Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
GREEN AND PURPLE LINES ACROSS THE SCREEN
How do i fix green and purple horizontel lines on my
sony trinitron kv 32FQ 75U
    Genius:
  • 1,554 Answers
This is a symptom of the circuit failing.
it will soon be much worse.
You need a tech.
you can verify it is the tv circuit.
remove cable or input another signal such as dvd
bring up the TV' menu. does it have the lines.
Posted on Jan 26, 2008
MY SONTY WEGA TRINITRON HAS A PURPLE HUE AT THE TOP OF THE SCREEN. ALSO THE CHANNEL DISPLAY WHICH IS NORMALLY GREEN ON COLOR IS NOW A RED COLOR
This kind of problem occurs if tv screen got hit by some thing that damage internally and its irreparable, second possible cause is magnetic field nearby screen, please check any speaker or some thing that has magnet inside around tv, remove it from tv to fix purple hue at top of screen.
Unplug tv from AC wall socket for 20-25 minutes, replug back in and turn it On, this will demagnetize screen to cure the problem.
Apr 11, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
6 horizontal lines
I would look for a Vertical circuit failure. Most likely is the vertical output IC and or open resistor off the hv transformer. Definitely look for any loose solder connections around the Vertical output IC.
Hope this helps,
Skyassoc
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony 24in flatscreen has green color on right
dont power your tv near sound box or machines with magnet,
switch off tv, get a magnet and pass it all round your screen, it will clear with no time
Mar 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Intermitant color bursts of red, green, purple
Kevin,
for the color problem,most likely you do have problem with loose contact of components from C-board ( small board connected at the back of CRT "picture tube" which drives every color and size of the screen)if you have knowledge with soldering electronic component parts, resolder this board and also check main board for possible loose contact.
cheers,
mark
Feb 04, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Purple and Green lines at the top of pictures
The sensor is damaged. I had the same thing happen to mine. It can happen over wear, and time.
Sep 09, 2008 | Fuji FinePix S7000 Digital Camera
Sony Trinitron 32 tv
1) Could be bad CRT ( picture tube )===no green==purple.
 2) Might be lack of green drive to CRT==bad transistor.
 Recommend analysis by technician--usually worth it if CRT ok.
Oct 22, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
No Green in picture
KV-32S... and KV-32V.... notorious bad picture tube.....
not worth pursueing..........................T.
Sep 04, 2007 | Sony KV-32S20 32" TV
Hello im having problems with my sony wega
It sounds like you have a loss of green. This could be caused by the green gun in the picture tube opening up or the drive circuit for the green gun gone bad. Stargazer
Aug 10, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony Wega model # KV-36FS12 it doesn't work can u help me?
This is due to humidity in your area. Due to moisture content screen control section getting corrosion. cleanit and adjust the screen control to get the normal picture.
Monitor colours are only fluro purple & green!
use a 10 ins, speaker magnet to front of picture tube degussing color
Nov 29, 2006 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
649 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
