Question about Sony Ericsson P910i Smartphone
Phone Problem how do you replace just the glass on the touch screen of a Sony erricson P910 ? ,I realise that you can buy the whole touchscreen £50 and its a matter of unpluging the old one .But I want to just replace the Glass.(Is the glass Glued to touch pad?)
  • Anonymous Feb 29, 2008
    need a display glass for my sony ericsson p910a phone
  • Anonymous Mar 18, 2008
    I want to change my display glass for my sony erricsonp910i pl let me know how that cost?
I have a P910i problem in display i am not able to navigate the touch screen due to it is unable to sense the where i point, also keys are not working inaugural please let me know ....?
Posted on Oct 04, 2008
    Problem Solver:
  • 42 Answers
Iykeboy i have p910i,but my problem is this, it does not have button.how can i operate it.is it with touching screen or what.
gud pm...
yes u can use the touchscreen or use the toogle at the left side of your phone.u can press it down,up and inward depending on how u want to navigate your p910i...
Posted on Feb 25, 2008
I have p910i,but my problem is this, it does not have button.how can i operate it.is it with touching screen or what.
Posted on Feb 23, 2008
I have p910i.but it does not have buttem,how can i operate it
Broken glass on touch screen display for epson workforce 845
The touchscreen is sold as one part, you can't buy or replace just the glass. There is a capacitive layer glued to the glass that is probably damaged.
Feb 03, 2013 | Epson Office Equipment & Supplies
Can you get a pattern unlock for sony erricson vivaz pro
NO YOU CAN NOT GET A PATTERN LOCK FOR SONY ERRICSON VIVAZ PRO
Dec 31, 2011 | Sony Ericsson Vivaz Cell Phone
Touchscreen not working
Hi, My Aino light stays on and is using up all the battery why is this and how do I safe the battery from going flat?
Feb 02, 2011 | Sony Ericsson Aino Cell Phone
Hello, i have recently dropped my sony erricson xperia x10 phone and the glass screen has smashed. No actuall damage to the LCD screen as the phone works fine, i just have a cracked screen. I was just...
there are phone repair shops all over the place that can replace the glass quickly
the glass is fairly expensive but there are different qualities that increase the life of the glass on dropping
ask around , get quotes and consider having a person with experience do the job as it takes very little to break the phone full stop
Jan 30, 2018 | Sony Ericsson XPERIA X10 Cell Phone
I have a lg viewty touch screen phone, the touch screen doesnt work but i can still see the screen perfectly, do i buy a whole screen or just a lcd part??
You just need to buy a replace touchscreen. You can replace it. They run about 15 dollars from ebay and are pretty straight forward. Here is a link on how to replace the touchscreen on the Ku990.
How to replace touchscreen on LG Viewty KU990
Jun 15, 2009 | LG Prada KE850 Cellular Phone
SONY NV-U94T touch screen cracked
I have the same problem. I called Sony Support and a new Touchscreen digitizer (the touch-sensitive glass pane that sits on top of the LCD screen) costs about $76. That's just for the part. Haven't been able to find another solution. I took the liberty of taking my unit apart and taking out the shattered screen, now all I need is a replacement, but Sony's is too expensive for me. Maybe it will work for you though
Mar 28, 2009 | Sony NV-U94T Car GPS Receiver
My Sony erricson P910 dO not chARGE
this happend due to problem with IC of ur cell.
the same situation was happened with my p910.
Oct 17, 2008 | Sony Ericsson P910i Cellular Phone
Cannot read simcard
Either just switch off mobile than on or reload software........
Jul 11, 2008 | Sony Ericsson P910
Touchscreen
I would like to ask a couple questions that might be of some use.
First, does the same issue occur when using the phone with the flip closed? That is, can you use the jog dial and keys on the flip properly?
If the phone works fine with the keypad and jog dial, then you should be able to try to recalibrate the touchscreen.
To re-calibrate the screen:
1. Select Applications tab
2. Select Control Panel
3. Select Device
4. Select Display or Screen
5. Follow the instructions on the screen.
6. Select Yes or No
Second, if you turn the phone off and on again, with the flip open, does anything load by itself, or does the touchscreen react as if something is being pressed?
This may indicate that there is a problem with the hardware.
It is possible to purchase a new touchscreen for under $100 from a few parts retailers such as http://cnn.cn .
It may also simply be a glitch or bug in the software or firmware OS. In this case, you can try a master reset or updating the firmware using Sony Ericssons update service (not compatible with Vista for the P910), or you could use a third party firmware utility such as from DaVinci etc.
If you choose any of the master reset, firmware or update options, you will lose ALL user data on the phone, so you should back it up before you proceed.
Apr 01, 2008 | Sony Ericsson P910a Handheld
P910i touch screen problem
good pm...
yes it is possible sir...i have recently change mine because i have the same problem as you...they replace the flexible glass (touch pad) but that will depend on the servicing centers you will go to...i have no idea how much is the cost in your place sir...
goodluck...
Feb 18, 2008 | Sony Ericsson P910i Smartphone
Open Questions:
Sony Ericsson P910i Smartphone Logo
105 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
