Question about Toshiba W512 VHS VCR
Counter display will not go away
Counter display button used to toggle this on and off. No longer does. how can I make this disappear
  • 579 Answers
The time-honored classic solution is a piece of black electrical tape!
Actually, try reseting the display processor by either unplugging it or some VCR's have a little tiny hole somewhere you put something like a toothpick into to push a button.
Posted on Jan 18, 2008
Hp laptop no longer connects to external display via fn + f4
The Fn+F4 button toggles between the LCD and external monitor.
From LCD only or both LCD and external monitor or external monitor.
only. Press the Fn+F4 keys again to toggle the various screen selections.
Sep 16, 2012 | Computers & Internet
I have a Clock an OEM #7132. Black with see through body. It has a temp area, but mine is stuck in Celsius and i want Fahrenheit
Be aware that there are several different versions of this clock model all made for Sharper Image. For my OEM 7132 clock, I press the "mode" button until the clock display disappears and only the month, date, and temperature are displayed. Then I press the "minute" button, which toggles between the Celsius and Fahrenheit displays. When I am done, I press the "mode" button again to display the clock.
Sep 06, 2011 | Audio Players & Recorders
I can't get the time to stay displayed on the screen. I hit the menu button, then the TmDay button, then exit, but both the time and date disappear. I want the time to stay displayed.
Its on a toggle switch. So hit menu, select time and day, do not hit exit, wait.
If it goes away, you just shut it off do this again, and it should stay on.
Sep 06, 2011 | Avaya Definity 8434DX Corded Phone
How to set the clock of sigma bc 1009 sts
hold the left bottom button untill the blinking caption "settings/ open" disappears. Then there are some options: language, distance counter, wheel size and clock. Swich between them with right bottom button, and when clock appears push the left bottom and change hour with top buttons, swich to minutes with the right bottom and finish by pushing the left bottom button. Then hold it longer to exit settings. Done. Damn, I could find no online manual and had to discover that myself.
Nov 01, 2010 | Cycling
Hi i have just had my car Renault Clio on a 06
- By dancer23 on Feb 18, 2010 -
Earlier i posted a question requesting how to switch off the service light on my Renault Clio, i have found an answer to thios, as follows.
How do you reset the service indicator light 2007 renault clio?
Turn on the ignition, but don't start the car. On the right stalk there is a toggle switch that hinges up and down, and is used for going through the different features of the display. When the display shows 'Service Due' press and hold the top part of this switch for 10 seconds until the dispaly resets and it shows 30,000km or whatever until next service.
all of the above is correct apart from pressing the toggle button. if you instead press the bottom toggle button for 10 seconds the display will start to flash. Keep button depressed and 5 seconds later the service counter will reset.
I know this works as i have just done it myself,
I hope this will help many others .
Feb 18, 2010 | 2006 Renault 181
Set the clock on a clarion cd player?
Setting the Clock
1) Press and hold in the BAND button [4] then press the DISP button [9] to toggle the display to the clock mode.
2) Press and hold in the BAND button [4] then press and hold in the DISP button [9] for at least 2 seconds.
3) Select left or right to adjust the time using the a-selector
~Adjusting minutes
Each time you select right >> using the a-selector [3], the minutes increment up by one digit (0 to 59).
~Adjusting hours
Each time you select left << using the a-selector [3], the hours increment up by one digit (1 to 12).
*The clock only displays time in a 12-hour format.
There is no way to toggle the clock to a 24-hour format.
4) Press the BAND button [4] to set the clock into memory. This also resets the seconds counter to zero.
*The clock can only be set by turning power on to the unit and switching to the clock display mode. You cannot set the clock when it is displayed with only the igntion on. If you drain or remove the car's battery, the clock must be reset. While setting the clock, if another button or operation is selected, the clock set mode is canceled.
Dec 08, 2009 | Alpine Car Audio & Video
Can no longer calibrate my cintiq pen
i found a button that switches the pens location, it says display toggle in the wacom properties, idk when i click it it switches back to the right position try pressing all your buttons or put your settings to default and try the buttons
Nov 15, 2009 | Wacom Cintiq 21UX (CINTIQ21UXNR)
Minolta dynax 5 camera, diplay has disappeared
does this model have the eye viewer also? if so check and make sure the switch is toggled to displayed and not for the eye viewer. look into the eye viewer and you should see your display. it is simple switch to toggle it to the display mode.
Apr 10, 2009 | Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
Hood fan works but displays the letter "C" ?
wow! finally the solution that works! Holding the '+' sign for 4 seconds. We had our vent replaced by kitchenaid once and were about to call again and complain since our new one did just the same thing without resolution using the 'H' button as indicated in the manual! Thanks for help it's so appreciated!
Feb 22, 2009 | KitchenAid KWCU205HSS Kitchen Hood
Toshiba W512 VHS VCR Logo
507 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
