Question about Genius Soundmaker Value 5.1
Soundcard I am getting a hissing sound on headphones and when record something from my tv card the playback has interfering, like hissing sound
I have found that sometimes this can be interference from your line input. If you don't use the hardware that is plugged into it(if any) when recording TV shows, then mute it in your sound card volume settings
Posted on Jan 16, 2008
6ya staff
SOURCE:
Headphones keep going quiet.
I would return them and either get a new one from them or another manufacturer.
May 11, 2017 | Sennheiser RS 110 Consumer Headphones
I'm using Audacity with a Shure SM58 mic, and the recording plays back fine when the mic is unplugged, but if it is still plugged in when I press Play, there is no sound and the light on the mic's chord...
I assume you are using the X2u USB adapter. When plugged in, the X2u acts as your sound card for recording and playback. Thus the playback will be on the headphone jack of the X2u. You can select which sound card to use for playback in the Windows Sound Control Panel.
Aug 06, 2010 | Shure SM58 Professional Microphone
No sound with new Vizio 22" LCD TV being used as monitor
you have to hook up the 1/4 headphone jack plug to the TV, from the computer. an Y audio cable with RCA plug (male) with headphone 1/4 male plug. hook the headphone jack to the green hole of the computer(sound out) to the audio input of the TV better yet to a stereo AUX port. also make sure the mute button hasnt been pressed.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jun 03, 2008 | Dell Dimension 4600 PC Desktop
Only Hearing Sounds on One Side of Headphones
your headphones are bad sounds like cheak out the new seinhezer hd280 pros ok 99 bucks best they make
Jan 23, 2008 | Edirol UA-25 External Sound System
Lambda doesn't record, though it seems ready to go
you need to go to the "control panel" on your computer.....click on sounds and audio devices, then hit the "audio" tab...make sure the lambda is selected on the recording and playback device....then apply...this should take care of it
Jan 16, 2008 | Lexicon Lambda Usb Desktop Recording...
Hissing and poor sound quality
Well it could be interference from the TV, computer, or other 900Mhz device (some wireless routers run on this frequency).
I'm currently dealing with the same issue myself, if I find a solution I'll post back.
Jan 02, 2008 | Sennheiser RS 140 Consumer Headphones
Tascam 22-2 no sound
Yes you need to hook it up to an amplifier and speakers through RCA cable on the back. And or you can use headphones if there is a headphone jack?
Also make sure there is something recorded on the reel tape in the first place. You can do a test recording of something like a CD from your CD player or record something, then play it back, make sure you turn the record input volume knob up and make the RCA connections on the back of the reel unit and connect to your playback source you want to record. When you playback the reel tape, the db meters should be moving on the front of the reel deck, if they move then you most likely have some sound recorded on the reel tape.
If you still can't hear any sound and the db meters are moving, then check all your connections again and volume output knob on the reel deck. Hope this helps?
Sep 26, 2007 | Quantegy 456 Tape Reel(1/2 in. x 10 1/2...
Genius Soundmaker Value 5.1 Logo
165 people viewed this question
Top Genius Computers & Internet Experts
Barbat Nae
Barbat Nae
Alun Cox
Ekse
Are you a Genius Computer and Internet Expert? Answer questions, earn points and help others
