Question about Toshiba 32AF43 32" TV
Black line I have a black line that runs from one side of the picture to about one inch from the other side. When the tv is off the line is still there, a little darker tha the rest
    Sergeant:
    Champion:
  • 375 Answers
The screen is burnt inside,/crt replacement to correct or ignore
Posted on Mar 28, 2008
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
How can I fix my Element Plasma 42 inch PLX4202B facing the tv on the right side there is a black 2 inch black line I ordered the driver board for the right side and installed it but still it seems to be...
i have a 40" element tv and it is about 3mo. old and it has two screens on it and they are on the wrong side of the screen how could i fix it it works but the picture is messed up
Mar 18, 2011 | Element Electronics PLX4202B 42 in. Plasma...
A black line running verticall down the middle of
There is no invertor board on a plasma tv. The fault is the X address buffer board. This is located on the bottom of the screen and runs horizontally the whole width of the screen. If you remove the heatsink plate that covers the x address boards and you need to look at the screen ribbon at the same position as where the bar is (in the middle).Vary gently lift the Xbuffer ribbon lock and gently take out the ribbon.Clean the contacts very carefully with a fibre pen or an electrical cleaning fluid.Insert ribbon back and heatsink and check.Here is a picture of the board and ribbon
a 1 inch bar is associates with 1 ribbon fault. So if the bar was 3 inches in from the left of the screen, the faulty ribbon will be 3 inches in from the right working from behind the TV. If cleaning dont cure the fault, then the Buffer IC will be blown and order a new centre buffer board (you can buy off Ebay)
Feb 17, 2010 | LG 42PG20 42 in. Plasma HDTV
Picture narrowed in. black lines on sides
check and or replace the following :
q551
d830
d825
r818
repair must be done by qualified tv pesonnal
Jan 22, 2009 | Panasonic CT-32D12D 32" TV
Sony KV-32S66 Picture Rolling Up/Black Horizontal Lines
the problem there is a loose connection on the board,you said that you smacked the right side of the tv and it goes normal.there are parts that should be resolder on the board in order to back into normal operation.
Oct 22, 2008 | Sony KV-32S66 32" TV
I have a plasma tv need help
Sounds like panel is bad or driver ic is bad on the board directly below the black line. Good luck on the repair. Any questions, we can do a chat and go from there. GURU JAY
Mar 14, 2008 | Televison & Video
I have a samsung lcd tv model LE32R41BD, 2 thin blue lines have appeared roughly in the middle of the TV running top to bottom, they are more pronounced at the top, they look almost as if they have been...
you have maybe black lines in picture common on some LCD tv this could be pixel or bad board depending on what side the lines are closest too!
Mar 12, 2008 | Televison & Video
Toshiba 32AF43 32" TV Logo
77 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
