Question about Canon CLC-700 Copier
Canon clc-700 stops copying when paper sticks to drum
We use the glass scanner on a clc-700 canon laser copier. The paper sticks to the drum inside and causes a jam. I checked the fuser oil and it was low so I topped it off but does not help. I am maybe able to get one copy at best. gus_mouse at hotmail dot com is an email for me.
  • gus_mouse Jan 15, 2008
    I took the paper feed assembly out. I looked into it further and the drum it is stuck on is the clear drum that feeds the paper around to the transfer drum. It is not stuck on the transfer drum. The paper is really feed in wrong I believe. I did about 10 sheets (no copies successfully) and the paper goes in straight but gets stuck at an angle. The front of the machine edge of the paper is about 1/4 inch further along in the feed process than the back edge of the paper in the machine. This is only 8-1/2 x 11 paper nothing large. That is the orientation in which it jams. I did notice a noise like a gear clicking when it jams but I think that is because it jams. The gears are not broken. I cleaned the roller assembly that feeds the paper and it had toner on it but looked relatively clean. I will need to look at it again when I can in more detail, but after 2 hours of staring at a small space I need to give my eyes a rest. I didn't see any gears worn or broke but need to look at the solenoids opening the claws? I'll have to figure a way to test that. Until later... Gus
  • Anonymous Feb 19, 2009
    My copier is Canon CLC-700 and it has the same problem, paper jum in the drum unit and crushed in one conner
  • 589 Answers
Could be one of two things.
Either the transfer / separation corona wire is dirty / broken, or the separation current is set wrong.
The drum separation claws aren't moving. Possibly a stuck solenoid.
Posted on Jan 15, 2008
I have a Canon CLC 4000, I have put new drums, and developers the fixing unit its OK. the glass(clean inside) too, but when i print o copy the colors are ok but a little Clear in some parts white spots...
If you haven't cleaned the optics and the coronas, do it. Always clean the machine, first. It'll save you money in the end. Not just the original glass. There are 3 optical mirrors in the optics cavity(underneath the original glass). One above the drum, and there are thre high voltage corona wires that get dirty.
White usually means that light is being blocked, and black usually means dirty coronas.
Don't know your technical level. if you need instructions
Let me know
Jan 16, 2011 | Canon CLC 4000 Copier
Check printer in canon image class d760
scanner bulb or mirrors of scanner must be having some dust on it.its easy to open the upper glass unit of scanner,jst open it carefully n clen the bulb ,mirrors n the calibration strip(black n white strip below the copier glass)with moist cloth.n refit it simply .ur copier will start copying for sure.feel free to ask 4 further asssistance.wish u success.
Jun 06, 2008 | Canon imageCLASS D760 All-In-One Laser...
I have canon clc 1180. Whenever I make a copy of a color document the final result comes with yellow bands.please help.
If you want to do a simple fix. Turn the copier off and take the copy board glass off and use a dry rag and Carefully clean the mirrors of the scanner and the lamp. Put the copy board glass back on and turn the copier back ON and go to "Additioal Funcations" and run a Full Autogradation adjustment.. Good Luck
Jun 26, 2010 | Canon CLC 1180 Copier
Canon CLC 1140 transfer issue on heavy or extra heavy stock
you must chose the bypass try to copy the heavy paper
Mar 24, 2010 | Canon CLC 1140 Copier
Certain papers, notably a transfer paper that I have used in other machines and have a lot of, will not stick to the drum properly which causes a 'jam' message: "Open front door, remove paper from drum"....
The paper on the CLC-1180 is held to the Transfer Drum by static attraction. Certain papers or media will not work with machine. One thing you can try is to check the flex the paper. Flex the paper and see which way it has the most flex. If the paper has more flex or bend in the Landscape direction load the paper in the Letter "R" direction, or Portrait direction (letter). If the paper is too stiff it will conform to curvature of the transfer drum and Jam.
Canon does not recommend the use of Transfer Material in the CLC series. Canon does have a recommended Heat Transfer Paper for Fabric item # 6094A082AA that will work with the copier.
Canon does recommend aftermarket transfer paper do the damage possible to the fixing rollers. It's possible you could get a Service Tech to adjust the Attraction charge in the copiers service mode to make this paper work better. The CLC 1100 series this very fussy about paper and some papers will just not work. The newer Canon Color copiers use a Transfer Belt which eliminate the bends and provide a straight through paper path much improving the performance with odd or heavy papers.
Mar 01, 2010 | Canon CLC 1180 Copier
What causes paper to stick to the drum?
Electric static cause the paper to stick to the transfer sheet. The chage comes from the attraction unit...
Nov 21, 2009 | Canon CLC 1120 Color Copier
Canon IR 2016J Scanner does not move and glows while copying
Call service it may be lamp pcb or broken belt or ...
Apr 08, 2009 | Canon CLC 1140 Copier
CLC 1110 E71?0007, E071?0002, E072 error codes.
On my CLC 1150 copier machine, I have an error code E071 – 0002.
Sir plz send soluation this error
Dec 12, 2008 | Canon CLC 1110 Copier
Erorr code E061
Please my Canon Color Laser Copier is asking me for a code, when i put it on it shows E350 on the table. sir what should i do.
Nov 16, 2008 | Canon CLC-700 Copier
CLC 700
remove the lamp and check the continuity, the lamp may be burnt out, also check the lamp thermal fuse. Failing that, check the continuity of the lamp cable, it may be broken inside the sheathing. And failing that, replace the lamp regulator.
May 15, 2008 | Canon CLC-700 Copier
Canon CLC-700 Copier Logo
171 people viewed this question
old marine
old marine
