Question about KitchenAid KUDS24SE Built-in Dishwasher
Can,t opendoor on kitchen aid dishwashr
The latch on dishwasher will not open
  • 5 more comments
  • kmdata Oct 05, 2008
    I have the same problem with a Kitchenaid Whisper Quiet.
    The door is closed and the handle is loose. It just will not open.
  • Anonymous Nov 17, 2008
    Same problem...I just went to open the door and the latch kind of snapped inside and now feels all loose in there. The door won't open. Any help would be appreciated.
  • sharonmannix Nov 29, 2008
    My door latch will not open. It feel loose and it wiggles around when I touch it. The model number is kudm24sebl5
  • sue5952 Dec 13, 2008
    I have the same problem model KUDS25SH just happened this morning when I went to open the door...help?
  • millston Apr 09, 2009
    Door is closed and the handle i sloose and won't catch to opent eh dishwasher. I don't know how to opent he door to remove the cover to fix the problem.
  • NormPres May 11, 2010
    HELP!!
    Door handle on this Superba QuietScrub dishwasher seems broke/loose, and can't open the door.
    You have a solution?
    I'm baffled!
    Norm
    Prestage2@aol.com
  • robert samples May 11, 2010
    this is a tough one i assume its in the closed position reply with model number and ill look up the blue prints and get back to you
    President:
  • 1,314 Answers
Send me an email ihave apage to send you b4829@yahoo.com under subject put kitchenaid door
Posted on Jan 17, 2008
  • McRobbie Dec 08, 2010
    KUDS24SE model..... latch and handle both broke. (same as all of you above) take a screwdriver, knife, etc...(6 inches long) and put it through the hole where the handle should be. The actual locking latch is at the very top of the inside of the panel.....if you poke around a bit you will 'find' the latch and be able to push it in (slight pressure - not much). This will unlock the door.
    Unfortunately you're now going to need to buy a new handle (and possibly - as I had to do rebuild the interior portion of the control panel plastic so that the new handle had a place to attach. (Epoxy worked on the plastic and all of the broken parts were actually down inside the door when I got that control panel removed.)
    Hope it helps...... now I'm out on this forum looking for a posting on how to open the damn door when the handle/latch is NOT broken......just about ready to go back to hand washing......at least that works!
Kitchen aid dishwasher whisper quiet model door stuck closed
I found this on another site hope it works for you.Take a bamboo shishkabob skewer and look were the handle is underneath the plastic console head unit and place the skewer on the right hand side... angle towards the center of the console and wiggle it in and push up...After i thought of the skewer it took me around a minute to push the latch up.
Read more: http://appliancejunk.com/forums/index.php?topic=5096.0#ixzz3Yhgf8Ihd
Feb 24, 2015 | KitchenAid Kitchen-Aid KUDD03DTSS...
Why does my detergent latch open up while the dishwasher is running?
If neither the detergent flap open or the rinse aid is being dispensed the this is usually down to a faulty or 'open circuit' solenoid that operates the dispensor unit.
Sep 20, 2014 | Maytag Dishwashers
My Kitchen Aid dishwasher, model KUDK03FTSS3, is stuck in a loop of some sort. It starts, but freezes after a few minutes. Does anyone know the reset key sequence to make this go away? Kitchen Aid customer...
Hi. Pressing and holding the cancel button may reset the unit at this time,as well as, pulling the ac plug out of the wall outlet for five minutes. With that said, I will provide the proper reset sequence below. 1. Open the door of the unit slightly. 2. Within three seconds, press the following sequence in this order-high temp scrub,energy saver dry,high temp scrub,energy saver dry. 3. After the sequence, close the unit door and latch it. 4. After the door is closed, press the cancel button. This will reset the main control, unless there is major damage to the circuitry of the control board.
Oct 13, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwasher won't run. Normal light and cancel light flashing cont
The door latch pulls the door tightly closed to prevent water leakage around the door. It is also designed to prevent operation while the door is open. The door latch works in concert with the door switch to ensure that the door is tightly closed and latched.The door switch is a separate part from the door latch and is found inside the cabinet. The switch is off when the door is open. Depressing the switch closes the circuit and enables dishwasher operation. Closing the door does not depress the switch all the way. Only when the door is closed and latched, does the door fully depress the switch.
If the door latch is not properly aligned it may not pull the door tightly closed and the door switch will not be fully depressed. Unless the switch is fully depressed the dishwasher will not operate. It is a simple matter to determine whether the door latch is the problem. Simply open the door, close the latch and select a cycle and depress the switch. Note that if the test is successful, with the door open, the dishwasher will operate and water may spray out. Make sure to first remove all tools from inside the dishwasher. Do not reach inside the dishwasher during the test. Now, inspect the cabinet where the door makes contact with it and locate the door switch. It may have a protruding button or spike or more likely it is a hole with a piece of metal or plastic inside it. You must fully depress that switch. If the switch is recessed, then use a non-conductive object, such as a wooden pencil, to depress the switch.
Thank you !!
Jun 18, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Need door latch diagram Kitchen Aid dishwasher (Part No. 9744033)
I thought the metal bar had to be locked into place somewhere in the black latch. This was not the case. I just put the white plastic latch in place in the slot in the door and closed the panel and the metal bar went into the correct position against the black latch.
Jan 22, 2010 | KitchenAid KUDS24SE Built-in Dishwasher
Kitchen aid dishwashers model kudi1o1ilbl6 won't function. Cancel light flashes 7 times pauses and flashes 7 times repeat for ever. killing the power did not reset. Advice?
open door, press in rapid sequence the following keys: hi temp scrub, energy saver dry, hi temp scrub, energy saver dry. Close the door until it latches, then open it and depress the cancel key. The lght should clear. It's a beautiful thing.
Aug 15, 2009 | KitchenAid 24 in. KUDS25 Built-in...
Kitchenaid dishwasher - door will not latch
The latch needs to be replaced. Kitchen Aid has made two updates to this latch. I.E. 2-revised latches. I just replacd the latch assembly and the dishwasher works fine now. Do a search for kitchen aid repair parts online and hav them shipped to your home. The repair takes five minutes. Un-screw all torx bit screws on door and the latch is under neath. One electrical dip switch held on by another screw and a two prong tab to undo the old latch. This seriously took me five minutes to repair and the parts were $40.00 online shipped.
Hope his helps.
Dec 16, 2008 | KitchenAid 24 in. KUDP02CR Built-in...
Kitchen Aid dishwasher won't start
If the power indicator is on check the latch as alot of the kitchen aid dishwashers wont start if the latch is out of alignment.
Jul 02, 2008 | Dishwashers
Dishwashers Logo
464 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
