Question about ViewSonic N3250W Television
Viewsonic N3250W won't power on
A local 911 Dispatch center has three of these LCD TV's. They all had Manufacture date of July 2005 on them Three of four have all gone down with no power up problem. Found capacitors bad on all three, able to fix first two with after market better caps. This last unit has burnt-up power supply and can't get any support from Viewsonic fort repairs. Unable to reach anyone last two weeks. Heard they moved from NC to CA and things are back logged. Never deal with Viewsonic products again.
  • 4 more comments
  • James32 Apr 27, 2008
    Same problem. No picture, red light, and a chirpping sound. Any fix?
  • ervinandkeyl Jan 09, 2009
    My viewsonic N3250w won't turn on because the power supply is out. I can not find one.
  • Bargain Boy Jan 12, 2009
    Same problem, same TV. I was able to find a repair shop in the San Francisco bay area to repair it, but they had to order replacement parts from Korea. Fix priced repair around $300.
  • Rocketman140 Mar 23, 2009
    Took it to local t.v repair. They couldn't find replacement power board. can anyone help?--J.T.
  • Anonymous Apr 19, 2009
    i need a new circit board
  • technoob May 11, 2010
    Hello, I have the exact same tv with the exact same date of manufacture - July 2005. I removed the back and checked that I had 120v going to the unit and that the fuse was good on the first circuit board. I presume the capacitor you mention is the big blue one around the middle of the board. I do not know where I could get one of these, and , as far as installing a new one, would it just be the case of removing the existing one and soldering in the new one. Need to know if some knowledgeable person would recommend I try this. I am fairly competant with a soldering gun. Any information on getting my tv working again with the minimum of cost would be great.
    Kind Regards,
    Vince
Got the same problem for a N3250. I'm not an electronic engineer and will attempt to fix my TV. Therefore I got the FSP2123F02 ($49.75)and now they have a harness 4WT0062302GP ($8.90) that will do a quick plug and play and will avoid any solder of the pins. That is my understanding can anyone corroborate this procedure. By the way I got both products from electronica-usa.com
I repaired it on June 28th with the lsit of parts above
More deatil information here (of the problem) http://forum.eserviceinfo.com/viewtopic.php?p=149367#149367
List of photos
B) new Power supply and new 12 pin connector (plug and play)
C) old board
Viewsonic N3250W won't power on - d8619b4.jpgsrc="http://i.fixya.net/uploads/images/d8619b4.jpg" alt="d8619b4.jpg" class="h_mi" /> e702b63.jpg
Posted on Jun 28, 2009
  • 3 Answers
I just repaired an FSP 212-3F01 power supply in a Viewsonic N3250W. I have seen the same power supply listed for the N3235W. This one was totally dead with no 5V stand by present. The problem was a shorted internal voltage regulator made up of Q7 and ZD4. The Q7 is a SOT23 size device and appears to be too small and over heats in the design. In this case it shorted from the over heating and that caused ZD4 to fail and shut down a 15V bias supply on the power supply board. I replaced Q7 with a 2N4401 to give it more power capability. Any small NPN transistor with a 25V or higher Vce rating will probably work. ZD4 is a 15V zener diode.
Posted on Jun 26, 2008
  • oscarhugo Jan 28, 2011
    Hello my friend!!!
    Do you know witch is colector, emisor and base from Q7??
    Thank you so much!!
  • Anonymous Mar 26, 2011
    JRNTX U R D BEST,AM A TECH FOR 10 YRS & U REALLY SAVE MAY DAY WITH UR EXPERTIES.I HAVE JUST REPAIR 3 OF THESE PS BD THIS WEEK,, I REPLACE Q7 WITH
    C815 THIS TAKE UP TO 60V--- THANK U THANK U THANK U..
    Problem Solver:
  • 5 Answers
Go to Power-On.com and look under LCD TV. It takes 6 to 10 days to get a new replacement for $45 plus S/H. The replacements come with a pin plug where the soldered on cable of the original is located. Depending on your set, you may have to unsolder the pins and use the cable from the old unit in it's place (an easy modification). ViewSonic was rather inconsistent on the power supplies they used. All are form and fit replacements with only the physical difference of the cable. You can contact me at [email protected] if you have questions.
Posted on Apr 26, 2009
    New Friend:
I looked at the good advice given by JRnTX to diagnose a Viewsonic N3252W with the symptom of no power. I tested the Q7 transistor and ZD4 zener diode and both were bad. I replaced the transistor with a 2N4401 transistor and the zener diode. I also replaced all the capacitors while I had the board out. I tested them all with an ESR meter. Several were out of spec but none completely gone. Good preventative measure to replace them anyway. Only a few pennies. Total cost to repair the board was about 7 to 10 dollars. I already had some of the required capacitors and don't remember their initial cost but they are pretty cheap. The power supply board was FSP212-3F01. It has now been replaced by FSP212-3F02 which usually comes with a backward compatible adapter to replace the 3F01. If you have a "no power" issue with one of these TVs that use the 3F01 board check the Q7 and ZD4 first. They are surface mount components so look for them on the underside of the board, not on the top.
