Question about Canon NP 6545 Copier
E001 Machine won't continue to warm up. Says turn power switch on and off. I have tried several times. Still getting error message E001. What needs to be done.
    President:
  • 2,072 Answers
That is a fuser realted issue. Not warming up properly.
Most likely a defective fuser. The over heat has opened, the heat element has gone bad.
Fuser more then likely needs replaced
Posted on Jan 16, 2008
Ir 3300 000001-0002 error
Title : E001 Error Code That is Not Resetable Error : paper jam
When the machine powers up the E001 error code is displayed but cannot be reset. (Note: The reset procedure for an E001 code is COPIER>FUNCTION>CLEAR>ERR)
Workaround :
In this case, the Main Power Supply PCB Assembly was replaced. The machine was powered up and the E001 code was able to be reset. The part number for the Main Power Supply Assembly is FM2-0260-000.
Remember, if the fixing unit circuitry has an open or a short, the code may not reset. Be sure to confirm the fixing unit wiring and try resetting the code before replacing the Main Power Supply Assembly. Canon USA, Inc. Systems & Technical Support Division1-800-528-2830
Aug 13, 2013 | Canon Office Equipment & Supplies
Fax automaticaly daling #365 etc like tha number how can reset my MFC 7450 printer
Found this here...
(For MFC-7420)
When you turn off the MFC's power switch its memory will be cleared. To check
whether the MFC has faxes in its memory see Checking if the MFC has faxes in
its memory on page 11-5. If there are faxes you need to save them before following
the suggestions below (See Transferring faxes to your PC on page 11-5 or
Forwarding faxes to another fax machine on page 11-5).
Turn off the MFC's power switch and then turn it on again. If the error message
continues, leave the MFC for several minutes and try it again.
Check the settings in your application software to make sure it is set up to work
with your MFC.
(For MFC-7820N)
continues leave the MFC for several minutes and then try it again. (The MFC can
be turned off for up to 4 days without losing faxes stored in the memory.)
Looking through this manual, this is the only solution that I could find. There are options on the 7820N model in the menus that will allow you to reset the printer itself, and i quick search through the above link for "printer reset" should bring you to the menu selections for that.
Jun 29, 2011 | Brother MFC 7420 All-In-One Laser Printer
E00001-002 Error cod?
Thanks for using Fixya.
E001 is an Overheating detection error.
E001-002 - The sub thermistor detects about 295 degrees celsius or higher. You would have got E001-000 for a temperature above 250 degrees.
Go into service mode, go to COPIER > FUNCTION > CLEAR > ERR.
Select ERR to highlight, and press OK key.
Turn off the copier using the main power switch (on the right side of copier).
Wait at least 10 seconds and then turn the copier back on using the main power switch.
If the error is still there then you will need to take your printer to a canon service center.
Good luck and have a nice day.
Nov 08, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Canon IR600-550-60. Error code E001.
550 just gave an error code E060, what do I do?
Nov 09, 2009 | Canon imageRUNNER 600 Printer
E001 switch off the machine and on again
E001 is a fixing assy fault you have to clear the error in service mode after correcting the fault of course. I would try clearing the error code in service mode 1st. press *28* function tab clear tab error ok then restart copier
Sep 09, 2009 | Canon imageRUNNER 400S Copier
ERROR E001 & E004 PCR-T470
Hi.
You have performed the flag clear incorrectly and now the machine is trying to do an entire RAM clear. You may have already lost everything. Make sure you do not type any numbers while it is like this.
Try this:
Turn key to PROGRAM mode.
Turn power off at wall.
Hold FEED down.
Turn power on at wall.
When you see '0.00' on display, let go of RECEIPT FEED.
Press SUBTOTAL
Jan 21, 2009 | Casio Parts Cash Register PC Desktop
Falla cannon
This is a reprint from another tech, he was right on with this...
okay lets shed some light on the E000 error code on the D680, D880, IR1300 family ( including the 1310,1330,1370,1630,1670)
The error code E00 is a memory threshold error what it means is your machine has logged 4 of the following errors, E001,E002, or E003. It is a lockout error and the machine cannot be used until the problem has been repaired or the errors cleared. First lets look at the errors:
E001 fuser over temp means the fixing assy has exceeded the manufactures maximum temp limits
E002 fuser temp dropout means the fixing assy has cooled below a set point during a copy session
E003 fuser no response means the fixing assy didn't even attempt to warm up at power on
How to fix, most common problem is bad power setting 4 E002's either brown outs of brief power failures.
To clear the error, Enter service mode by pressing additional functions then the # button, use the left or right arrow buttons to scroll to #7 printer press set. again use the arrow buttons to scroll to #4 printer reset press set. press the appropriate arrow key under the YES to clear the error. unplug the copier and reboot. At this time normal function should return if not and it resets a E00 the you can assume either the fixing assy is bad or either the power supply PCB or DC controller is bad and it is getting E001,E003 errors. At that point id call a qualified tech to research the problem to avoid spending money on excess parts
Hope that helps...
Lbcoaster
Jul 11, 2008 | Canon ImageClass D880 Copier
System Error E000
The error code E00 is a memory threshold error what it means is your machine has logged 4 of the following errors, E001,E002, or E003. It is a lockout error and the machine cannot be used untill the problem has been repaired or the errors cleared. First lets look at the errors:
E001 fuser overtemp means the fixing assy has exceeded the manufacures maximun temp limits
E003 fuser no responce means the fixing assy didnt even attempt to warm up at power on
To clear the error, Enter service mode by pressing additional functions then the # button, use the left or right arrow buttons to scroll to #7 printer press set. again use the arow buttons to scroll to #4 printer reset press set.press the approprite arrow key under the YES to clear the error. unplg the copier and reboot. At this time normal function should return if not and it resets a E00 the nyou can assume either the fixing asy is bad or either the power supply PCB or DC controller is bad and it is getting E001,E003 errors. At that point id call a qualified tech to reserch the problem to avoid spending money on excess parts
Jun 05, 2008 | Office Equipment & Supplies
Canon IR 1600 error message
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET." Power the unit off/on.
May 17, 2008 | Canon imageRUNNER 1600 Laser Printer
Canon NP 6545 Copier Logo
215 people viewed this question
old marine
old marine
