Question about Clarion DXZ-725 CD Player
Wiring Please tell me what color the remote wire is from the unit. Currently after my last tech the amp remains on. Pulling the fuse out when I park is making me smell burnt toast. SC
  • 46 Answers
The remote wire is blue...should be the only blue wire
Posted on Jan 15, 2009
Parking sensor wiring / reversing light wiring
Pretty much universal is the color coding on vehicle lights. Brown, or another color with a brown tracer/stripe, is always the running lights. You wont see an all brown wire on these newer vehicles. Always another color with the proper color tracer. Brown=run & tail-tag lights, green is right turn and brake light, yellow is left turn and brake light, and black is the ground wire to the lights. Inside cab and under dash, You need look closer for these colored tracers.all ground wires are white. This is what I've found.
Nov 12, 2017 | Cars & Trucks
1997 Ford E350 clearance lights don't work
First check the fuse, the clearance lights are not factory in most cases and the wiring gets shorted from poor wiring. Once you replace the fuse see if the lights come on, if the fuse blows right away find the wiring to the clearance lights and disconnect them, if the short goes away it is a I said the wiring is shorted. If you don't have the owner's manual you should be able to download it at the link provided. It should be fuse #10 a 20 AMP in the interior fuse box.
May 05, 2017 | Cars & Trucks
2000 buick park avenue ultra sunroof fuse location
The fuse for the sunroof is located under the back seat. The back seat can be removed by pulling up on the front (slide your fingers under the front side of the seat and pull up.) There will be a 3" square black box just about the middle of the seat area. This fuse box should have a 20 amp mini fuse (yellow in color) for the sunroof next to a line of 3 other fuses (15 amps and 10 amp fuses if I remember correctly.) Mine was not burnt out, so it's on to the next step of checking the wiring from switch to motor... :)
Jun 01, 2012 | 2000 Buick Park Avenue
I have a 1999 chevy prizm, I currently have a stoc...
The red wire is for ignition power, the yellow is for constant power, for the stereo memory, the black is the ground wire, the blue wire is for a remote amp or power antenna, the 2 white wires are for the front left speaker,and 2 gray wires are for the front right speaker, and the 2 purple wires are for the right rear speakers and 2 green are for the left rear speaker.
May 16, 2010 | Car Audio & Video
I need to connect my remote wire to a accessory wire but i dont know which one is the accessory wire. I dont have that light tester thing so I cant try it out. I heard you can just tap it with some fuse...
The accessory wire that you are looking for is the one that tells the head unit to turn on when you turn the key in car. If you have an aftermarket deck then the deck has it's own for the amp usually it is blue and in your case may not be connected to anything. If you don't have an aftermarket deck you will need to find a wiring diagram for the car radio harrness and it will be labeled. You dont want to use any random wire because if that wire always has power your amp will stay on and kill battery. You can wire a switch if you choose this method to prevent that from happening. You may also try running a wire from main power of amp to a small fuse (remote uses less than 2A) then to a switch and then back to remote screw of amp.
This website has wiring diagrams but colors dont always match. Good Luck
Mar 26, 2010 | Kicker ZX10001 Car Audio Amplifier
1994 ford thunderbird sony xplode installation?
power wire from batt fused to positive on amp .earth wire eg - to bare metal in car with bolt or screw. remote wire from amp to remote wire on back of head unit mostly blue wire it tells amp when to turn on then you need a set of rca cables to send sound from head unit to amp they go in subout if you wanna use sub or rear or front out for full sound best thing is to buy amp kit cheaper most the time and all you need there
Oct 18, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp not staying on
Hello lyttle_matt1,
Connect a DC voltmeter between the "remote" (+) terminal and the "ground" (-) terminal on the amp. When you turn on your Pioneer, you should read 12-14V. If you get voltage for a second and then it goes away, either the incorrect wire from the head unit is connected, or the head unit remote turn-on is defective. If the voltage remains on the terminal and the amp immediately turns back off, it's possible that the remote turn-on is not supplying adequate current for the amp. To determine if that is the case, run a separate wire from a positive (+) accessory terminal (cigarette lighter or fuse box) to the amp remote terminal. If the amp then turns on and stays on, you'll need to wire a relay into the turn-on wire. The wiring for such a relay is shown here. Most any 12V SPST or SPDT relay from an auto parts store or Radio Shack will work OK.
May 11, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Can anybody help me besides best buy for $80 an hour??
First of all if everything is wired right then your amp is defective. If you have The B+ wire from amp to the fuse block then to the positive battery post, Then if you have a good solid ground going to the amp, and you have 12 volts running to the remote on the amp when you turn the head unit on or a switch for the remote turn on, then you should have no problems.For one, I would test the voltage at the amp with car off and key off. Take the probes of the meter and touch them to the amps ground and positive terminals and check those readings. If ok turn key on and do the same thing, leave head unit off. If ok turn on head unit and test voltage at the positive and remote terminals using the amps ground. If you have any problems before the last test I said to do then thats where you should start to find the problem. Otherwise if the power drops it maybe a bad ground or else you'd start burning up fuses. Let me know what you found out or if you figured it out. I would like to know what it was. I own a car audio/video install business as well as amp repair. Send me a message so I can find out what it was please.
Mar 21, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Lights don't blink for remote start
If you look at the unit (probably installed under the dashboard, on the drivers side) You can see the wires going into the unit... Follow the wires back and you will find that 2 of them have in-line blade style fuses, it sounds like the fuse in the parking light output wire has blown. if you find the fuse is blown, replace it and the parking lights should be on again when you remote start it.
Jan 03, 2009 | Car APS921 Remote Starter - Keyless Entry
40amp fuse blows
Measure the DC voltage across the B+ and ground terminals as well as across remote and ground. If you have less than 11 volts when the amp tries to power up, the amp could be shutting down due to low voltage.
If the voltage remains near or above 12v, disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down or blows the fuse when you apply remote voltage (turn the head unit on), the amp likely has blown output transistors.
Nov 24, 2007 | Rockford Fosgate P3001 Car Audio Amplifier
Clarion DXZ-725 CD Player Logo
90 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
