Question about Panasonic Panafax UF-9000 All-In-One Laser Printer
Network printing I setup this printer using standard TCP/IP port and used LPR for the protocol on my server and still cannot print over the network. I can ping the printer, but am unsuccessful rpinting a test page from the server. Is there any way to open a web console on this printer. Does it use HTTP?
  • Anonymous Mar 10, 2008
    I am setting up the printer as part of a printer server. I can ping the printer, but no prints get to it. It does clear the print job, but never shows up at the printer. Also USB printing has the same problem.
    Sergeant:
  • 284 Answers
Do you have the driver from workio.com
do you have the ip, subnet mask, gateway all installed properly,
try a cross over cable to test the parameters are working if still more issuses re-post same thread
Posted on Oct 01, 2008
Windows 7 cannot find my hawking pn7127 print server. All my xp computers print to it no problem , My port is http://192.168.1.5/lp1. Even when I input this info, Windows 7 cannot communicate with the...
1. Click "Add a printer".
2. Click "Add a network printer".
3. Click "The printer that I want isn't listed".
4. Select "Add a printer using TCP/IP". Click "Next".
5. Type in the print server's IP address. Click "Next".
6. Select "Custom". Click "Settings".
7. Change Protocol to "LPR". In LPR Settings, type in "lp1". Click "OK".
8. Click "Next". Select your printer. If your printer isn't listed, click "Windows Update". If still not listed, install driver from manufacturer's website.
9. Print a test page!
Mar 10, 2010 | Hawking 10/100M Internet Print Server...
Tip
Configuring NETGEAR print server PS121 printer port settings manually.
If you can not run the installation software for the print server PS121 on the computer then you can try the below steps to manually configure the printer port settings:
Step 1:-
1. Visit the link below to make sure that the printer is in compatibility list:
http://kbserver.NETGEAR.com/kb_web_files/n101216.asp
2. Make sure that the printer is working in direct connection with the computer.
Step 2:-
1. Now connect the printer to the USB port of the printserver and then the Ethernet cable from the router to the Printserver Ethernet port.
2. Press the DIAGNOSTIC tool button on the printserver for 10 sec (All the lights will blink amber), you will receive a print page with Port name,Ip address of the printer and other details.
3. The ip address will be given from the router. If there is no ip address then powercycle the router, printserver and the printer. Press the diagnostic tool button again.
Configure printer port settings on XP computer:
1. Go to control panel then go to printer and faxes.
2. Right click on the printer icon go to properties.
3. Click on the ports tab on the top.
4. Click on add port.
5. Select standard TCP/IP port and click on new port.
6. Press next.
7. Enter the IP address of the print server it will show you the port (IP_ip address).
8. Press next.
9. Select the second option custom and click on settings button.
10. Select the protocol as LPR; enter the queue name as q1.
11. Select LPR byte counting enable.
12. Click on ok and press next then click on finish.
Configure printer port settings on VISTA computer:
1. Please confirm you are able to print by connecting the printer to the Vista computer directly.
2. Click Start - select Control Panel then switch it to Classic View from left side.
3. Double click on Printers & Click on 'Add a Printer'.
4. Select 'Add a local printer' & Click next.
5. Select 'Create a new port'.
6. Select 'Standard TCP/IP Port' as 'Type of port' then click 'Next'
7. Enter the IP Address of the Print Server in the 'Hostname or IP address' field.
8. Uncheck 'Query the printer and automatically select the driver to use' & Cilck next.
9. Select 'Custom' then Click on 'Settings' on the next dialogue box.
10. On the next dialogue box, select 'LPR' as the 'Protocol'.
11. Under the LPR Settings put in any name for the 'Queue Name'.
12. Check 'LPR Byte Counting Enabled' then click on OK and next.
13. Select the Manufacturer and the Model Number of the printer. If it is not available then click on 'Have Disk'. Click 'Next'.
14. Check 'Set as the default printer' and click next.
15. Try to print test page, it'll print.
These steps will help manually configure the printer port settings on the computer.
on Feb 10, 2010 | NetGear PS121 Print Server
My print server is working with a Epson DX4400. It is all setup correctly (according to Netgear) but when I print wirelessly, it only prints half the test page and then the printer stops with an error...
U need to manually add the Printer ports ..
Install the printer driver to the computer first and make sure that we are able to print directly. Follow the steps below after putting the printer and computer back to your network.
  1. Click on Start, then Control Panel, then Printers and Faxes. Right click on the Printer and select Properties.
  2. On the printer properties window, select Ports tab and click on Add Port.
  3. Select Standard TCP/IP Port and click on New Port
  4. This will bring the Add Standard TCP/IP Printer Port Wizard, click Next
  5. In the field for Printer Name or IP Address, type the IP address of the print server and click Next
  6. Select Custom and click Settings button
  7. Under Protocol field, select LPR. For Queue Name, type P1 depending on what print server port is the printer connected to.
