Question about Sewing Machines
Presser foot Hi! And thanks for having a help line.. much appreciated. I have an issue with a kenmore 14. when the presser foot handle is in the down position, but presser foot doesn't reach the fabric by about 1/8 inch. How in the world is that possible?! *laughing* and where did i lose that sock?
I figured it out! Yay me! There is a very small hex screw on the side.. i just loosened it, scooted the rod down and tighetned it! Thanks so much for your help! Much appreciated!
Posted on Jan 15, 2008
I need instuctions on using different presser foot for ja nome schoolmate
Please add a comment with the specific model of Janome Schoolmate sewing machine.
Fpr the Janome Schoolmate S-3015, make sure that the needle is fully up and raise the presser foot. Then press the red button on the back of the presser foot holder to have that foot drop off. Set the pressure dial to 3 before attaching the new presser foot. For snap-on feet, align the pin of the presser foot (the horizontal bar in the middle of the foot) under the presser foot holder. Lower the presser foot holder (using the presser foot height lever) until it locks onto the foot.
For the zipper foot, you need to fit the rear pin on the foot into groove at the back of the presser foot holder. Then lower the presser foot holder onto the zipper foot.
These are shown on page 11 (14 of the PDF) of the manual. You can download the manual here: http://janome.com/en/machines/sewing/schoolmate-s-3015/ . The direct link to the manual is http://janome.com/siteassets/support/manuals/school-models/schoolmate3015.pdf .
For the S-7330, you need to again raise the needle and the presser foot. Press the lever towards (it moves slightly up, not down) the presser foot holder. Then line up the pin on the foot under the presser foot holder and lower the presser foot holder onto the foot so that it locks. This is also in that sewing machine's manual, here: http://janome.com/siteassets/support/manuals/school-models/inst-book-s-7330esf.pdf . See page 14 (18 of the PDF).
I hope this helps.
Dec 21, 2016 | Sewing Machines
Presser foot level on pfaff 1540 will not go down?
Hi Donna. The lube in your pressed bar had gone gummy. There is a spring inside the bar and it gets stuck. You will need to have a pfaff service tech clean and relube it. Could be included in a standard machine service.
Dec 22, 2015 | PfaFF Sewing Machines
Why won't my presser foot drop down?
There's a screw that connects the two together, it probably fell out
Aug 13, 2014 | Sewing Machines
Hello, I have a kenmore sewing machine model #385.19233 . It is not broken, what i need is someone who can tell me how to get this machine to do free motion sewing. I hope you can help me.
If your machine has an embroidery foot, this will allow you to free motion embroidery. The embroidery foot will be positioned close to the fabric but will not hold the fabric in place.The presser foot must be down so that you will have the correct tension. Once the foot is on, the presser foot lifter is in the down position, then it's up to you to guide the fabric under the machine in the pattern you want. I advise a regular straight stitch with about 6-8 stitches to the inch. Move the fabric at a medium speed under the foot. If you move too slowly the stitches will be too close. If you move too quickly you'll have HUGE skips in your stitches. The main thing to know is that you can't use a regular foot because it will hold the fabric in place, even if you lower the feed dogs. When I free motion, I use the embroidery foot and keep the feed dogs up just to give a little resistance but NOT to hold the fabric in place. I love doing the free motion and I hope this helps you get started. If it helps you, please come back and rate my advice. Thanks!
Aug 01, 2011 | Kenmore Sewing Machines
Bad stitching
Re thread the machine with the presser foot up and this will ensure the thread is properly seated into the tension control.
Use a 14 or 16 needle as they have a larger groove on the front of the needle to better control the thread.
Make sure the presser foot is down (it can happen).
May 11, 2010 | Kenmore 19110 Computerized Sewing Machine
My kenmore sewing machine needle is coming down on presser foot.
Check the needle to make sure it is inserted with the flat side of the shaft toward the back of the machine.
Also, check to be sure the needle is not bent.
Remove the presser foot and see if the needle clears the opening in the needle plate and pulls up the bobbin thread.
If all of the above checks out, switch to a presser foot with a wider opening.
If not, the machine needs to be serviced as it may be the timing has to be adjusted.
Whenever you pick up a machine that has been serviced, try it out before taking it home.
Mar 17, 2010 | Sewing Machines
The presser foot lifter of my Singer 9432 has disconnected
Had the same problem.
Open the cover where the light bulb is.
Follow the presser foot rod up into the machine.
You will find a metal keeper with a set screw facing the now open end of the machine.
That set screw has most likely come loose.
Since the presser foot is spring loaded to the down position leave the presser foot raising lever in the down position.
With your flat bladed screwdriver, gently push the metal keeper to it's lowest position. If it does not go easy, loosen the metal keeper set screw a bit. Lefty loosey.
Tighten the set screw on the metal keeper. Righty tighty.
Dec 31, 2009 | Singer Sewing Machines
Can't lift handle for my foot presser
Take the machine apart to the point where you can see the pivot point for the presser bar lifter and spray WD40. Let sit for a few hours and try again. Repeat until the presser bar lifter releases.
Sewing Machine Parts
May 18, 2009 | Kenmore 15208 Mechanical Sewing Machine
The foot on my Kenmore sewing machine model 15516 was removed and I cant get it back on.
If it is a snap on foot, just line up the bar with the "hook" on the shank and drop the presser foot lever into the down position, it should snap back into place.
Jan 03, 2009 | Kenmore 15516 Mechanical Sewing Machine
How to connect the walking foot for ls-2125i? I have removed the snap on presser foot. Unscrewed the leg so I could screw on the foot. The white piece to the right does not fit on my screw so it just...
Turn power switch to "0"
raise the needle to highest position by turning the wheel toward you(counterclockwise) and raise the presser foot lever
release the foot by raising the lever located at the back of the presser foot assembly
place a different presser foot on the needle plate so that the bar on the presser foot is in line with the slot on the shank
lower the presser foot lever and fix the presser foot onto the shank. If the p foot is in the correct location the bar will snap in you should hear a click or snapping sound let me know if this helped thanks! amy
Jun 24, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
81 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
