Question about Canon imageCLASS D780 All-In-One Laser Printer
Copier will not allow to use
Tried to copy one page and it scanned half way then beeped with E0000 now machine will not allow any copies at all
    Genius:
  • 1,003 Answers
E codes are usually paper jams take out paper drawer and look for jammed paper if you dont see any unplug copier from wall and plug copier back in somtimes this wil force paper trapped in copier out as it powers up.
Posted on Jan 15, 2008
Black band down right side of page when copy or fax
Most common cause for a band on copies or sent faxes is debris on the scanner glass. A cotton swab dipped in rubbing alcohol will usually work in cleaning the scan area. After cleaning the area, allow it to completely dry prior to testing the machine.
Feb 21, 2011 | Office Equipment & Supplies
Konika Minolta Copier prints half dark pages
If it is only causing an image problem when you copy and not when you print, then there is something wrong with the optics under the glass. Check and see if you have any mirrors out of place or if the scanner looks crooked. If you have the machine set up to scan try and scan to SMB or email to see if it still has the problem. If everything looks correct under the glass and scans to SMB and email look bad like the copies, you may have a bad CCD assembly, or a bad board.
May 10, 2010 | Konica Minolta Office Equipment & Supplies
When copying it randomly makes a loud noise and
see scan connector care fully and give me a good vote
Apr 13, 2010 | Sharp AR-407 Copier
Half of the page is black. This happens during
Is this a printer or MFP? If it copies and scans then your problem is in the scanner area, either something is on the glass or you have a bad CCD (changes image into bits to write info to drum) let me know if this is a 8100DN or what and I will find more info on the scanning section.
Aug 06, 2009 | HP LaserJet 8100 Printer
My Brother 8860 DN does not copies, yet it can print . The menu screen only allows fax, not scan or copy.
This is commonly an issue with the Keypad PCB. We can get you pricing on parts if you want to try this as a repair. Does the machine beep 3 times when you hit the copy or scan keys?
Dec 31, 2008 | Brother MFC-8860DN Printer
Epson V200 scanner
Epson V200 Copy Utility Problem with Incorrect Margin Output
I had the same problem forever and i just sat down today to fix it.
I have a Konica Minolta PagePro 1350w for my printer. The resolution
is set default at 600x1200 when in the Output Paper - Paper setting.
Change the resolution for your printer if you can to 1200x 1200 in the output paper - paper setting in the copy utility software, and
that should solve your problem with this half page copies. It might
still cut off some margins at the very edge, but most of the time they're just
plain paper margin. Hope this helps you out.
Jul 04, 2008 | Epson Perfection V200 Flatbed Scanner
When I want to copy a page it cuts off about 1 inch on th e side Have tried everything I put it on the glass like it says and no luck
i think all printer with copier have in common in regard with copying the have all allowance i think its half an inch so if you copy a borderless document its not 100percent copied theres a cut on the side. My solution? scan and edit so you can have a complete picture without a cut.
yours,
alecz
Apr 23, 2008 | Office Equipment & Supplies
Scanning
Our problem is not solved. It was suggested the feeder needed cleaning or wasn't working. The feeder works as we make copies of documents. If one is scanning can you feed the document or can you only scan one page at a time by placing it on the window?
Feb 13, 2008 | Brother Office Equipment & Supplies
Fax Not working
Copying Documents If you make copies of multiple documents at a time, the number of pages the fax can scan into memory varies depending on the scanning resolutions as follows: * STANDARD and FINE result in the same resolution when making copies
* If MEMORY FULL appears on the LCD when making copies, reduce the number of documents to be copied or reduce the amount of total copies.
  1. Lift up the document tray.
  2. Insert the top of the document, face up, into the ADF (1) until a beep is heard.
  3. Adjust the document guide to the width of the document.
  4. Press <Resolution> to select the resolution.
    You can select [STANDARD], [FINE] or [PHOTO].
  5. Press <Start/Copy>.
  6. Enter the number of copies (up to 99) using the numeric buttons.
    To make a correction to the number of copies, press <Clear> and re-enter the number.
  7. Press <Start/Copy>.
    To stop copying anytime, press <Stop>. If the document does not eject, press <Start/Copy> for a few seconds, then the fax will feed out the document.
  8. The new resolution will remain until it is changed.
Nov 05, 2007 | Canon FaxPhone B95 Plain Paper Inkjet
Canon imageCLASS D780 All-In-One Laser Printer Logo
70 people viewed this question
old marine
old marine
