Question about Norelco Advantage 6705 X Electric Shaver
Norelco doesn't work
My Norelco Advantage doesn't work, just an intermitent red light and then nothing. I bought it 5 years ago. I must change batteries, How can I do? Thanks
Gmo
  • Anonymous Mar 30, 2014
    I have a Norelco Silhoutte shaver # looks like 973D My mom bought at Sears years ago.
    I takes batteries 4 AA. I changed the batteries they are in the right way. When I flip the switch to turn on and it does not work. I donot remember how old it is and want to get a new one or something similar to it
Open the screws and replace them
Posted on Feb 20, 2008
I've changed out the batteries. You have to buy them on line cause they are two AA sized nicads that are connected with soldered tabs and have two free tabs that must be soldered in place. That means you have to unsolder the old ones. Make sure you notice the + and - sides of the old ones so the new ones are installed the same way. The case is opened by removing 5 screws. Note how a black plastic clip on top of the motor is placed cause it will fall out. The motor has to come out with the batteries and the circuit board under the batteries. The motor is connected to the circuit board with fragil thin metal leads that can break. One of mine did and I repaired it by soldering a short piece of thin, insulated phone wire. Mine worked really well until I let it run too far down before recharging and now my red light is on, too. I did get it to recharge by dismantling partly and reassembling; may be a faulty connection cause it went back to the red light and wouldn't run until I whacked it a couple times on my hand. It now runs, but still have red light which may mean its not charging. Looking for a manual to see what the red light means. I've also had it blink with a red light several times which may be a diagnostic light indicaton. Here's a link for the batteries, but there are probably other sources http://www.interstatebatteries.com/estore/search.asp?details=1&bnd=Norelco&mscssid=6256X7VH67LW9JBSK6Q7RTJRKXCQA3N8&Ntt=norelco&N=4294600169&mdl=600RX&part_number=NIC0200&part_desc=Norelco+600RX+replacement+battery&Nu=Part+Number&Ntx=mode+matchboolean&Ns=product+Type%7C0%7C%7CRank%7C1&Ntk=SearchGroup&js=1
Posted on Mar 04, 2008
6ya staff
SOURCE:
I have an Aquatec. Bought about a year and a half ago? It no longer gives a close shave. Is that all the longer a NORELCO shaver lasts?
Norelco suggests changing the heads every 12 months for best performance. This is stated in the user manual that came with the shaver.
Replacements can be found at shaveroutlet.com. You will need the model number written on the shaver to properly identify the correct parts
Sep 11, 2017 | Norelco Health & Beauty
Dead batteries
You will find batteries for model 6705X at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
Scroll down item page for viedo tutorials for installation tips
Dec 05, 2011 | Norelco Advantage 6705 X Electric Shaver
After using the shave a digital red symbol of the head shows up at the bottom of the shaver. What does this mean? Thanks.
Digital red symbol of the head shows up. It's menas that you should change new replacement heads, that Norelco Arcitec electric shaver replacement heads is Norelco RQ10 shaving heads.
May 21, 2010 | Norelco Arcitec Electric Shaver -...
Red light at bottom flashes even when razor ids fully charged. What can causrethis?
When the battery is almost empty (when there are only 5 or fewer shaving minutes left), the battery symbol lights up red.
Make sure that the battery does not have a memory effect. What I suggest is taking the shaving head unit off and running the shaver till empty, then recharging. Check if the red light is still flashing.
There's also a head indicator at the bottom of some shavers.
To remind you to replace the shaving unit, the shaving unit symbol flashes (all types) and you hear a beep when you switch off the shaver (RQ1090 only). This happens at the end of 7 successive shaves to remind you to replace the shaving unit.
Without knowing what model you have it's difficult to diagnose further.
May 23, 2010 | Norelco Arcitec Electric Shaver -...
What is the red blinking light showing the head mean?
Hello. That is a reminder that it is time to change the head, to maintain optimum shaving. It will blink the next 7 times you turn on the shaver. Here is the manual if you want to read more about it. http://download.p4c.philips.com/files/1/1050x_22/1050x_22_dfu_aen.pdf
ps kindly rate my answer as very helpful. thank you. Joe
Mar 29, 2010 | Norelco Arcitec Electric Shaver -...
Need to replace the lotion dont know how
Don't use the NIVEA lotion, just coat your face with a sensitive skin shaving gel, like Edge or Gillette, then run the shaver over your face. The shave is much better and cheaper. I gave up on the NIVEA packets over three years ago.
Dec 21, 2008 | Norelco Advantage 6705 X Electric Shaver
Doesn't hold a charge or cut very well anymore
Heads for your model are no longer available. Shaver will not hold a charge because batteries need replaced. Batteries can be replaced but soldering is required. If you have cleaned it well and it does not cut, I suggest getting a new shaver.
A full line of Philips Norelco shaver can be found at shaveroutlet.com
ShaverOutlet com ShaverOutlet com Rotary Shavers Men Shavers Manufacturer...
May 22, 2017 | Norelco Advantage 5615 X Electric Shaver
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Norelco Advantage 6705 X Electric Shaver Logo
581 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Robert McClure
Andrew Taylor
Andrew Taylor
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
