How to fax
I do not have the manual for the estudio 282 machine I am recieving faxees but I have no idea how to send a fax if i enter a number it just doestn do anything
Im sure there is something I am not doing but I don't have the instructions
  • 102 Answers
The online interactive e-STUDIO 282 manual can be found here
Posted on Jan 15, 2008
Call service c440 total counter 712154
switch on the copier while pressing '08' enter 400 press start button enter 0 press enter key
Feb 17, 2014 | Toshiba E-Studio 282 estudio 282
Xerox Work Center 657 Will Not Recieve, After Replacing Drum
Check to see if when he reset the fax reverted back to receive only as a default.
  1. Press [Menu] (the Up arrow key), and press [3], [1], [0], then press [1].
  2. Select the Answer Mode:
    • Press [1] to select Auto answer, then skip to step 3.
    • Press [2] to select Manual answer, the press [Stop] to return to the Standby mode.
  3. If you select the Auto answer feature, use the numeric keypad to enter the number of times (must be 2 digits, 01-10) the phone must ring before the machine answers, then press [Enter].
    NOTE: When the machine is set to Auto answer and the set number of rings occurs, the machine answers with a fax signal tone and enters the Auto Receive mode.
  4. Press [Stop] to return to the Standby mode.
Jun 30, 2009 | Xerox WorkCentre Pro 635 Laser Printer
Fax can not recieve. It sends okay. Hp fax 1010
Most likely the machine has been set to "manual receive" from either "fax/tel" or "automatic" receive. check your manual to check/ change the setting.
May 26, 2009 | HP 1010 Plain Paper Inkjet Fax
I would like to know how to send faxes and recieve faxes, I have lost my manuel in moving.
first, you can download the manual from the website at www.brother.com
but the basics, put your paper that you want to send upright in the document feeder, touch the fax button, dial the number, and your done.
make sure your phone cable is wired correctly to the fax.
Apr 17, 2009 | Office Equipment & Supplies
Cannot recieve faxes, but will send them
No model number provided.
....but your problem is that you have switched off "automatic reception", and set it to "manual reception" somehow. Check your manual to find out how to set it.
Cant recieve fax on Toshiba estudio 3511
Hello sir; For the fax line only have two single lines working in the cable one is in-coming ,another one is out-going, therefore if you can send fax and can not receive, that's means your phone cable or phone jack on the wall have problem, my sugestion, replace phone cable first, if still have problem check the phone jack on the wall.
Jan 23, 2009 | Toshiba E-Studio 3511 Color Copier
Philips fax phone hfc 171
It goes face up into the bottom of the machine. Here's a manual. http://www.fax-anleitung.de/Philips/Fax%20HFC/BDA%20HFC141-171%20uk.pdf
Carl
Nov 10, 2008 | Philips Lands Phones
Fax Error codes
I have mentioned the Description for the error codes.388 and 421 error codes means the same and suggestion to resolve the problem.
282 - Retry the transmission.
388 - Reattempt the fax reception at a different time when telephone line conditions have improved.
421 - Reattempt the fax reception at a different time when telephone line conditions have improved.
233 - A communication failure has occurred between the two machines (OR) The user at the remote machine might have pressed the Stop button. (OR) Sometime Call waiting service might cause this error code.
  • Turn OFF the Error Correction mode(ECM).Steps to do. Push the menu/setup button ->Select Advanced fax setup-> press ok/Enter->Scroll Down to Error Correction mode(ECM) and highlight -> press ok/Enter->Select turn OFF-> press ok/Enter.At Last Press Cancel to quit the menu.
  • Decrease the Fax speed.Steps to do.Push the menu/setup button ->Select Advanced fax setup-> press ok/Enter->Scroll Down to" Fax speed"-> press ok/Enter-> Choose "Medium speed or slow speed ->press ok/Enter. At Last Press Cancel to quit the menu.
Thank You
Feb 08, 2008 | HP Officejet 9110 All-In-One InkJet...
Can't send any faxes
Hello,Mafriend,It sounds like you might have recieved a Fax machine that Recieved a surge,To verify this Ck the Jack where the Phone line goes in to see if you have any type of discoloration there,also see if it locks up your phone line from making calls or recieving Them ttech
Jul 20, 2007 | Panasonic Panafax UF-560 Plain Paper Laser...
82 people viewed this question
k24674
jasbo
jasbo
