Tv dvd how can i tune my tv to my proline dvd recorder
  • 1 more comment
  • Margaret Passalacqua
    Margaret Passalacqua Jan 15, 2008
    could you please tell me i have 2 scarts in the back of my dvd recorder but only 1 inmy tv can you please tell me where they go in my tv etc
    Margaret Passalacqua Jan 17, 2008
    thanks worked great but can you please tell me why i cant record on this recorder it wont let me record can you please help
    Margaret Passalacqua Jan 22, 2008
    can you please help me make my computer go faster please i am affraid of deleting something important can you help
  • 102 Answers
Have a look at this online guide
Posted on Jan 15, 2008
  • Anonymous Jan 15, 2008
    One of the scart connectors is for hooking up your vcr or pay-tv decoder the other one should be connected to your tv.
    There should be a label near the connectors stating which is which.
    The black scart connector (av1) goes to the tv and the blue one (av2) to vcr or decoder.
    When both are black they could look like this example.
    When you have connected the right connectors through a scart cable your tv should automaticly switch to the scart input when you switch on the dvd recorder.
  • Anonymous Jan 17, 2008
    I guess you can look that up in the manual as I do not know every dvd recorder and the way it operates :)
6ya staff
SOURCE:
I am unable to auto tune my Tevion DVD Recorder
If the recorder is old the analogue/digital change is screwing it up. It isn't the TV that is the problem, it is the received signals, but the problem is the same.
Dec 28, 2013 | Tevion AP-DVR18 DVD Recorder
Can't tune in tv with dvd freeview.it states ext link problem
If you've connected the DVD to the TV via HDMI or SCART you shouldn't need to 'tune it in', just select the HDMI or SCART input. If your TV is also a Freeview device and you want to tune it to Freeview, where you have the aerial connected to the DVD recorder, you need to also connect the DVD recorder to the TV via an RF cable or aerial flylead so that the aerial signal passes through the DVD recorder. It's all in the instructions
Oct 16, 2013 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Unable to tune my liteon dvd recorder DD-A300 to a panasonic tv
I'm a bit confused about what you are trying to do? DVD recorders don't tune in to TV's anymore. They output the signal to the TV via a connector such as HDMI. To record the recorder will need an aerial feed etc, which can be split using a splitter between what feeds the TV and Recorder.
Dec 20, 2012 | Televison & Video
HOW TO INITIATE SET-UP PROCEDURE FOR 2ND HAND VIDEO/DVD PLAYER
You should have the main aerial going into the dvd and then a black flylead going back into the tv.If you go into the on screen menu you find a set section so you can re-tune the stations.
Aug 17, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Code for total control4 - Proline TV
i have the same problem cant get a code for my durabrand dvd recorder
May 05, 2009 | Televison & Video
Problems tuning TV and SLV-900
the video recorder has it's own tuner you do not actually record from the tv... think of the vcr as like a tv but without a screen... connect to your tv via a scart lead and while you are on the vcr's 'channel' (so you could see a tape playing on your tv) and access the menu on you vcr (not the tv's menu) choos auto tune if the vcr supports it or manual tune if it has no auto tune and tune in the required channels on your vcr... it is simply then a matter of selecting on your vcr which channel you wish to record
Oct 13, 2008 | Sony SLV-D900 DVD Player / VCR Combo
DVD records a black screen if tv is on standby.
You have tuned the dvd recorders channels? dont forget a recorder dvd/hd/vcr is actually a tv set without its own screen and to record from channels you need to have its on board channels tuned in... what you have been probably doing is using a function on many recorders that records direct tv... what this means is it records the feed back signal through the scart lead of what ever channel your tv is tuned to at the time that is why no tv on = no signal
Sep 24, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Tuning tv stations for panasonic dvd recorder DMR ES15
Set your TV to channel 3 or 4. Then press TV/VCR which is above the button on the bottom right of the remote. Then you can tune in TV stations from the unit.
Aug 20, 2008 | Panasonic DMR-ES10 DVD Recorder
Grundig TV - Tuning DVD & VCR
Hi there!
If the DVD recorder has an RF out then you should be able to tune it on UHF bandwidth. The cable should run from the RF Out on the recorder to RF on the TV. Switch the recorder on, put in a DVD and press play before tuning. Some DVD's require a disc before a Menu appears. Good Luck, Regards, JUS004
Mar 23, 2008 | Grundig GF70-600 TV
Televison & Video Logo
213 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
