Question about Sony PlayStation Portable (PSP) Console
Power gets no charge and wont power on
  • 1 more comment
  • chuche Feb 19, 2008
    i tried to charge my psp with a 6 volt charger instead of a 5 volt charger now the psp wont charge using both type of chargers. thing i might of burned it out or shorted it.
  • Waleed2snype Apr 21, 2008
    i pluged in my psp charger into my psp the orange light wont come on and the psp wont even charge i brought my friends psp and it work with his psp but not mine please i need help
  • Anonymous Jul 07, 2008
    Kids played it til it was dead, and possibly spilled something on it too, cuz it was sticky. No orange light when put on the charger, and that is either way (on the charger, or plugging the cord directly into the PSP), although the blue power light is on the charger. So no idea if its just the charger/battery, or if there is any problem with the system itself. Is there any way to check (without buying new battery).
No ur video doesnt help....
Posted on May 23, 2008
So i guess i wont use a 6 volt charger
Posted on Apr 10, 2008
    President:
  • 4,402 Answers
Http://video.aol.com/video-detail/re-psp-wont-charge/3601584488
Posted on Jan 15, 2008
SOURCE:
Why my power windows,dome lights,dont work plus car wont start
ok a lot not said here trouble shooting time. does the battery have a full charge "no" put a charge on it. battery wont charge and still wont do a thing dead battery get another one. ok battery charged and all works undo the positive cable on battery, if it still runs "good" if not alternator is bad. hope this helps not much to go on
Sep 09, 2014 | 2004 Ford Explorer XLT
Kohler diagram
only thing it can be now is charging stater is bad but dosnt make since its getting power somewhere has to be stater is charging check voltage at stater see if power there if is check relay behind dash see if power there then go to switch see power there this done while engine is running and battery unhooked if no power at switch replace it if motor wont start jump start at starter to get it going if wont start let me know well go from there
Sep 02, 2014 | Garden
My iphone 4 8GB only charges when powered off. It doesnt show charging symbol and wont charge while powered on. Not jailbroken. Itunes doesn't recongnize it while plugged in to laptop I tried 4 di
First, make sure that if your iTunes version is high enough to fit the version of your iPhone.
About charging, I think it means the output current of your charger is to low to charge and run your iPhone at the same time. This case is most like that, when a iPad 2 link to PC it won't charge when the scree is on.
If you are using digital products frequently, you can try to get a dual USB output external power supple, which hold on 2 type of output current 1A for common cell phone, 2.1 A for iPad, Pad PC and some device which need high charge current
Apr 03, 2013 | Apple iPhone Smartphone
Iphone won't charge unless it is completely powered off
Luckily, there are some tracks you can try to fix it.
iPhone wont charge when turn on
# Check Charging Accessories
# Clean Charging Port
# Hard Reset Your iPhone
# Using iPhone Recovery Mode
# Restore iPhone to Factory Settings
http://www.recoveryiphone.net/article/fix-iphone-wont-charge-when-turn-on.html
try practical methods to fix your problem, and if it still can't get your problem solved, just take it in for service at the nearest Apple Store in your area to get the help of the Apple employee.
Mar 20, 2013 | Apple Iphone 4s latest Model - 32gb -...
My tablet wont charge unless turned on but battery is so low it wont turn on so cant charge it up.heeeeeelllllpppp
You Power Cord must be bad. If you cannot get on the laptop by using just the power cord, then the power cord is bad and needs to be replaced. Also it sounds like you've been operating off your battery since the power cord is bad, but now the battery is dead because the bad power cord was not charging it.
Get a new AC Adapter and Power Cord. Or it could be that the pin where you plug the power cord into the table is damaged or broken.
May 15, 2012 | Archos 101 Internet Tablet 16GB 10.1"...
When I try to charge my iPod on my AZ-1330D (AZ1330D/37) Docking Station I get the message "charging is not supported with this accessory." The IPod is a Generation 5 Nano.
There may not be enough power from the docking station to power the nano. There are also rare times when it wont charge because the ipod doesn't recognize it and wont charge to protect itself. Try plugging it in directly into your laptop if possible.
Dec 29, 2009 | Philips Audio Players & Recorders
Magellan Roadmate 300T, bought new battery but it wont charge.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
the following magellan800,860,2000,2200t,2500,3000,3050,3100,3140,4000,4040,4050 and the 6000t are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc powerport...i sell these power ports and will repair them for anyone thats notable to do it themselves.
you can get it repaired here
or buy the port here
Sep 03, 2009 | Magellan RoadMate 3000T GPS Receiver
Wont charge and get get it to stay on,
Check Power supply first.
use another one and check if battery is charging.
Jan 12, 2009 | HP Pavilion ze5270 PC Notebook
Ac power pack keeps failing, wont charge battery
get the whole laptop checked by the service center
as if the batteries and the power pack are ok there might be the problem with the mother board
Aug 22, 2008 | Compaq Presario M2000 Notebook
Sony PlayStation Portable (PSP) Console Logo
205 people viewed this question
Top Sony Video Game Consoles & Games Experts
shevantha perera
Damen Wong
Damen Wong
Nikki  Mclean
Nikki Mclean
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
