Question about Dishwashers
I need a timer
Timer for an old Hobart under the counter dishwasher
model WM-1D
ML-34001
serial number 27-044-383
Can you help?
rylee_smith
  • 8619 Answers
SOURCE: dishwasher says delime on screen, how do i do this?.
Hi!
You need to buy a calcium lime remover/lime remover and if you can see a bad lime deposit then please buy a stronger delime.You need to put the delime in the unit and run it through a cycle.Repaet this procedure more than once to get optimum results & get rid of the scale. Also try and delime it once in a month or two so that this doesn't happen in future.
Please rate this solution.
Thanks
Rylee
Posted on Feb 13, 2009
bigg t
  • 640 Answers
Hold the delime button in and hit the on button for 5 seconds.It will then do a partial fill then it will say add delime,add delime shut the door and press the wash button.Let the machine do the rest it will turn itself off when finished.
Posted on Feb 14, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: HOBART FX-20 dishwasher out of order
There is one glued to the lower panel on the inside. Hobart is very tight lip'd when it comes to getting any info from their web site. Best I can do, sorry.
Posted on Jan 25, 2010
  • 110 Answers
SOURCE: Hobart dishwasher model LX30H displays -5 on
by the way you're describing the problem, i would have to say there is something wrong with your control board. part#473173 can be bought @ any hobart office in your area. dont forget to vote
Posted on Feb 13, 2010
Testimonial: "Turns out it was mice eaten wiring."
SOURCE: Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Posted on May 25, 2010
Manufacture date hobart LX30 H. Serial 23-1044-007. ML 111 4354
If it is before Kitchen-Aid got involved, it is from the era before the 1986 buy-out by Whirlpool, so it is 30 years old at minimum!
Jul 12, 2016 | Hobart Dishwashers
My Hobart runs continues cycles and will only stop when I open the door...what is causing it to not stop after the rinse cycle?
When I did commerical Hobart repair, this usually was a timer issue..on this model is it a digital timer or a manual dial timer that you turn to select cycles? Another thing is..some dishwashers water temp has to be a certian temp before timer will advance.
Jan 07, 2015 | Hobart Dishwashers
I have a model 665.15831791 When it fills with water it does not go into a cycle, it automatically discharges the water
It could be two things causing such problem: no power to the wash pump motor or the motor itself is bad. Remove the wire plug from the motor and check for the 120V when the timer is on wash cycle. If there is no power then check the wires and the plug at the timer. If this is not an issue replace the timer.
If there is a proper power to the motor then the problem with your dishwasher is a bad wash pump motor. If your dishwasher is less then 5 years old then it could be under limited manufacturer warranty. Call kenmore with the model and the serial numbers and they will tell you. If the dishwasher is more then 5 years old I do not recommend you to repair it yourself. I've seen many times when it's not possible to install the pump back after repair because the plastic tub got warped.
here is the link to the schematic diagrams for your dishwasher ... you can also order for timer and other parts if need be from the same link as well
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dishwasher-Parts/Model-665.15831791/0582/0130000?pathTaken=
Sep 03, 2010 | Kenmore Dishwashers
Hobart WM-ID dishwasher doesn't heat water enough to clean dishes
The WM-1D does not have any internal heating devices. You have to supply the machine with the proper water temp. It has two fill valves, one for wash and one for rinse. It should have 150F supplied to the wash fill valve and 180F to the rinse fill valve.
Feb 04, 2010 | Hobart AM14C-155 Dishwasher
Need circuit card for Hobart Mixer Model HL600C
ge is a recitml# and repost, there are 2 p.c.b.for that mixer 1 is a recipe timer for ml#134317,part#916560, the other is a standard timer part#916557, can be bought @ any hobart location, one would assume that the c on the model # stands for corrections. hope this helps, dont forget to vote, monomoy
Sep 21, 2009 | Food Mixers
Top arm came off of AM 14 model
www.hobartservice.com, select parts on the left and either select model from the lists or enter your ML number. You will get exploded view drawings with links to part numbers when you click the item numbers.
Apr 27, 2009 | Hobart AM14-253 Free-standing Dishwasher
Dishwasher does not run
I'm a hobart tech and repair these units often.I can tell you this---If you open up the control panel and see water the wash tank has a crack in it.If this is the case depending on the serial number you may be able to get a new dishwasher.What happens is the water gets onto the electronics and shorts out.What is the exact serial number,model number and ml number?How old is it and where are you located?Have you had any repairs done by hobart or any other service company?
Jan 10, 2009 | Hobart 29 in. AM15-1 Free-Standing...
Looking to find out how old a hobart dishwasher model# wm-es-2 is
Hi Bobbertb
Let me see if I can help you. If the unit have a hot water booster behind the bottom panel, and it is located on the left and oval shape; well that's old. most parts are no longer available. If the booster tank is on the right side and somewhat square looking, then there is a chance.
Normally the model and serial number are stamped on a piece of metal, riveted on the upper section of the door.
More, models like wm5h or sr24 were very popular and most parts are still available.
I suggest you search the internet for those models, see if they match what you have.
Dec 01, 2008 | Dishwashers
All the wires been trip by some one so i need to wire it up
Can you confirm if you have an AM14 or AM15. Check the data plate and give the Voltage spec., ML number, if you have it.' Please confirm what you mean by the wires are trip.
Nov 12, 2008 | Hobart 42 in. AM14C-154 Free-standing...
Dishwashers Logo
Top Dishwashers Experts
Marvin
Marvin
