Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Agitator not working
I have a whirlpool ultimate care ii washer that is not agitating. knowing it will costs at least $75 for a service call,what can i expect the agitator to cost?
  • 4 more comments
  • darocapaco Dec 31, 2008
    I have a whirlpool extra large high capacity 9 cycle washer. It appears that there are two agitating parts, the bottom part and the top part, which has spiral fins on it. the bottom part works great and turns back and forth great. the top part that pulls the clothes down to the bottom of the machine, fails to agitate. Is this easy to fix? is this the "Dogs" part.
  • DennyDuf Jan 03, 2009
    Ours also the Upper agitator will not agitate, all other cycles appear to be normal.
    MN: LSQ8543JQ1
    SN: CL034357
    TYPE: 111
    Other then the UA problem the unit works fine.
    Denny
  • lollipopluv Jan 07, 2009
    I believe the problem with my washer may be the lid switch you mentioned, because the agitator will start when I bang the lid several times. Would you happen to have a solution I may follow? Thank you! The model number for my washer is LSB6300PW1 and it is an Ultimate CareII top loading washer.
    I believe my washer's problem may be the faulty lid switch since it starts to agitate when I bang the lid a few times :).. Would you have a solution to this I could follow? Thank you! Model number is LSB6300PW1 and it is an Ultimate Care II top loading washer.
  • darocapaco May 11, 2010
    yes, everything else works fine but it just doesn't agitate on the top agitator.
  • brian c
    brian c May 11, 2010
    Is there any motion from it at all (spin, etc)?
Thanks for the help, I pulled the agitator and took it into a repair shop, cost me $10.00 for the parts, re-installed all works good.
Posted on Jan 06, 2009
I had the same problem. I replaced the agitator dogs and it works fine. I called a repair company and they wanted $100 to come out and look at it. I did it myself in 15 minutes and it cost me $7.40. Here is the link I used to reference the removal of the agitator. http://www.davesrepair.com/DIYhelp/DIY285770.htm
  • 5,911 Answers
There are several things that can cause your machine to fail to agitate. First of all, you need to ask yourself a few of these questions:
1. Does the washer fill normally, initiate agitation cycle and just the agitator is not moving? If so, the transmission and motor coupling are likely good and the agitator has probably worn out the dogs that cause it to grip properly. The agitator dogs will need to be replaced and you shouldn't need a new agitator. (rough estimate = $5.00 to $6.00).
2. Does the washer fill normally, but stops when the agitation cycle is to begin? If so, I would suspect a faulty lid switch. The lid switch will allow the washer to fill, but will not advance the timer beyond that point on some models. (rough estimate = $35.00).
3. Does the washer fill normally and makes a loud grinding noise when the agitation cycle begins? If so, I would suspect your motor coupling is bad and needs replaced. (rough estimate = $18.00 to $20.00).
4. Does the washer fail to fill at all? If so, I would suspect a bad fill valve, pressure switch remaining shut off and/or timer. (rough estimate for fill valve = $35.00, timer = abt $100.00).
These questions are not all inclusive, but these are some of the more common problems I have encountered. If you can provide me with a little more symptom elaboration, I can lead you in the right direction and get a part number and a better price for you. I will need your EXACT model number (located somewhere along the lid opening. Post back with your comments if you need my assistance. A good majority of the problems associated with Whirlpool top loaders can be easily repaired by the average consumer without assitance from a repairman. I hope this information is helpful to you.
Posted on Jan 15, 2008
Whirlpool ultimate care II, Top agitator not working. I got it apart and can see the agitator dog gear not catching, unable to free the gear from the clips. Suggestions?
stand on agitator,pull top section upwards,the agitators are meant to be disassembled this way,sometimes they are stubborn,and you cannot service agitator if agit is still in the machine...
Mar 09, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
How do i remove the agitator on my whirlpool ultimate care II top loader washer
first you remove the cap on top of the agitator then you remove the inner cap then you use a long extension with a 7/16 socket to remove the bolt the agitator will pull right up
Sep 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Wont agitate
your dog ears are bad.
You can replace them for about $10 @ your local appliance store.
Aug 17, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool top loader washer not agitating
Hi, Do you know if the lower half of the agitator is working? THere is a dog kit that might need replaced in the agitator to get the top half to work. If neither half agitates, there is probably a transmission issue. Start the washer with no laundry in it and see if either sections of the agitator work.
I hope this helps you.
Vic
Jul 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My whirlpool ultimate care 2 washer works great, however, the agitator misses and clicks before it catches up
Is this a two piece agitator? You may just need dogs, they are inside the agitator. Rotate the top of the agitator back and forth, top should engage the bottom portion when turning counter clockwise.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Remove agitator on a whirlpool ultimate care II washer
have you look at the center of the agitator? after you remove the dispenser.
there i s a bolt there that you have to remove before pulling the agitator at the top.
tnx 4 using fixya,
drcool
Oct 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer fills but agitator doesnt start; sensor problem
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Sep 24, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
410 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
