Question about Lexmark Wheelwriter 5 Series II Typewriter
IBM Wheelwriter 5 (Setting the Margin back to 5"
I can not get the margin to go all the way to the left when I hit the return key. I try to reset the left margin, but it will only go to 45" line.
  • 1 more comment
  • smokeydai Jan 18, 2008
    Thank you. Problem solved once I moved the carrier back to the left by hand, then I was able to reset the l.margin.
  • jugge5 Jun 03, 2008
    Yes the carrage stops both left and right like the margin wowld be set. I can move the carrage by hand eighter way BUT FEELS LIKE IT NOT SMOOTH.Left or right it stops then it is hard to continue by hand i am worried that i may harm it by forcing it by hand PLEASE HELP Frank J Cali Patterson, La. judgefive@hotmail.com
  • Anonymous Mar 18, 2014
    Margin was set fine - now it shifted to the left and I need to get it back where I had it.
  • Lexmark Master
  • 3,594 Answers
Sounds like you don't know how to set l. margin or you have some debris in the typewriter. Turn it off and see if the carrier will move back and forth by hand, if so turn it on 7 return to l. margin press mar rel key, backspace to where you want the margin and press l. margin key.
hope this helps
DickyO
Posted on Jan 17, 2008
SOURCE:
Left margin stuck at center of page What to do besides reset margins? Can't back up to reset the left margin
You have to push the Mar Rel key then backspace to the new margin and press the Left Mar key
Jun 05, 2014 | IBM Wheelwriter 6 Typewriter
Change left margin on IBM wheelwriter 2000
To change the left margin, hit the return button which will take you to the left margin. Hit the margin release lever (mar rel) and then the backspace button to go farther to the left and stop where you want the margin to be. Hit left margin and that is where it will then be set.
May 09, 2014 | Lexmark Wheelwriter 3 Typewriter
After typing first line, hit the return key. The carriage would not return to the far left margin...it only moved 12 or so spaces to the left.
The carrier slides on a silver shaft that is about 1/2" thick spray some WD40 on the shaft, if that doesn't do it you have to get some on the carrier motor bearings located under the case in the R. rear corner.
DickyO
Feb 22, 2014 | IBM Wheelwriter 3 Series Ii Typewriter...
Return to tab
Don't confuse tabs and margins, after a return it always goes to left margin. Use the tab key to go from the left to the next place where you set a tab
Jan 30, 2014 | Nakajima AE-740 Typewriter
My ibm wheelwriter beeps 1 time when i tab
Does anything else work? It is possible your right margin is set to close to the left margin. Try tabbing all the way to the right, set the right margin, hit the return and then hit the tab. If it beeps and goes all the way to the right, try setting some tab stops and retry the test.
Jan 06, 2014 | IBM Office Equipment & Supplies
Occasionally, I still have to use a typewriter for some forms. I inherited a Xerox 6015 Memorywriter but I have no manual. Is there one online that I can download? Specifically, I'm trying to figure...
hit the carriage return key to put carriage at left margin. then hit your margin release key, then backspace key to put your carriage where you want it. then hit left margin key and that should set new left margin. good luck.
razors
Jun 06, 2011 | Office Equipment & Supplies
The left margin is stuck and the release margin works only the first time after turning on the typwriter. I can set the margin at a point on the left side, but after a few times of hitting the return key,...
Put a shot of WD40 on both sides of the silver shaft that the carroer slides on. If that doesn't do it put some on the carier motor bearings. The front one can be reached from inside of the T/W the rear one yuo will have to remove the case of fish the straw thru it. The motor is located on the R. rear corner.
DickyO
Apr 05, 2011 | Lexmark Wheelwriter 1500 Typewriter
How to set margins
after hitting the return key, the carrier goes all the way to the left margin. If you need the margin to move even more to the left, hit the margin rel key and backspace to the desired position and hit the mar left key. Same for the right margin, use the space bar to move the carrier all the way to the right margin and press the margin rel and move the carrier to the desired position and press the mar right key.
Jan 27, 2010 | Royal Satellite 40 Typewriter
How do you clear a tab someone preset. when I get to the far right of page and hit return it will on return to a tab. How do I clear all the preset margins or tabs.?? thanks
To clear margins, you have to hit the return button to find the left margin, then hit margin release and back space to move the margin left or spacebar to move to the right, then hit left margin button to set the new position. Right margin now. Hold spacebar down and find right margin position, hit margin rease and either spacebar to the right or backspace to the left to the new margin position then hit right margin button to set the new position. Tabs now. hit the tab key, when it goes to the first set tab, hit the tab clear key, then hit the tab key again, then tab clear again etc.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Dec 29, 2009 | Swintec 7040 Typewriter
Can't get the left margin to change, it is stuck way over on the right side and when I hit return it goes to about the center of the typewriter
On carriage return the machine locates LH margin. In your case the LH margin is set in centre.
Press the margin release key when at the margin location position.
Use the backspace key to return to the extreme left.
Space forward to were you want the new margin.
Press Margin Left set.
Alan
Nov 04, 2009 | Swintec 7040 Typewriter
Lexmark Wheelwriter 5 Series II Typewriter Logo
395 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
