Question about Sony XPLOD CDX-GT200 CD Player
New Sony radio doesn't work in a 1996 Fiat Punto
I've just changed the radio in a 1996 Fiat Punto. Before completely installing the radio, I plugged the leads in, and the radio worked fine. After putting the cage in, and placing the radio into the cage, the radio now doesn't work. Worse still, the old radio doesn't work as well.
I checked the fuses which are all fine. I'm at a complete loss. Please Help.
Check that you have a very good earth seperate from the aerial or outer casing.
Posted on Jan 15, 2008
Torque settings on a fiat uno 1100 engine
Answer barbo(fiat mechanic) Fiat do not issue torque settings for a punto they use angles so that you can snap your stretch bolts! after contacting fiat and haynes neither of them would give proper torque settings, so i delved into my many tech manuals on fiat fire engines which is what is in your punto and i have successfully changed many fiat punto head gaskets using the following torque settings: stage 1 starting from the centre head bolts tighten to 33nm: stage 2:65nm and finally stage 3: 96nm these torque settings work fine and will probably save you buying new head bolts.
Oct 29, 2014 | Cars & Trucks
Fiat punto automatic
time for a new box..
Jan 08, 2014 | Cars & Trucks
Fiat punto Blaupunkt radio code
If you lost your radio code and it's the original radio inside the car, your best bet would be to go to Fiat. If you play nice they won't charge you for it.
Apr 21, 2013 | Car Audio & Video
Fiat Punto idles rough and grey smoke
take your cylinder head out and take it to the engineering and ask them to change your valve sterm seals then your problem will be solved
Oct 23, 2012 | 2001 Fiat Punto
My fiat punto loses power when driving uphill
I have a 98 punto sporting nd today it started running like it was misfiring but wen i accelerate slow its fine but wen u accelerate as normal it spits and splutters :'( any suggestions??i have change fuel filter nd injectors ????
Sep 22, 2012 | 2005 Fiat Punto 1.2
Fiat punto 2001 radio code
Best to go to your local fiat dealer and they can look it up against your chassis number. hope this helps.
Jan 09, 2008 | Radio Communications
Installing a sony xplod in to my girlfriends fiat punto
If I were in your shoes I would hardwire it, Run the red wire directly to fuse box or battery, run yellow wire to switched circuit in fuse panel, and isolate the black ground wire somewhere inside the dash, I'm in America and have not wrenched on any FIAT's, but in my expirence some manufactures doe things proprietary, give this a shot.
Sep 27, 2007 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
Sony XPLOD CDX-GT200 CD Player Logo
291 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
