You have primary keys and secondary one. The secondary can be used by holding at the same time shift and the key you want to execute or the by holding fn key and pressing the one you want to press.
You should try to explore the calculator to find its capabilities. You can also read the manual. Everything is in it.
Press the Mode button, then the down arrow key. On the second page of the mode list you find 2:Verif
An upside down image - this is caused by unintentionalpressing Ctrl-Alt plus the down arrow key.
Restore by pressing Ctrl-Alt plus the up arrow key.
ALSO
To change the display from portrait to landscape
Press Ctrl-Alt plus a left or right arrow key.
If so, here's a first attempt. It may be correct, and it may not be.
It's up to you to understand the process, and to make any needed corrections.
X minus 11 equals Y.
So, X is larger than Y.
So, 3 times X minus 33 equals 3 times Y.
Thus 3 times X equals 3 times Y plus 33.
Also, 3 times X minus 4 equals 4 times Y.
Hardware problem, keyboard is shorting out at different times. Keyboard needs to be replaced. Possible some water got on it or just over time keys tend to stick from dirt, dust, etc.
Easy: 1.) Turn it on ("ON" button) 2.) Hit the "STAT" button 3.) Hit the Right arrow key Twice 4.) Hit the down arrow key once or hit the "2" button 5.) Enter your Data into List one (L1) OR Right Arrow once and "ENTER" to just enter your statistics
To just Enter the Statistics: Down Arrow once and Enter: Hypothesis mean Sample Mean Standard Deviation Number of Tests and Either (not equal to)Ho , <Ho , or >Ho Then either hit Calculate or Draw
The comma key on the TI 84 SE is above the 7 key, and it is just left of (, right of x squared, and below SIN. thats where the "," key is. If you're asking something else, please clearify. My understanding is that you don't know where the comma key is.
press the plus key again, it should work. ie put a number in and press the plus key twice, it should double, and again it should double again and so on
If you are facing problem with any particular usb device then it doesn't means that the usb port of your laptop is faulty,You need to check the usb device.........or you can buy a new usb hub which is very cheap ..
whats wrong with the keys what are you not understanding?
