Question about Polycom VSX 7000 Video Conference
VSX 7000A connects domestically but cannot connect internationally
I'm having trouble when I try to connect international contacts my systems just hangs. Does anyone know any settings of this device that might be preventing me from doing international video conferencing? I tried several test sites internationally and they all do the same thing; however, when I contact test sites domestically, everything is fine.
  • 47 Answers
Please check with your Internet Service provider. They might have a firewall which blocks the ports used for video conferencing
Posted on Apr 08, 2008
I'm trying to connect a polycom vsx 700 to this conference room. Same unit is able to connect to local scopia xt5000 with no trouble. If dialing 135.11.119.48 it times out without connecting to an
hello
This is not a dialing but trying to connect to the IP address setup in the system. Start editing the IP address giving the one that you would have already allocated to the device in the Router (i.e. 192.168.1.99) and then reboot it. It should connect then automatically.
Best regards
Dec 16, 2014 | Polycom VSX 7000 Video Conference
I'm trying to connect a polycom vsx 700 to this conference room.Same unit is able to connect to local scopia xt5000 with no trouble. If dialing 9200277@135.11.119.48 I get " The far end system does
hello
Best regards
Dec 16, 2014 | Polycom Lands Phones
The reciever sounds like the speakers are shorted out. I can hear the audio at about 3/4 but it is distorted and not load at all. Is there an internal fuse that may be shorted out? Thanks for any help
Just disconnect the cables, use a fresh set and validate the connections from the receiver to the speakers... This happens when it's cross connected or you have the speakers connected to the Sub connection. Just validate the connections from the user / connection manual that you should have received with the set
Oct 16, 2013 | Pioneer VSX-505S Receiver
Hi, After using the VSX-712 with headphones the
Need to have the headphone jack replaced. One of the internal contacts is shorted. You may be able to temporarily correct the problem by inserting and removing the headphone plug a few times.
Sep 20, 2013 | Pioneer VSX-D712 Receiver
FRS 2800 Mackie Amplifier Connection Problems
that sounds like an internal connection problem, try getting inside the unit to where the internal wiring is connected, if you have signal coming through well thats a big plus, see if there are any loose wires or if the internal connection is damaged, would probably pay to replace the complete terminal, should be able to pick up XLR connections fairly easily from any electronic spare part dealer, trouble with this type of gear is that the connector is continually being used, so over time they do wear out or suffer damage
May 30, 2010 | Mackie FRS 2800 Amplifier
Why does the receiver turn off and say overloaded?
Bad output IC. May have been caused by; overheating, shorted speaker wires, bad speaker, power surge or a bad connection has occured internally in the receiver.
Feb 14, 2010 | Pioneer VSX-D412 Receiver
Hi there. Need some help. I love my pioneer
Get an RCA-to-whatever-size-the-headphone-output-on-the-IPOD-is adapter and jack it into any available aux or line level input.
Feb 02, 2010 | Pioneer VSX-454 Receiver
I have a pioneer receiver and when i try to increase the volume past the half way point the screen flashes"overloading" wtf i have exactly the same problem as mtloans....pleeeeease give us a...
I would check your speakers OHM input requirements, usually an "overloading" indication is clipping the receivers internal amplification capabilities, also check speaker polarity to confirm exact + - connections
Feb 20, 2009 | Pioneer VSX-917V-K Receiver
My battery will not charge for my averatec laptop. The internal port seems loose and the external charger takes some wiggling to try to stay connected. Is the internal battery connection conneted to the...
I've never worked on this brand, but almost all laptops have the power jack soldered right to the system board. Flexing the power connector can break the solder connections and cause the problems you describe. If there hasn't been any damage to the system board, these connections can be resoldered. Getting to them can be a challenge as it means removing the system board to get at the solder side. But if you have soldering experience, patience, a small screwdriver, and some attention to detail, you can fix this.
The only trouble that may pop up is that sometimes electrical arcing occurs where the connections break, and may burn the circuit board. Sometimes the area can be cleaned and successfully repaired, sometimes it's too far gone. But it never hurts to try the repair. Good luck!
Jan 28, 2009 | Averatec (82-878011-01) Motherboard
Not able to getting video from Remote far end.
Is the Indian site within the firewall? If so, I would focus on the firewall. Does the US site have a firewall? They may be blocking outbound traffic. If you are connecting but no video, it sounds like UDP traffic is still being blocked somewhere. If you can, you may want to assign public IPs on the units and test outside of the firewall.
Hope this helps..
May 06, 2008 | Polycom VSX 7000 Video Conference
Polycom VSX 7000 Video Conference Logo
386 people viewed this question
Top Polycom Lands Phones Experts
David Burbee
David Burbee
TEKUSER
TEKUSER
pankaj rautela
pankaj rautela
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