  8. Click Ok, then Next, and Finish.
And this will resolve the issue
Feb 06, 2010 | NetGear WGPS606 (WGPS606NAR) Print Server
Kyocera will not print without kprint port
The KM-1650 will print useing a standard TCP/IP port printing over the network, I have done it ever since the machine came out. Load the print driver as a local printer and then setup a TCP/IP port and set the printer to print to that port in the printer properties.
Let me know if yo need more help.
Jan 15, 2010 | Kyocera Copystar Printing Systems -...
Vista 64-bit driver or windows 7-64 bit driver
Please note that PS121 does not require drives for its configuration. It can be configured manully using a browser:
Step 1:-
1.Connect the PS121 to the router & check the lights
2.Press the diag button with a paper clip, it should give a print out which should include a IP address (make a note of the IP address)
3.Open the browser & enter the IP address on the address bar, it should give you a prompt for a Username & password (Username = admin; password = password), this will show if PS is communicating with the network.
4. Make sure that all the firewalls are disabled (including windows firewall)
Step 2:- (For XP)
6. Press next.
8. Press next.
Step 3:- (For Vista Computer):
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Nov 09, 2009 | NetGear PS121 Print Server
Print server was turned on today and doesn't recognize printer. It has worked witout a problem for over a year when we switched to a newer print server program
HI, Follow the steps below to reconfigure the print server:
1. Now connect the printer to the USB port of the printserver and then the ethernet cable from the router to the Printserver ethernet port.
2. Press the diagonistic tool button on the printserver for 10 sec (All the lights will blink amber), you will recieve a print page with Port name,Ip address of the printer and other details.
3. The ip address will be given from the router,If no ip address, powercycle the router, printserver and the printer. Press the diagonistic tool button again.
Step 2:- (For XP)
6. Press next.
8. Press next.
Regards
Anand
Sep 23, 2009 | NetGear PS121 Print Server
I have a netgear wgps606 wireless print server. I
Manual Configuration of WGPS606 Print Server
Note: Before configuring the printer server please check if you printer is compatible. You may open this link to you web browser: http://kbserver.netgear.com/kb_web_files/N101216.asp.
1. Please make sure that the printer works when connected directly to the computer.
2. Confirm the wireless settings of your router. You should have the SSID, wireless security and IP address of the router.
For NETGEAR routers please follow these instructions to check the wireless settings:
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
d. Click on Wireless Settings under Setup tab and you may get the wireless settings on that page.
e. On the left side under Advance setup, click on the LAN IP setup and locate the LAN TCP/IP Setup. Underneath that is the IP address of the router.
Note: If your IP address is 192.168.1.1, then you may use 192.168.1.200 for your print server.
3. Please connect a computer to the print server. At this time, the router is not connected. The printer should be connected to USB1. The power, LAN port and LPT1 should be lit.
4. Assign static IP address to the computer.
a. Click on Start and right click on Control Panel.
b. When the Control Panel window opens, double click Network Connections.
c. Right click on Local Area Connection, then click Properties. When the Local Area Connection Properties window appears, click Internet Protocol (TCP/IP) then hit Properties button.
d. Change the option from Obtain an IP address automatically to Use the Following IP Address and enter the following:
IP: 192.168.0.50
Subnet Mask: 255.255.255.0
Note: Leave the default gateway and DNS addresses blank.
f. Click on OK and then Close. Exit out of all the Windows.
5. Ping the print server.
a. Click on Start and then Run. Type cmd and hit OK.
b. On the DOS prompt, type ping 192.168.0.102. This should give four responses.
c. If it gives request timed out or destination net unreachable, please turn off both print server and computer. Wait for few minutes, then turn it on again. You can also try holding the reset of the device. Then repeat steb 5.b.
6. If you are able to get replies, you may now open Internet Explorer and type 192.168.0.102 on the address field.
7. After hitting go or enter on the address field, it will ask for a login. (Please type in admin for Username and password for Password).
8. Click on Wireless Settings under Setup tab and we need to set the same SSID as your router.
9. Please also select the appropriate Wireless Security and type the network key or wireless password from the router. Then click on Apply to save the settings.
10. When you get back to the page, click Print Server settings.
11. Check Change to and set the following:
IP address: 192.168.1.200 (It should be on the same range as the router. e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router). This will be the print server's IP address.
IP mask: 255.255.255.0
12. Click Apply to save the settings. We will get a Page cannot be displayed.
13. Set the IP address of the computer back to dynamic.
For Windows 2000 and XP:
a. Please click on Start, select Settings and then Control Panel.
b. Double click on the Network Connections icon.
c. Right click on Local Area Connection and click on Properties.
d. Scroll down to Internet Protocol (TCP/IP) and click on Properties.
e. Select the option Obtain an IP address automatically and Obtain DNS server automatically.
f. Then click on OK.
