Question about Samsung VR8060 VCR
"Lock" is displayed on the screen
I think something laid on my remote and consequently my
VCR says "LOCK" on the display screen. I have unplugged and it
does no good. None of the buttons on the VCR OR the remote will work.,
Any suggstions?
thank you
leigh
The same thing just happened to mine... I'll let you know if I figure out how to fix it.
Posted on Jan 24, 2008
6ya staff
SOURCE:
Tip
Mitsubishi parental lock removal/v-lock redo
Models:
Color Televisions
CS-20EX1, CS-20301, CS-26EX1, CS-26201, CS-26301, CS-2725R, CS-27EX1,
CS-27MX1, CS-27TX1, CS-27200, CS-27201, CS-27301, CK-27304, CK-27306,
CS-27401, CS-27403, CS-3135R, CK-3136R, CS-31AX1, CS-31FX1, CS-31MX1,
CK-31MX2, CS-31301, CK-31302, CS-3525R, CK-3526R, CK-3527R, CS-3535R,
CK-3536R, CS-35X7, CS-35AX1, CS-35FX1, CK-35FX2, CS-35MX1, CK-35MX2,
CK-35MX3, CS-35201, CS-35201A, CS-35203, CS-35205A, CS-35301, CS-35401,
CK-35402, CS-40FX1
Projection Televisions
VS-40VA2, VS-4517S, VS-45VA1, VS-45VA2, VS-4561, VS-4562, VS-5016R,
VS-5017S, VS-50VA1, VS-50VA2, VS-50VF1, VS-50VF2, VS-50VX2, VS-50VX3,
VS-5061, VS-5062, VS-6017R, VS-6026R, VS-60VA2, VS-60VF1, VS-60VF2,
VS-60VX2, VS-60VX3, VS-6061, VS-7017R
This system locks only the entire TV. The TV will display a screen that
will indicate "Parental Lock ... Now the lock is on" and request the
personal four digit code when the TV is powered on.
IMPORTANT> You must use the original remote control that came with the
TV to release the Parental Lock, you cannot use a remote
that came with a VCR, Audio System or from any other
manufacturer.
1. Depending on which remote came with your TV, press the button at
the top labeled TV,OR set the TV/VCR switch in the upper left
corner of the remote to the TV position. .
2. Press the button on the remote labeled POWER.
The TV will turn on and display an information
screen that indicates "Parental Lock ... Now the
lock is on" and ask for the four digit personal code.
3. Press the #9 and the QV buttons at the same time.
The TV will turn on.
4. Press the button labeled MENU.
The "TV Main Menu" will be displayed.
5. Press the ADJUST UP or DOWN button to move the arrow next to the
"Advanced Features" selection and then press ENTER.
The "Advanced Features" menu will appear and
indicate that the lock is ON.
6. Press the ADJUST button to move the arrow next to the "Parental
Lock" option, and then press ENTER.
The screen will change to indicate "Parental Lock
... Now the lock is on" and ask for the four digit
personal code.
7. Press the #9 and QV buttons at the same time.
The screen will return to the "Advanced Features"
menu and indicate that the lock is off.
8. Press the MENU button twice to return to normal viewing.
The original lock code has now been erased and the lock canceled.
on May 16, 2010 | Audio Players & Recorders
What is the pin code for Aiwa HVFX5500 vcr
hi ,
Try...
Power on,
Press both CH/UP key and REC/OTR key for more than 2 seconds,
OK will appear in the display panel.
or try
Press CH DOWN key on VCR while pressing the 7 key on remote and hold for more than 5 seconds.
The display should then show OK.
but First disable the child lock by pressing the "lock" button on the remote,
and only then press "Ch-" and "7".
Oct 02, 2014 | Televison & Video
RCA VR678HF display reads, "LOCK." Nothing will work!
Held down on-off button on remote control for 10 seconds.
Dec 05, 2008 | JVC HR-S9400 S-VHS VCR
Aiwa GX1100 VCR
When safe show on the screen, it actually means that the child lock feature is on.
All you have to do is press the child lock button again on the remote and it should flash "OFF" on the screen.
Hope you have the remote :)
Sep 13, 2008 | Aiwa Televison & Video
Recieving "Locked" display message but don't know how to clear it. No reset switch or panel lock button
I have the manual and it is called "child lock" go figure it stumps us adults. Anyway...holding the power button down for approx. 8 seconds can toggle this feature on / off
Jun 18, 2008 | Apex Digital ADV3800 DVD Player/VCR
Daewoo DV6T811N DVD Locked
Your Child Lock has been turned on.
Press the power button of the remote for about 8
seconds. No buttons of front panel and remote can be
operated now and Lock indicator (“LOCK”) will be
displayed on window display.
To release child lock,
press the power button of the remote control for
about 8 seconds.
Good Luck.
Apr 08, 2008 | Televison & Video
Sanyo DVD RECORDER displaying "SAFE"
the "LOCK" feature disables the front panel buttons. Press "LOCK" on the remote control to LOCK/ULOCK.
Jan 18, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Mitsubishi HS-U447 VCR in Lock or "Loc" mode
Hopefully you still the VCR. Your's is stuck in "CHILDLOCK" mode. To release the lock you have to have the remote and press the DISPLAY for 8 to 10 seconds.
The purpose of the CHILDLOCK is to prevent others from using your VCR. If you want to set the VCR back on Lock you again press the DISPLAY for 8 to 10 seconds.
This solution is from the owner manual for HS-U448, so I figure your model is the same.
Mar 06, 2007 | Mitsubishi HS-U447 VHS VCR
Samsung VR8060 VCR Logo
67 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
