Question about ViewSonic VA800 17.4" Flat Panel LCD Monitor
Short, 3/8", horizontal blurs
I have a Viewsonic VA800 monitor that displays horizontal blurs emitting from objects on the screen. This gives the impression of movement.
Any thoughts? I don't want to give up the monitor. I like the vertical aspect.
Thank you, Dave Johnson ,
  • hubcapper Sep 26, 2008
    I am a tv and repair everything tech at trade...25 years in the vidio and consumer repair biss.............I have replaced a bunch of electrolitics on the main board ,,but haven't found the cap thats causeing this..ITS most of the time a cap that causes vidio issues with the flatscreen tvs and monitors.......NOT the power supply..tryed that... .Have white streaking after all the lettering ..anyone else that have found the repair to the problem i like to me at regards and best73--==de===-- Henry
  • 585 Answers
I posted this answer on another "white streak" question, I suspect this is right:
This issue presents itself in different ways in this monitor, in the form of smeary video, or color changing from the left to right, or as you indicate, a smear following text. I know this as I own this monitor, and have repaired this myself. There are three 1 mf capacitors, surface mounted on the control board inside the monitor that fail. They are in the RGB input lines, and when they fail they cause distortion of the RGB signals, causing what you see. They are the three caps you will find in a row, spaced maybe 14mm on the board between the VGA connector and the processor chip. I would replace all three, observing polarity markings. You can get by just fine using old-style thru-hole caps, just form and clip the leads and solder 'em down on the surface-mount pads. I highly recommend proper soldering tools for this job though, especially for the removal of the old parts, they don't want to come off unless you can heat both pads at the same time.
Posted on Dec 14, 2008
Screen goes black or pixelates
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Aug 18, 2013 | ViewSonic VX715 17" LCD Monitor
My viewsonic VA800 just started getting all pixillated - does it need to be degaussed?
mitchpowell, CRT monitors need to be "degaussed". No need for that with CCFL back-lit LCD displays. 12fixlouie
Feb 11, 2010 | ViewSonic VA800 17.4" Flat Panel LCD...
The green power light comes on but the screen is black? What do i do?
More likely the backlight inverter board is bad, you need to check and see if the surface mounted fuse/fuses are good on the inverter board, also check to see if it has 12v feeding it, post a pictures for further help.
Jan 29, 2010 | ViewSonic VA800 17.4" Flat Panel LCD...
"Lines" or irregularities through the monitor image display
Check power supply section for bad caps with bulging top first, may be a sign of failing power supply:
Jan 27, 2010 | ViewSonic VX2235WM Monitor
Geforce 3 analog output: I have horizontal, blurred/faint lines scrolling from bottom to top of display, spaced 6 inches apart.
what kind of monitor? Have you replaced the cable? Try the pc on another monitor. You need to see if it's actually the monitor or the video card. replace the broken or defective part.
May 30, 2009 | Nvidia 64MB GeForce3 AGP Video Card with...
Monitor is vertical display instead of horizontal display
the keys ctrl+alt+right arrow should do the trick for you. if not then right click on the keyboard and select properties for options and you will find your graphics software has its own rotational software. good luck with two year old, sounds like you'll need it.
Feb 25, 2009 | Dell Computers & Internet
Screen goes white after 12 seconds
Per the first hit on Google for 'viewsonic fades white',;jsessionid=A68BB7FE4AF6EC93EB730E8588C865A2?topicId=4064461903&sid=1
(which you should go on and read in another tab,) you need to contact Viewsonic about an inverter board (for the CCFL backlight) or switching your backlight to LED while spoofing the INVERTER_OK signal to keep the display from giving up as it does.
So...this should be a hint that you should respect others' time (or be moved to increase usability) better by searching for cures in similar Viewsonic monitors, and of course checking the obvious search terms.  Viewsonic evidently has a nifty knowledge base available for all on the web, so that one would be a nifty surprise.
Aug 18, 2008 | ViewSonic VX1945WM LCD Monitor
Green shadow and low brightness in Mac Mini intel
Launch System Preferences from the ??Menu.
click on 'Displsys try changing resulution and brightness.
Nov 13, 2017 | ViewSonic VA800 17.4" Flat Panel LCD...
ViewSonic VA800 17.4" Flat Panel LCD Monitor Logo
260 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
