Question about Leica C1 35mm Point and Shoot Camera
Method for setting date in camera
I can get the date to blink but not to change it.Have mislaid my original user guide
0 characters
1 Points
I need a user manual for a Canon Sure Shot Z90W point and shoot film camera.
Mar 29, 2010 | Canon Sure Shot Z90W 35mm Point and Shoot...
Flash is not flashing
Common problem with flash charging transformer and/or bulb.
Needs replacement.
Does the green light blink or steady when you take picture?
Apr 05, 2009 | Fuji Zoom Date 120 35mm Point and Shoot...
How can I change the date display battery of Polaroid ProCam?
I typed in Polaroid ProCam into google and the first result that popped up is a manual:
Instructions on changing the date is on page 15.
Hope this helps : )
Mar 01, 2009 | Polaroid ProCam Film Camera
Can't set the date
Dec 17, 2008 | Minolta Freedom Zoom Explorer 35mm Point...
Canon Sure Shot 80 Tele/Date 35mm manual
try this website.
I checked it out but looks like they don't have the manual but they can do support by email.
Jul 19, 2008 | Canon Sure Shot 80 Tele/Date 35mm Point...
Pentax EZY-R change the date
Hey befiro,
I have included a link to a PDF download of your camera manual, and the instructions on how to change the date are on page 25 of the manual. I hope this helps!
Go Ahead. Use Us.
Jun 11, 2008 | Pentax IQZoom EZY-R 35mm Point and Shoot...
Date time
If the display is on ,yes, just push the SET button and the date / time will blink untile it's set.
If no display is on, the battery for the settings must be replaced. this is located near the pressure plate on the camera film door. ( inside )
May 09, 2008 | Pentax IQZoom 105SW 35mm Point and Shoot...
How do I change the date? I don't have a manual.
1. With power off, press the MODE button to select the DATE mode.
2. Press the zoom out (three trees) button for more than two seconds to enter the date/time set mode.
3. Press the zoom out (three trees) button to select year, month, day, hour, or minute (selected number will flash).
4. Use the zoom in (one tree) button to advance the number.
5. Repeat steps 3. and 4. to set each value.
6. Press the zoom out (three trees) button until the colon (in the hours:minutes) is flashing. When the colon stops flashing, date and time setting is completed.
7. Press the MODE button and the power will switch off.
Jan 13, 2008 | Canon Sure Shot Z180u 35mm Point and Shoot...
Date and time change
First you press the button called "MODE" and, without releasing it, press the "SET" button.
Then, the year will start to blink.
Set the year with the "SET" button. Once you finish setting the year, press the "MODE" button to change to the month.
Then, the same way with the month, day, hour, minutes.
After minutes, the display will stop blinking.
Dec 08, 2007 | Olympus Stylus Zoom 140 Deluxe 35mm Point...
Leica C1 35mm Point and Shoot Camera Logo
Top Leica Point and Shoot Film Cameras Experts
Steven Wander
Steven Wander
Are you a Leica Point and Shoot Film Camera Expert? Answer questions, earn points and help others