For Windows 98 and ME:
a. Please click on Start, then Settings, and then Control Panel.
b. Double-click Network then select TCP/IP for the Ethernet adapter. Then click on Properties.
c. Go to IP address tab and select Obtain an IP address automatically.
d. Click on the Gateway tab and delete the numbers under the Installed Gateway.
e. Click the DNS Configuration tab, and then select Disable.
f. Click on OK. Windows will then prompt for a restart.
14. To set up a TCP/IP port to the computer, please follow these steps:
b. Double click on Printers and Faxes.
c. Right click the printer icon and go to Properties.
d. Click Port Tab and click Add Port.
e. Select Standard TCP/IP port. Hit OK or Next.
f. In the field for Printer Name or IP Address: enter the IP address of the Print Server and click on Next.
g. Select Custom and then click Settings.
h. Under Protocol select LPR, and for Queue Name, type L1 if printer is connected to the print server USB port 1 and L2 if the printer is connected to the 2nd port.
i. Click on OK, then Next, and Finish.
j. Lastly, please right click on your printer icon and select Use Printer Online. If this is not an option, disregard it.
15. Check if you can print through the print server.
16. If it is not printing, then please try to connect the print server to the router and check if you can print. If it can, then there might be a need to re-do the steps for wireless configuration of the printer server.
Mar 29, 2009 | NetGear WIRELESS PRINT SERVER 54MBPS...
PSC 2175 wont work with print server
Please make sure that the printer is working okay if directlysd connected to the MAC computer. You may try this as well. hope this helps
Description
LPR (line printer remote) is a platform independent printing protocol that is associate with TCP/IP. It works by using LPR client software that communicates to a server running LPR services.
In terms of PSU, LPR printing will become the basis for all network printing while Novell print queues are phased out. Therefore, all Macintosh, Windows, and Unix computers will be configured to print through LPR.
Requirements
· The name of LPR print queue. This can be found by searching the LPR printer database.
· LaserWriter print drivers version 8.5.1 or newer
· The Macintosh must have a working TCP/IP networking configuration. (If the Mac can browse the web then it's working.)
· a server running LPR services or a printer that supports LPR printing. Most HP LaserJet printers support LPR. However, only the following LaserWriters support LPR printing:
- LaserWriter 8500
- LaserWriter 16/600 PS
- LaserWriter 12/640 PS
- Color LaserWriter 12/600 PS
- Color LaserWriter 12/660 PS Procedure
1.Open up the Applications folder from the OS X menu.
2.Open up the Utilities folder
3.Now open up the Print Center
4.If you have no printers installed you will see the following screen. Click on Add.
5.On the following screen, select LPR printing.
6.Now enter printhost.oit.pdx.edu for the LPR Printer's address.
7.Uncheck Use Default Queue on Server option and enter the queue name of the printer.
8.Select the printer model.
9.The completed settings should be similar to the following:
(LPR Printer’s address is the ip of our PRINTSERVER)
10.Click on Add
11.Your printer has successfully been installed. Test the printer by printing something to it.
Mar 29, 2009 | HP PSC 2175 All-In-One InkJet Printer
Well you please tell me default IP address of LINKSYS Wireless-G Print Server
Installation of WPS54G Print Server
Using standard TCP/IP Procedure (Windows XP/2000)
  1. Make sure your printer already has its drivers installed on all PC's prior to attempting to install this print server.
  2. Be sure also that your printer can print when it is connected directly to your computer.
  3. Click on Start go to Printers and Faxes.
  4. Right click your printer and go to Properties.
  5. Click on the Ports Tab on the top.
  6. Click Add Port. Select Create a new port: and select the Type of port: Standard TCP/IP Port, click Next.
  7. This will bring the Add Standard TCP/IP Printer Port Wizard, click Next
  8. Inthe field for Printer Name or IP Address: enter the IP address of thePrint Server and click Next. (You can get the IP address of your printserver by pressing the reset button on your device for 3 seconds thenit will print out it's status).
  9. Select Custom, click Settings.
  10. Under Protocol select LPR, and for Queue Name: type L1. Click Ok, then Next, and Finish.
Youshould be able to print on the device afterwards. You can refer to yourRouter's Wireless Settings and match them on the WPS54G so that theywould be able to communicate wirelessly.
Jan 22, 2009 | Linksys Wireless-G WPS54GU2 Print Server
Netgear Print server
IP: 192.168.0.50
Dec 18, 2008 | NetGear WGPS606 (WGPS606NAR) Print Server
Panasonic Panafax UF-9000 All-In-One Laser Printer Logo
210 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
