Question about Hitachi Deskstar 7K80 Hard Disk 80GB, 7200RPM, ATA-6, 2MB Cache, Desktop, 20PACK (HDS728080PLAT200A3021020PK) Hard Drive
Installing 2nd Hard drive
Installed a 2nd HD on my Mac 466. But when i turn on my comp i just get tha apple screen noting else. I then turn off comp unplug the 2nd HD and it boots up no problem. am i missing something?
  • 589 Answers
Sounds like you have them both set to 'master' and is doesn't know which one to boot from.
Posted on Jan 15, 2008
What does flashing globe on white screen on mac meanmacbook pro
If by flashing globe you mean spinning globe (often a colored beach ball), there are several possible reasons. The spinning beach ball happens when a operating system command cannot be completed. The computer is frozen/stuck in a process that it can't complete.
Most often the cause is faulty or missing information on the hard drive. Running Disk Utility will often fix it. You may need to start the computer from your OS install disk and rather than install find Disk Utility in the pull down menu and run it on your hard drive.
The spinning ball could also be caused by insufficient RAM memory to even run the operating system. It could also be caused by hardware problems which can be diagnosed with the Apple Hardware Test found on the disks sold with the machine.
If you truly mean a flashing round globe, I have never seen such a figure. Flashing question marks or flashing circle with a slash through it means the mac cannot find a bootable hard drive. Your hard drive may have died or become corrupted. To see if you hard drive is defective, again run Disk Utility by booting off an install CD or another hard drive with a compatible MacOSX operating system to diagnose.
Try running the repair disk program under the general tab of the Disk Utility program.
Aug 11, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I get a big question mark that blinks on and off on my display. I have a Mac Laptop serial # 4H65017MWGL
That means the MacBook can not find a bootable device to startup from.
First thing to do would be try starting up from the CD's that came with the MacBook or the Mac OS CD if you have updated to a newer version of the OS ( 10.5 or 10.6 ).
If the MacBook starts from the CD, good news your computer is still good, just the Hard Drive may have failed or be failing. You can check and see if they Hard Drive is working by going to the Menu on the 1st or 2nd screen when you are booted from the CD and pull down to Disk Utility.
Once you are in Disk Utility if the is more than the CD showing down the left then there is hope, now look and see if the name of your hard drive is listed ( default is Macintosh HD ). If you named Hard Drive shows and you have an external Hard Drive w/ enough free space I would try backing up your drive at this point using Disk Utility to make a disk image on your external hard drive.
Now that you have either backed up your hard drive, already had a current backup or have given up all hope of getting data back, you can either try
  • Just reinstalling the OS on your hard drive ( not my favorite choice, since you might be installing over existing problems and have more in the future ).
  • Erasing the hard drive and installing a clean copy of the OS and re-installing your applications from the original disk and then recovering your data from the backup.
In either case there is the worry that the drive is starting to fail permanently, so now that you have been given a 2nd chance make regular backups or replace the hard drive. ( The hard drive on these is fairly easy to replace and instructions can be found here http://manuals.info.apple.com/en_US/MacBook_13inch_HardDrive_DIY.pdf .
May 12, 2011 | Apple Computers & Internet
My comp froze and when i tried to turn it back on i got a grey screen
When this happens, it's usually about the hard drive, AND if there's also a question mark on the gray screen, it's definitely about the hard drive. I'd try installing the operating system software again. BUT before you do that, check out Mac's users support forum; I've found tons of help there, and it's fast, easy and free!
Jul 11, 2010 | Apple MacBook Mac Notebook
Mac Pro not booting - blue screen
This symptom can signify one of the following things. 1) Mac OS is corrupted and needs to be re-installed."Archive & Install" 2) You hard drive is rendered unbootable, Erase & Install may work. 3) Hard drive needs replacement
Oct 01, 2009 | Apple Computers & Internet
When turned on it just a white screen with a picture of a folder
HI,
Off hand and based on the description, it would appear that the hard drive of the computer is either faulty or the programs stored inside are corrupted. Corrective actions could be any of the following:
  • removal of the hard drive and connecting it to a SATA/IDE to USB adapter. Thereafter connect said HD to the USB port of a 2nd PC and perform disk maintenance. This would probably be the best option since if it still can be recognized and accessed, this procedure would allow you to back-up/copy your important files;
  • re-partition, re-format and re-installation of your Operating System. But then of course this would mean that your files would be deleted;
  • do a repair using the installer CD;
  • worst case scenario is a hardware problem with the HD which of course calls for a replacement.
Good luck and thank you for using FixYa.
Mar 18, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
HD installed with XP in Giga MB,not booting up in the originalP3
it is impossible or else you reload the hd on the motherboard
Jan 21, 2009 | Computers & Internet
Not loading when i turn the computer on
Start the computer from the installation CD, choose Disk Utility from the menu, and then choose Repair Disk with the internal HD selected. If that doesn't work, you can try a new OS installation. If your data is important, don't erase the drive during installation and select "Archive and Install" -- if your data is *NOT* important, you can just repartition the drive and install the OS.
Jul 11, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple iBook Mac g4 Notebook hd doesn't appear
You have a hard drive issue, this is why it freezes. DO you hear clicking sometimes in the laptop? I would get your hard drive looked at by a tech.
Jun 09, 2008 | Apple iBook Mac Notebook
Blank screen
It's a hardware failure. Try reinstalling the OS, otherwise it sounds like apple gave you a LEMON. LOL (little humor there). This also happens when there is no OS installed at all, which doing the above may solve the problem. Also, check to make sure the Hard drive is formatted for FAT~~ and not NTFS, cause for some reason, apple system hate NTFS Drives.
Jan 26, 2008 | Apple MacBook PC Notebook
Trying to boot from a hd from my old comp
MS Windows XP when installed to an HD will "marry" itself to the hardware of the original computer specifically the motherboard. Transplanting the HD to another PC with a different motherboard will result in a cycling blue screen of death or protective message requiring that you reboot. Running in Safe Mode will not also be allowed.
You need to re-install your OS (boot from CD) but choose the 2nd repair option rather than a new/clean install or the first repair option if you want to preserve your other applications as well as your settings/configuration. Doing this will allow the OS to install the new device drivers and delete the old ones.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
God luck and kind regards.
Jan 13, 2008 | Computers & Internet
Computers & Internet Logo
101 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
