Question about Canon ZR85 Mini DV Digital Camcorder
Eject when i close the bottom tape loader it says eject
  • Anonymous Mar 12, 2008
    Same problem with ZR100
Same problem here with the Samsung D963 (DV cam). I discovered that if you cycle the tape loader without a tape and then load a tape the gremlins leave. At least on mine, the camera doesn't stop for an eject anymore. Hope this helps veryone with this stupid problem. Now if I could just fix the damned battery life....
Posted on Jul 06, 2008
2 Suggested Answers
satavlad
  • 405 Answers
SOURCE: Sony Handycam CCD-TR64 cassette door won't close
Common problem with this mechanism. In order to fix the problem you will have to replace part called CHASSIS LS. Expensive repair, probably not worth the effort.
Posted on Dec 04, 2009
Testimonial: "Thanks. We ended up getting a new camcorder. That Handycam was as old as I am (18 years), so it was time for an upgrade anyway."
How do I load the tape
I see your picture of a cassette player. Guess you are referring to that. (tapes also come in reel-to-reel, and 8-track). Just push the "EJECT" button (power may need to be applied to some units for the eject button to work). The tape slot will open. Insert tape with exposed tape on the "head" side of the opening, usually the heads are on the bottom of the slot.. You can't put it in any other way and have the door close. The "door" that opens has guides for you to slide the tape into. The side you want to listen to should face you. Either manually close the tape compartment or push the close button (depending on model). If the door doesn't close, you put it in upside down. Push play and enjoy.
Oct 01, 2014 | Audio Players & Recorders
Cannot play a VHS tape. Push in and pops out.
The belt on the loader motor is slipping. This causes the tape to not completely position itself to allow the tape to load around the drum. The machine senses this and ejects the tape.
Feb 20, 2014 | Samsung DVD-VR375 DVD Recorder/VCR
Item: DLT tape drive ( DLT8000 SCSI LVD Loader For Scalar 100 )Problem: Eject spring not fully loaded, as the result pick up tape unable to reach to pick. Please advice.
Look at this document to see if the interposer mechanism is holding the tape from ejecting. The solenoid that energizes to tape insertion or ejection sometimes relaxes and you have to move it manually out of the way to recover the tape.
http://www.filibeto.org/sun/lib/hardware/storedge/tape/l280/pin-024.pdf
Jul 28, 2011 | HP DLT8000 HVD/SCSI Loader (c7200-69978)...
Dec 04, 2009 | Sony Handycam CCD-TR64 Camcorder
Canon es55 video camera. Everytime I put a tape in, it ejects it. If I take the tape out, and close the door,it will will automatically close and stay closed
Nov 21, 2009 | Canon ES970 Camcorder
Cannot find way to eject tapecassette
Check eject lever near battery, press it downward to open tape compartment, take out old tape and put new tape, close tape door and let it go inside by itself. Close tape compartment.
Below image will help you to locate eject button/ lever in DCR-HC18E camcorder.
Thanks.
Sep 20, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
EZECTING TAPE LOADER
This error is a mechanical malfunction, try this:
  1. Eject the tape.
  2. Set to OFF.
  3. Detach the battery.
  4. Reattach the battery.
Here is a link to your manual:
Manual
Mar 28, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
Gs36 tape door doesnt open
In case anybody read this....     I have a GS-36 that would not eject the tape. I removed all the screws from the bottom and pulled the bottom plate off. Then I fidgeted with the mechanism near the eject button towards the front of the camera.  In my case it had just become stuck and needed to be gently pried open.    Tested it a bunch of times with tape - seems to be o.k.!
Oct 13, 2007 | Panasonic PV-GS36 MiniDV Digital Camcorder
Tape won't load
Was having a similar problem but the tape would not even partially load. Spent several hours, over the course of several days trying to figure how to fix this and found the following solution to a similar problem on this site. I tried it as a last resort...it worked! Now I just need to figure out what to tell my wife when she asks me "how" I fixed the camera???? Here is what I did...I allowed the mechanism to close without a tape inserted (the only way it WOULD close), gave it a solid - but gentle - whack on the tape side of the camcorder with the palm of my hand...sort of like burping a baby. I said a little prayer to the saint of hopeless causes (St. Jude Thaddeus)...slid the open/eject button, opened the door, slid a tape in, gently pushed it down (where it says "push") and ...the mechanism closed!!! Not sure if the "fix" will last but we'll see and report back if the problem crops up again.
Dec 05, 2006 | Sony DCR-HC42E Mini DV Digital Camcorder
Canon ZR85 Mini DV Digital Camcorder Logo
172 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
