 | Computers & Internet
I Need the jumper settings for the fic k8mc51g motherboard from a emachines desktop computer. Putting the motherboard in a custom case.
There is a 4-Pin Speaker connector that is not used by Gateway on the motherboard (right beside) the CMOS jumper settings (Pins).
The clear CMOS settings jumper block is right beside the speaker pins. You can use this jumper block to clear the CMOS RAM, which is powered by the onboard real-time clock button cell battery.
Pin 3 is indicated by the markings on the board.
Settings: Pins 1 and 2 covered = Normal Operation Pins 2 and 3 covered = Clear CMOS enabled.crazyeyes746.jpg
Jun 26, 2011 | Computers & Internet
Have replaced this mobo "3"
Are the leads to the motherboard to the power button loose? In some motherboards there is a separate lead for the light of the button, or the LED. That would be my first guess.
May 02, 2011 | Gateway GM5072 Desktop PC
Ok, so I am fairly new with computers. I have looked for countless hours and days trying to find a manual a bios update, just about anything. Manufacturer First International Computer, Inc. Product ...
Looks like it is a Gateway motherboard made by Foxconn, you can get drivers and info from Gateway for this board at
May 02, 2010 | FIC (51-81677-00) Motherboard
GT4022 Gateway FIC KTBC51G Motherboard died
How did you determine that the MB was dead? Do you know how to use a post card and do you have one? How old is your computer and is it worth it to replace the MB? It is usually fairly easy to find a replacement MB on Ebay. Although, today desktops are so inexpensive that you may want to try that route. If you do replace the MB make sure that your power supply is adequate. We build systems every day and we never use less than 450W. If you do decide to replace the MB email me if you run into any problems and I'll see if I can assist you.
Jul 30, 2009 | Gateway GT4022 PC Desktop
Gateway GT5228 Motherboard Replacement Seems to be the most consistent answer that I find. Hope it helps.
Jul 27, 2009 | Gateway GT5228 (7156) PC Desktop
Lookig for a manual for an fic au13 motherboard
Front Panel Block Cable Connections
1 3 5 7 9
2 4 6 8
1] HDD-LED (+)
2] Dual Power-LED* (+)
3] HDD-LED (+)
4] Dual Power-LED* (-)
5] Reset Switch
6] Power Switch
7] Reset Switch
8] Power Switch
9] Dual Power-LED* (**)
* Single Color Power-LED 2 or 3 pins:
1 2 3
1]Power-LED (+)
2] GND
3] GND
** Dual Power-LED:
if useing dual power LED,
Green: pin2
Yellow: pin4
otherwise, Pin2 is positive (+) Pin4 is negative (-
For future Reference you can download your manual directly from the manufacturer's website HERE
Or directly from HERE
May 30, 2009 | FIC AU13 Chameleon Motherboard
Bad motherboard or power supply which fries motherboard
Gateway hasn't had any recalls on it that I know of. maybe it is not the mother board. It might be the hard drive. Hard drives can do that aswell. When I fix a computer the first thing I check is the hard drive. A little bit of advice with computers. Start with the small things first and work Your way up to the big stuff. Hope that helps.
May 20, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
MSI 845E Max2 LR Motherboard Logo
2,246 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
