Question about Dell E173FP 17" LCD Monitor
Logic board for E173FPf
Does anyone know where to find this board? I am having a hard time finding it. Any help would be greatly appreciated!
  • Todd Sudduth
    Todd Sudduth Feb 10, 2008
    hey thanks for the effort, but i already fixed this monitor. it was the logic board. pretty simple fix, works great now.
    Novelist:
  • 138 Answers
What's wrong with you monitor? Did you check the lambs inside the screen?
Posted on Feb 10, 2008
My Samsung HMX-E10BP/EDC is stuck in DSP Tester mode. It says press menu for config, But that does nothing. It also displays a "wait HDMI connection" message but all that happens is that it...
Try removing the battery to reset it. SAlso check that none of the buttons are sticking.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 25, 2011 | Samsung HMX-E10 Camcorder
My controls will not open or close my garage door. The wired control works. I read that the logic board is bad. How much is the logic board and how hard is it to install. Is it better to just get another...
A new board is @ $86.00. Because I do not know your skill level I really cannot say whether it is easy or hard to install. I have replaced boards and I find it easy, but my brother would find it impossible. So it is subjective and you know your own skill level better than anyone else. I personally feel that it is not too complicated for a typical homeowner to do. In this economic time, some people have no choice and cannot spend the extra money for a new opener, but again I do not know your financial situation either. So the choice is yours, but if you can use a screwdriver and stand comfortably on a ladder, I would replace the board. I hope this helps and good luck!
Please remember to vote c5e7dfb.jpg and leave a testimonial. Thanks.
Nov 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
NO POWER ON INDICATOR LIGHT AND NO Screen Raster on Monitor
Initially, pls check D854 on the Power Supply/Logic board. It is a dual diode. If you would prefer board replacement rather than component level repair, this might be of help. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
This is of course in addition to checking the usual, power cord, fuse, outlet etc.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 05, 2008 | Dell E173FPf 17" TFT LCD Flat Panel...
Backlight
The problem is fairly common and while you could test the long-shot possibility that it's not the inverter but the actual CCFL "bulb" (a tube really) that produces the light and sits in the bottom of the LCD panel, the chances are that it's a circuitry problem on the logic board. I've never had luck replacing inverters in these computers (though it works like a charm in PCs).
With the symptoms you have though, it might make sense to try the $20 inverter rather than replace the logic board. It's really quite simple. Just follow the instructions on THIS PAGE and select Apple MacBook Pro (even though you have a PowerBook it's almost exactly the same.)
It will walk you through taking the back off and pulling the LCD, but just notice that on Diagram #2 it shows you where the inverter board is. Just take it out, remove the two cables going to it and replace it with a known good one from eBay. It will be a great $20 way to check a cheap solution. After that fails, replace the logic board.
Or, for more fun, find another person with another laptop who doesn't mind you pulling it apart. Almost all 12" laptops will use a similar CCFL, so you can plug your LCD panel into just the two prong CCFL plug (shown in step 3 of the walk through). If you find someone else with a powerbook or iBook I know for certain that your screen's CCFL plug will fit.
So you could do all this or you could find someone on Craigslist to do it for you for a pretty cheap cost. Good Luck.
to peachgroup: if you have a lighted White screen, it is something completely different.
Jul 30, 2008 | Apple PowerBook G4 Mac Notebook
Fedora 8 Installation
hai
delete all parations from your hard disk and install the fedora
also check your ram i should be 1 gb to install fedora 8
Apr 11, 2008 | Computers & Internet
Zebra Z4M printer error
The mainboard does not need to be replaced, just the sensor head open is dirty and needs cleaned.
Mar 10, 2008 | Zebra Z4M Printer
Dell E173FPf lcd- no picture,steady green light
E173FPf Mfg December 2004
This E173FPF has changed much inside from the November 2003 E172fpb which had the famous 4 identical transistors 5707 that would tend to fail in pairs. If your newer E173FPF displays a green power light and fails to display a picture try replacing the 220uf25v capacitors at C6 and C26. Test them with a volt ohm meter and they will test Ok, replace them anyway. Radio Shack did not have the 25v so I used the 35v, display works fine now. There is an E173FPF repair kit with directions available on Ebay if you don't have a parts store in your area and would prefer delivery.
i'm not an expert at anything...x'cept maybe dumpster diving. God Bless
Jan 14, 2008 | Dell E173FPf 17" TFT LCD Flat Panel...
Bad logic board on Western Digital Caviar SE16 500...
Are you still looking for the PCB?
Maybe I can help you to find it.
PM me on this forum http://forum.hddguru.com/hard-disk-drives-repair-and-data-recovery-f1/
Username: dav34
Oct 01, 2007 | Western Digital Caviar SE16 (WD5000KS)...
Bad logic board on Western Digital Caviar SE16 500 GB SATA Hard drive
I just had the same problem today. I found this place.
http://www.lowcostrecovery.com/pricing.html
Sep 15, 2007 | Western Digital Caviar SE16 (WD5000KS)...
Dell E173FP 17" LCD Monitor Logo
53 people viewed this question
Alun Cox
