Question about RCA F32648 32" TV
Rca tv modle f32648
When my tv is on there are two black bars on the left and right sides. I heard it was the HD but i dont have HD and switching the closed capt. didnt work
  • Jaime Hernandez May 11, 2010
    Could you please tell me what is the chassis number?
    Champion:
  • 453 Answers
U have to do the picture side on the cable box , (if u using ) strecht
Posted on May 02, 2008
6ya staff
SOURCE:
Trying to install onn 37" wireless 2.0 Channel Soundbar to Emerson tv modle LF401EM5. Multiple problems!
The onn cannot be connected to the Emerson wirelessly.
If it is connected to the Emerson TV, there has to be a wire plugged in to the audio output on the TV and the left and right input connectors on the sound bar. I have heard that you will only get about as much sound from the sound bar as the TV.
You cannot use the digital audio outputs.
Sep 11, 2018 | Emerson Televison & Video
Plano RCA F32648 32
What is the problem with your rCA TV? Please provide some more details.
Apr 27, 2012 | RCA F32648 32" TV
Went black and white rca f32648
so far no proper details are available regarding resetting this particular TV ( f32648 ) .... i have checked user manual also
have you tried following things
1 - playing different dvds (dvd player )
2 - changing different channels ( cable tv or antenna )
3 - increasing ( to maximum ) & decreasing ( to minimum ) [in menu ]
contrast colour tint black level sharpness
picture presets auto colur colour warmth
4 - auto channel searching ( cable tv or antenna )
even after these trials if picture is in black & white then it is a hardware problem - since it is a rare problem no details are available about which component might have got deffective ...... only the service engineer who opens & checks your tv can tell the exact deffective component .......... sometimes it can be loose connection ( cracks at soldering joints - hit your TV lightly with your hand on left side or right side or on top - if color comes & goes then it is loose connection problem - all soldering joints should be resoldered by service engineer ) ..... or an IC might have got deffective ......... only after opening & checking your tv mainboard exact deffective component can be identified ......
for nearest RCA service center call 1800 336 1900 ( this number got from your TV's user manual - click this link for your TV's user manual - free down load - RCA F32648 model - http://download.rca.com/FilesForRCAcom/Manuals/15491880.pdf
Nov 06, 2011 | RCA F32648 32" TV
Black bar on the top and bottom during watching the tv
Hello
If you are watching television and you see black lines on the left and right sides of the screen, check to see if you are watching an HD broadcast or a standard definition broadcast. You can do this by bringing up the TV guide menu on your remote. If the show is in HD, it should take up the full screen. However, if it is not HD, bars will be present on the left and right of the screen. That is because standard definition programing is in 4x3, which will not take up the entire screen.
If the picture you are watching not only has black bars on the sides, but on the tops and bottoms of the screen as well, your "Zoom" mode has somehow gotten off-kilter. Press the "Zoom" button on the remote until the image appears correct. If this does not work, power down the television, wait a few moments, and power the TV back on. The image should be correct now.
If the image on the screen looks stretched or squished, this is because your HD cable receiver is not set up properly for your widescreen television. Press the "Menu" button on the receiver
May 06, 2011 | Samsung 50 in. Plasma TV
Need to find code for RCA universal remote, Westinghouse TV
Go to
http://rcaaudiovideo.com/
On the left side select 'remotes' and then your remote type. You will be able to download the manual and codes for your RCA Remote Control.
Let me know if you have any other questions. Please rate this solution. Thanks.
Mar 09, 2011 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
Find a horizontal output transistor or flyback
Flyback transformer part number for a tv RCA F32648
Mar 06, 2010 | RCA F32648 32" TV
Remote doesn't work rca model #F32648,i can't access the input function. The onscreen menu doesn't show it or I cannot find it. Problem is without it I can not use the DVD player.
This isn't a solution but I am unable to acccess the input either. My tv is hooked to a dvd,vcr and direct tv satellite with a dvr. I watched a movie on the dvd and the tv won;t allow me to switch the input back to satellite tv.
Apr 10, 2009 | RCA F32648 32" TV
RCA Mod#F32648 volume stuck in High position how
possibe dirty switch. Pull the back of the TV off and unclip the panel that has the switches in it. Spray contact cleaner into the switch while pressing repeatedly. Common problem with these TVs. will take about 10 minutes...good luck
Apr 05, 2009 | RCA F32648 32" TV
RCA F32648
if it is a universal remote control , u need to reprogramer
May 02, 2008 | RCA F32648 32" TV
TV Tuner
http://www.partstore.com/Part/Thomson/RCA/248782/New.aspx?ModelMfgName=Thomson&ModelBrandName=RCA&ModelNumber=F32648YX59
Apr 06, 2008 | RCA F32648 32" TV
RCA F32648 32" TV Logo
62 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
