Question about Dayton E52 Utility Heater
200,000 BTU Oil Fired Dayton: Shuts off
Hi there ! Our unit pretty much stopped coming most of the time and stopped after a few minutes when it did come on. I read your solution on checking for fan blade clearance with the couling. We blew out the rear section with compressed air, added small washers under the couling lip to raise it 1/16", put the couling back on. It fired right up and ran great for about 5 minutes and shut down. When we ran it with and without the couling on it seems to have a lot of good fan pressure. Is there a manual and or more trouble shooting tips for this size unit? Do you know what my next thing to check is? Thanks in advance, Mike Quante
  • Big Mike 642 Jan 15, 2008
    In my post I mentioned I was looking for a manual etc... so I would better understand the solution info. I really don't understand the terms you are using. I do not know where the cut off / cut on settings are. Which way to turn them? Etc... Etc... In addition, I posted this under E52. I do not know the exact E Series this unit is but the model # is 3VG79B. It is a 200,000 BTU unit. It has "Hsi" Smart start technology / Hot surface Ignition system. Without a manual I need plain talk like: Take that black knob thingy located in the left rear of the unit just under the red knob and turn it 1/4" clockwise until... Thats the kind of help I need. By the way, we added some more small stacked washers under the couling raising it to approx 3/16" - 1/4" up from the base and it has now been running for 2 hours straight if that info helps. Do you know where I can get a manual as well? Thanks, Big Mike 542 "The unknowing One" !! LOL
  • Big Mike 642 Jan 16, 2008
    I really need you to spend a little more time on your responses to me so I know what you are saying. You posted a link just after the word manual so I assumed thats where I could get a PDF manual to print. I go to the site for 15 to 20 minutes and not only could I not find any manuals I can't even find my type of heater in there. Tell me what this link is for ?? I found just about every kind of heater you can imagine but nothing even close to mine??? Tell me about this thermister in the flame properly (what is the proper setting of it)? If you are going to help me trouble shoot this without me having a manual and no knowledge of how it works I need you to tell me what you are saying in more detail and why. Thanks, Big Mike
    President:
  • 1,314 Answers
Id check the theromastat for proper cycleing and the ignightor
Posted on Jan 15, 2008
  • 5 more comments
  • robert samples Jan 15, 2008
    ok where is my brain all thermostats have a cut on cut off setting your cut on may be right but your cut off may be too low so its cycling off too low there for too early
    make sure the thermister wire in in the flame properly
    well where you set the heat is the thermostat the cut in cut out cant be adjusted has to be replaced lol some times i need that even with the maneul http://www.detroitradiant.com/partscente... here big mike let me know ok
  • robert samples Jan 16, 2008
    sorry mike your right went back to the site and i couldn't find no info there im just trying to help don't rate me because im not interested in the cash even if we solve this let me do some more research then ill post in terms that will work i really thought needed info was on that site sorry again
    its late in my part of country but you might try www.granger.com as they handle dayton products my expertise is in major home appliances but a heater should work the same way as a gas range
    http://www.grainger.com/Grainger/wwg/sta... sorry about that last post mike misspelled it you can go there and go to parts your model number is 3ev52 type it into parts can get printable diagram and printable parts list they also have a tune up kit tech support there says if you e mail them they will answer in a day
    3ve52 im going to bed lol
  • robert samples Jan 21, 2008
    well mike i appreciate the rating but i really didn't earn it just trying to help you so we can build the site all of us are trying to make this the best repair site we can but i did it for you and your problem did you get it fixed and what was it that info may help some one in the future
90000 btu high intensity infrared ceiling hung heat. Have replace twice and Honeywell gas valve once. Always starts and runs first time then never starts again. Coils on gas valve keep burning up. ??
Dayton 3E134E Troubleshooting guide - manualzz.com
manualzz.com/doc/1285710/dayton-3e134e-troubleshooting-guide
This heater must be installed and serviced by trained gas installation and service ... Dayton High-Intensity Heaters ® Description Dayton high-intensity heaters ... ofinfrared radiation by heating a ceramic refractory material to incandescence. ..... 3E133, 3E461, 5VD63, 5VD64 90,000 BTU/H Do not mount heater horizontally.
[PDF]Fall Heating - Plumbing & HVAC
plumbingandhvac.ca/images/documents/PHVAC_Sept-Oct03.pdf
Nova Scotia gas utility eyes dealer network ... valve underbody and screw trim pieces ... Infrared requires a different way of ... gives you a crisp picture, and speeds up pipe locating. ... tiative will keep HVAC contractors busy ..... labelling for equipment usinghigh pressure R410A ..... Multi fired from 90,000 to 179,000 btu/h.
Jan 05, 2016 | Dryers
Have 30,000 btu Dayton heater m#3e3665 when reaches temp. fan
Hi blow heater out with air line flame sensor could be dirty check out pressure switch jump this out see if it lights
Feb 09, 2010 | Dayton (3E379) Heater
I need a service manual for a Dayton oil fired 350,000 BTU heater.
I have a manual for a Dayton 3E218E. If you want a copy email me at Edwards0202@aol.com and put "HEATER MANUAL" in the subject line. I can scan it in and email it back to you. This manual is for 2E510F, 2E511F, 3E218E and 3E219E. I also found a great web site for parts for all these models as well:
http://www.bealsmotor.com/
Nov 30, 2009 | Dayton E50 Heater
Wat the hell is wrong with my dayton heater?170,000 btu oil fired...wont stay runnin?on shut down puffs like a mutha....
Most use a spark plug to ignite fuel it could need cleaning. You also could have water in fuel or dirt
check and clean ignitor/spark plug clean fuel line and nozzle, drain and clean tank Check for water in fuel by tilting unit to have a low corner siphon fuel from that corner after 1 hr inspect for water.
Jan 23, 2009 | Dayton E51 Oil Filled Utility Heater
DAYTON 210,000 BTU OIL-FIRED HEATER WON T LIT UP
You write "FUEL SPRAYING AND FAN WAS WORKING"
If the fan was working, but the fan is not working now after replacing the whole kit, then something was installed incorrectly during the installation, possibly the rotor gap or rotor thickness is not correct or vane/vanes installed 90 degrees off.
Dec 08, 2008 | Dayton E50 Heater
Dayton 600,000 btu heater oil fired
throw a gas can in a fire it is alot more fun.call the manufact
Jan 02, 2008 | Dayton E50 Heater
Dayton 3E227A Heating Cycle
The sensor for the thermostat is probably going bad or has bad connections. It is (or thinks it is) heating up fast and therefore shuts of the heater.
Dec 30, 2007 | Dayton (3E386) Heater
Dayton E52 Utility Heater Logo
364 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
vance jones
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