Posted on Jan 10, 2010
    Problem Solver:
  • 6 Answers
Check the power supply, it seems to be a common problem with this tv. this website was made by some brilliant french guy and it gives a lot of good information about the problem, and how to fix it. I recommend either getting a new board from one of the suppliers he lists or do as I did and get the small chip and solder it in or have someone do it for you. mine is working great and I only spent $20 on the chip.
http://pagesperso-orange.fr/alain.mionnet/enii3210j.htm
Posted on Aug 06, 2008
  • 11,361 Answers
Lookin from top view (middle leg on on top)
Left = Base
Middle = Collector
Right = Emiiter
I use through hole 2N2222 to fix my Viewsonic N3250 ,and Protron 3250. Both TVs use the power supply made by FSP with similar circuits.
Both power supply have bad caps and bad Q7 and ZD4.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20N3250W/
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Jul 01, 2010
    New Friend:
Hi; Someone know where to get the diagram for this pcboard? Or how to identify the b/c/e of the transistor? Thanks! [email protected]
Posted on Apr 01, 2010
6ya staff
SOURCE:
Samsung LCD TV
The LCD panel appears to have gone bad.
Apr 23, 2015 | Samsung Televison & Video
Need to program a rca converter box with Daewoo remote control
If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 09, 2013 | Televison & Video
The volume won't stay at the level selected. It counts itself down to 00. I hold the volume button to raise the sound but it struggles to go back to 00. The highest setting goes to 03. I have no...
Remove the TV from the power for a few minutes, and then power on, then check the volume, effectively you have reset the set. If it still will not work, check the manual for any sleep settings etc, and work through the setup again for the channels. Now if none of that works, and it isn't a remote control issue? Then unfortunately you indeed have a problem with the set and it will need to be serviced. it will most likely be a microprocessor and ambient background noise sensor or the like, this will have to be replaced. To this end get a "Quote" from a certified repairer, and go from there?
User and service and repair manual at links below....should you wish to DIY?
http://www.retrevo.com/support/Viewsonic-N3250w-TVs-manual/id/276ag810/t/2/
http://michaeljaylissner.com/archive/viewsonic/n3250w-1_sm_1a.pdf
Oct 07, 2011 | ViewSonic N3250W Television
The Menu Screen blinks on and off while te TV is on.
Sounds like either three things are happening - 1 check your buttons on the tv and remote to make sure the menu button isnt stuck or doesnt have pressure on it to cause this 2 - your av card is bad or 3 your tv is possessed. :-) I'd check 1 and 2 first.
thanks,
michael
Apr 16, 2011 | ViewSonic N3250W Television
How do you get rid of Test that appears on the screen in red
It depends upon the date of manufacture for Hotpoint (Indesit) washers. The date should be on the panel probably at the back in the most handy position, sorry!
Date code 39 March 2005
Press start/cancel until ALL LEDS are lit
Press both start/cancel AND on/off together until 'dOFF' is displayed
Date code 39 March 2005 to date code 42 June 2005
Press the cancel button and the machine should return to normal
Date code 43 July 2005 onwards
Press both start/cancel AND on/off TOGETHER with top left option button until 'dOFF' is displayed.
Hopefully one of these should clear it ;-0)
Good luck,
John C
Mar 31, 2011 | Hotpoint Aquarius WF210 Front Load Washer
Green light is flashing tv will not turn on held down power on on tv and light turned red then yellow starts for 3 sec and shuts back down any ideas
Your TV has a bad inverter more than likely. There is nothing you can do to fix your TV except replace the part that is damaged. I recommend contacting Sharp and seeing if the TV is still under warranty. Most of the time they can dispatch a technician to replace the part for you. If you have to replace the part yourself then I recommend simply buying a new 32" TV since the cost of repair and parts will easily be in the three hundred dollar range.
Feb 28, 2011 | Sharp LC-32SB24U 32 in. LCD TV
I have a viewsonic n3250w that won't turn on. where do I start?
Unplug the TV from the wall outlet. Press and hold the power button for about 10 seconds. Wait five minutes and then re-apply power.
Nov 26, 2010 | ViewSonic N3250W Television
My Viewsonic N3250w tv I have had for 4 years no longer powers up. If you hit the button it lights up around the switch but then almost immediately powers back down. Does this sound like a power supply...
Power supply module will be the first thing to check, look for bad caps, find out if it has standby 5vdc and other voltages.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Oct 05, 2010 | ViewSonic N3250W Television
Viewsonic N3250w. Power supply went out and I replaced the bad capacitors. TV worked for a week then now when I turn it on, the screen just turns on and off
Check to see if the 24vdc disappear when the screen black out, it is always there then you have problem in the backlight inverter board. Did you replace the caps in the 24vdc supply also? I replace the whole set.
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for yo
Sep 05, 2010 | ViewSonic N3250W Television
Televison & Video Logo
10,243 people viewed this question
Top ViewSonic Televison & Video Experts
lubomir73
Level 1 Expert
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
