Question about Garmin StreetPilot C330 GPS Receiver
Keeps turning off
Says it is running on battery power and will turn off in 30 seconds. Checked fuse in car and is okay - don't know why GPS keeps saying Running on battery - will turn off in 30 seconds. Will come back on, but goes off again after same message
  • Pepperoni Jan 16, 2008
    Will check it out - thanks so much!!!!
  • 174 Answers
Your power cord is cutting in and out. You either have a bad power cord or there is something wrong with the connection to the cigarette lighter. When the unit say "Running on battery - will turn off in 30 seconds" this mean that it has lost external power. This is by design so that when you shut off the engine external power is cut to the unit and that it will shut down.
It a shame that for the C330 Garmin decided to remove the LED light from the power cord that shows the power cord is connected correctly to the cigarette lighter.
Posted on Jan 15, 2008
Dodge 1500 1995 pickup 7.5 volts to fuel pumpwill not start applied 12 volts pump runs book sayes pcm de-energize booth relayes and will not send proper voltage to fuel pump
There is a red and white wire feeding the fuel pump relay from a 30 amp fuse. Both the shutdown relay and the fuel pump relay are grounded by the PCM, so if the fuel pump relay is grounded it should be "on" and providing a direct link from the pump to that fuse.
You should have battery voltage on that 30 amp wire before the relay and then on the dark green and black wire going to the pump.
If you don't have battery voltage coming from the 30 amp fuse, the problem could be before the fuse.
That 30 amp fuse is hot all the time, so it is powered by a fuseable link coming off the battery.
Jun 24, 2012 | Cars & Trucks
I cant use my controler because the green part keeps bliking and wont turn on so i cant play my xbox 360
I had this exact same issue the other day. Changing the batteries did not work for me, but don't cross that off of the list quite yet. This worked for me:
1.) Pop the battery pack off of the controller. This is the only way you're going to be able to turn it off. Wait about 5 seconds and put the battery pack back into the controller.
2.) Turn on your X-Box with the power button ON THE CONSOLE. It should turn ON. If it doesn't, unplug the X-Box for 30 seconds, plug it back in, and try again.
3.) When your X-Box turns on, go ahead and hit the controller's power button. Things should function normally from this point forward.
Please let me know if this works for you!
Sep 30, 2011 | Microsoft Xbox 360 Controller
Yes my fuse for my wipers keeps blowing and my wipers turn on when i plug fuse in even know the wipers are turned off.
The power distribution box in the engine compartment # 6 , 30 amp mini - fuse , front wiper motor , front wiper relay , front washer pump , FEM ( also # 7 , 25 amp mini - fuse , rear wiper etc. ) The owners manual shows to disconnect your battery cables before servicing anything in the PD BOX
your relay could be shorted which makes the fuse keep blowing
Sep 05, 2011 | 2001 Ford Windstar
Daughter called me wont start. checked battery at is good. someone stopped to help them and bang on startere and it starts up. Bad starter. Starter replaced. Next day daughter...
it sounds like you have blown fuse to the Alternator.. I don't know what car you are talking about but they charging systems vary.. But if alternator isn't getting all the power it needs it won't charge. this should be checked.
good luck
Sep 02, 2011 | 2000 Oldsmobile Intrigue
My subwoofers cut out after 30 seconds of use but work fine during the 30 fuses are all fine and i'm running thick wire with an 80 amp fuse connected off battery...I have a lanzar vibe286...
If it's only your subwoofers cutting out and your speakers are still playing and all, try turning gain down on sub amp and see if that fixes it. I know if I crank my amp too high it kicks itself off to try to keep itself from blowing.
Aug 21, 2011 | Car Audio & Video
Our GPS keeps saying low battery and then going off. thought it was the cigarette lighter that wasn't working, got a new fuse, but it still says low battery. opened the back, now what
Let me see if I understand your question.
You had your GPS plugged into your vehicle power outlet (AKA cigarette lighter) and you thought you were charging the battery all along. However, your power outlet was not "live" (you checked?) so you replaced the fuse. Your GPS was telling you LOW BATTERY and turned off, and that was why you checked the fuse and it was blown, right?
So now, your power outlet is hot (you checked it right) and you have a good 12 volts DC. You have your GPS plugged in and it still says LOW BATTERY and shuts off. Is there a fuse in the GPS plug? Have you checked for this? Are you able to check the voltage where the cord plugs into the GPS with a volt meter?
There is that possibility that everything is well with your power supply - but you must check and assure you have power. If it is, and your GPS still says LOW BATTERY, I would be inclined to take it for a drive with it plugged in and turned off. At the end of the drive, try it again. (Is your power outlet HOT when the car is not running?) If all is well with the power and you have tried to charge it, the battery may not be accepting the charge due to a battery fault. I don't know if you have the tools required to change the battery or not. If you do and if you can find the battery (there are lots of batteries available at many sites) and it does not cost more than a replacement GPS, I would suggest you give it a try. What the heck, it doesn't work now so you don't have much to loose except the price of the battery.
You might find the battery you reqire at a advertiser to be found here on this page. Your support of advertisers will be appreciated by the site.
If I missed the ball, please provide a little more detail on the matter and I will try again.
There it is all in under 10 minutes.
Thanks for using
Jun 27, 2011 | Maylong Group Maylong 43inch FD420...
2001 crown vic keeps burning 30A PCM relay fuse
have fuel pump checked i have known a bad fuel pump shorting out causing pcm fuse to blow.
May 10, 2009 | 2001 Ford Crown Victoria
Garmin StreetPilot C330 GPS Receiver Logo
283 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
