Question about Creative Labs ZEN V Plus MP3 Player
Buttons lit up but not working?? Like it's in sleep mode??
Before unplugging the mp3 checked that it was ok to remove and when i removed it the screen went off and the buttons are still lit up but not working?? I have tried reseting,charging but not having any of it. I have looked at the manual and it says remove the battery but i don't no how to get to it? Please help. Thanks. Charlotte.
  • chazk06 Jan 19, 2008
    Thanks very much will try it.
  • 4,402 Answers
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
or try this
Posted on Jan 18, 2008
How to disable the sleep mode of my msi
Hi Tyrell,
Please try to check this website on how to disable sleep mode on your machine.
1. please unplug your notebook from A/C power and remove the Battery for a few minutes and then re-test? If won't work please check the sites below.
How Do Stop My Laptop From Going Into Sleep Mode eHow
How To Enable or Disable the Standby Mode
May 08, 2014 | MSI "MS-U135DX-1679ZA 10"" Netbook, 10""...
I can't wake my Xerox Phaser 6280 from sleep mode.
The Electronics Module may be faulty but first, unplug the unit from the wall for 30 minutes. Plug it into the wall and see if it completes posting and messages display on screen. Console Panel ZNN (Control Panel) 848K19391
Control Panel (PL1.2.16)
1. Remove the Exit Out Chute (listed below)
Be careful not to drop the Control Panel.
2. Disconnect the Control Panel connector P/J220.
3. Release the 6 hooks securing the Control Panel to the Front Cover
4. Remove the Control Panel.
Exit Chute
Exit Out Chute (PL6.1.1)
1. Remove 2 screws (10 mm, flanged) securing the Exit Out Chute to the
Front Cover.
2. Remove the Exit Out Chute from the Front Cover.
Mar 17, 2014 | Xerox Phaser Office Equipment & Supplies
Stuck in sleep mode
remove the battery and unplug your power chord for 1 min. then plug your power chord back in and try to turn it back on.
if it works then plug your battery back in and see if it boots your system up without the power chord.
if everything works fine then go into your control panel and change your power options.
Feb 12, 2014 | HP Pavilion Dv7-4065Dx Laptop Lcd Screen...
The monitor will go into sleep mode, and when first booted up will not register anything and goes to sleep. Have tried re-booting, checking the chords, plugging and unplugging them in. To no avail it...
No pc stated just monitor. (not even desktop or laptop) stated.
no OS stated, ether.
so ill answer in wide generic ways....
all computer are a problem, since days of Mr. Allen Turning to now.
ive done 43years of them just puters.(and other big systems MIL)
no person on earth can answer that common question
gee no pc stated,! nor can we lay blame until its fixed can we. ever.
3+billions of transistors. mine here typing now.
4,800,000,000, and friends, lots of other things to fail even LCD
its not a toaster or 4 banger calculator, at all.
its COMPLEX but 1 of those 2 boxs or cable are bad. sure.
(viewed in the MACRO)
sleep? how do you know it is sleep.
the screen showed that. text said SPEEP?
is the screen totally dead. (that is not sleep if true)
is the screens OSD button dead?,
the only clue i have here is one word, REGISTER (good word just too few)
so the screen never ever shows any text or HP logo ever
booting with monitor on for 5min. power on PC, see words?
no text
then push the monitors.
Select menu buttons on front of monitors. and the OSD pops does it , it must....!!! see image below (mine is Viewsonic, near new)
there are many simple tests here.
  • try you monitor on any other PC
  • or try you pc on any other monitor
easy no.?, just 1 or 2 tests and bam, who's bad.
called the process of elimination..
but OSD is first. no matter what,.
if the screen tests ok,, (display tests and its buttons)
then the PC is problematic, (1/2 the battle won)
the first thing to do (tell me what pC) but turn off all sleep
do that first. if you can even get the screen to work.
A pc never boots to sleep so.....
the PC can have 2 VGA jacks on the rear.
the PC can have DVI jacks, using those are you
try them all yet?
if you test the PC and it works and the screen works the cable is bad.
omg that screen is new, its even sold now at walmart.
not cheap either, too much, kinda
this is a modern 22" screen, LED>
and do not just go bad, is the power pack there and correct?
if the OSD screen is dead, check power first.
this is the Monitors brain, it works even with the PC dead.
the button is marked menu or select. this is test1.
osd-1z31dkbg41o2owghj0fas5br-1-0.jpg on my monitor ,heck all 2004 up
it tells you SLeep mode when the PC goes to sleep mode
or shows Power saver mode. live on the screen.
screen power on first sure.
all ways to go black done here.
Jul 20, 2017 | HP w2207 Monitor
Vista will not come out from sleep mode ?
Disable sleep mode. Right click the desktop any where. Chose screen saver at the bottom chose change power settings and chose change when the computer sleeps. Set to never. Just turn it off when not in use. Next; check the MS window site for a fix, there is a download update if it is still posted.
Feb 24, 2010 | Computers & Internet
Stuck on black and white Apple logo screen
Solution 1) Press Hold/Sleep & hold buttons at same time for 20 seconds, This may fix you problem.
If problem is still alive follow solution 2
Solution 2) Press Hold/Sleep & hold buttons at same time for 10 sec. & then leave only Hold/Sleep button keep home button pressed & connect you ipod to PC, That means you have to bring your ipod in DFU mode (Recovery mode) Check out this video for getting ipod touch in DFU mode
. itune must be run on PC.
It will ask you for restore. Accept Restore you ipod touch request by itune. Wait for few minutes while ipod being restored.
This process will solve your problem 100%. I have solved same problem for ipod touch. Follow this video
If my solution help you please vote up me.
May 22, 2009 | Apple iPod touch
Factory settings restore error
ok this is what u should try to do.
1) plug into the comp and try restoring it on iTunes if this doesnt work then u need to put it into "RECOVERY MODE" this is easy to do i will list the steps below,
1) plug into comp and open iTunes first.
2) To put into recovery mode, hold down the home and sleep button for 10-15 seconds (the shut down screen will appear but keep holding down the two buttons) When the apple appears, let go of the sleep button. continue to hold the HOME button and it should go into recovery mode
Mar 04, 2009 | Apple iPod touch
My iPod is being rediculous.
Hi! I think there is a virus in your iPod. Check your ipod with an antivirus when it is in diskmode. Then you need to open itunes and restore your ipod and will restore it to factory settings.
And if it doesn't work then Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect.
After doing this open latest version of itunes and then restore your ipod to factory settings by selecting it from itunes.
Dec 29, 2008 | Apple iPod nano MP3 Player
I can not start laptop because it stays in sleep mode.
Do A "Cold" Boot...
Remove The Battery For 30 minutes, And Leave It Unplugged..
With No Battery in and No Charger Cord Plugged In Now, Press and Hold the Power Button Down For 30 Seconds.....
After 30 minutes, Replace Battery and AC Adapter and Attemt to power on "hopefully not in sleep mode"
Nov 20, 2008 | IBM ThinkPad R31 2656 Notebook
Creative Labs ZEN V Plus MP3 Player Logo
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
