Question about Microwave Ovens
Changing light blub of oster microve oven
I have an oster microwave oven with grill, I need to change the light blub.
The lamp is located under the stainless top cover of the microwave which unscrews from the back and sides, the bottom corners in the back have special torx screws which are meant to thwart you from removing them but a pair of locking pliers does the trick. Then under the cover on the top of the microwave there's a black elliptical shaped base with only 1 screw holding it down, that is the lamp. Pull the female spade connectors from the lamp, unscrew it and take it out. Oster has about the worst customer service around so i have not verified that they will sell a replacement lamp but if you can find a 20W 120V replacement with spade connectors that will do.
Posted on Feb 14, 2009
How set clock on oyster microwave and grill?
Oster Microwave Oven Operating Instructions
  1. Press the "Clock" button once, then the correct number buttons to set the desired 12-hour time. ...
  2. Press "Timer" to set the timer function. ...
  3. Press the number pads to select a cooking time. ...
  4. Press "Defrost by Weight" to defrost a food item by the weight of the item. ...
  5. Select "Speed Defrost" to defrost food quickly.
More items...
Oster Microwave Oven Operating Instructions ' Hunker
https://www.hunker.com/13407971/oster-microwave-oven-operating-instructions
set clock on oyster microwave and grill Google Search
Jun 24, 2018 | Microwave Ovens
Microve wILL NOT DO ANY THING COMPLETELY WENT OUT .
  1. Every microwave I've seen has a fuse in the 110 VAC line. Remove the cover or access panels and look for a ceramic or glass tube fuse with metal end caps. Replace with the same value, which is often 20 Amps.
Mar 02, 2015 | Oster OGB61101 1.1 Cubic Foot 1000-Watt...
Replace inside light bulb
gonna needa open it up theres about 6 screws holding the covere and it like a small light blub u can uncrew it or if not it has a has a clip u pull off and are able to change it
Oct 13, 2014 | GE Spacemaker JVM1750 Microwave Oven
Frigidaire microwave oven
Hello - This may or may not be specifically for your model, however these are generics instructions that I found.
To replace the light bulb to the over the range microwave you will need to follow the steps below:
1. To replace light bulb, first disconnect power to the microwave oven at the circuit breaker panel or by unplugging.
2. Remove the vent grill mounting screws.
3. Pull the vent grill away from the unit.
4. Remove the charcoal filter by pushing it inwards, then turn and pull it away from the unit.
5. Open light cover located behind filter mounting by carefully pulling up on the front edge.
6. Remove old light bulb and replace only with equivalent 30 watt bulb available from part distributor. Bulbs are also available at most hardware stores or lighting centers.
7. Replacing the microwave oven light cover by carefully pushing into place. Replace the charcoal filter. Push the vent grill back into place (engaging both the bottom and top tabs) and replace the vent grill mounting screws.
Note: DO NOT USE BULB LARGER THAN 30 WATTS.
Oct 27, 2012 | Frigidaire FMV152K Microwave Oven
How to change a fuse in oster microwave oven
Unplug microwave, remove top," several screws" look to the right where the keypad control board is, now look down where the printed circuit board is, fuse should be near by clipped in, pop fuse and replace with same current rating, assemble before testing, "lethal voltages present"
Apr 21, 2012 | Oster OGB61101 Microwave Oven
Lights fan and carosel do not work
tricky one. common denominator to all parts not working could be open neutral track at back of the circuit board, or possibly a relay not switching correctly.Need testing equiptment for that.
Sep 13, 2009 | Microwave Ovens
Just stopped working.
First, Enlist the help from a friend. Second,unplug cord and remove the screws going through cabinet into microwave. Third, tilt microve down and pull off mountind plate. Forth, remove microwave from shell. (Caution even though unplug, capacitor store electrical charge) As you are looking at the front of the microwave, the fuse holder will be directly above and behind the touch key-pad. Remove with an inexpensive fuse puller found at your local hardware store. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microve turns on, but will not heat Model number is FMT148G1B2
When you hit Start to cook, do the inside light and turntable come on? Yes
Any unusual noises? No
Is it louder or quieter than usual? No change
Sep 14, 2008 | Microwave Ovens
Microwave Ovens Logo
219 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
