Question about GE ZV750SY Kitchen Hood
ZV950S D2SS 4 Lights on the unit not working. Have new bulbs installed and none go on. Any ideas? fredmo395@yahoo.com Thanks
  • 2 more comments
  • trae121 May 03, 2008
    I have the same situation. The fan works but none of the lights work.
  • kimberj Sep 01, 2008
    We have the GE Monogram Stainless Steel 42" Island Vent Hood ZV1050 and everything works but the 4 lights won't come on? Had it installed in July 2006 and was working until a couple of weeks ago, went to turn the lights on to cook and nothing?
  • Tom101 Dec 07, 2008
    I have GE range hood, model ZV1050. Two of the four lights are not working. I replaced bulbs last month and everything was fine unril now when the two front lights do not light. The back lights continue to work, including the dim and brightness. Tried switching the bulbs around without success.
    Thanks for any info or help you can provide.
    tom@tjwilson.com
  • Kevin Scott May 11, 2010
    How many total lights on the unit ( are some working and some not?) Here is a link to GE's website put in your model number on the bottom of the page it will take you to a diagram and parts list. I would think the switch has gone bad but you would need to use a multimeter to check for sure. Good Luck Kevin
    http://www.geappliances.com/service_and_...
Brake light problem
Make sure you have the right bulb. I've seen several times where the wrong bulb was installed.
Apr 08, 2016 | 2007 Lincoln MKZ
GE Monogram ZV950S D2SS range hood - lights on one side stopped working then on both sides. This happened as I was changing bulbs. Everything else works.
Light doesn't work
  1. Light bulb
If your refrigerator light does not power on, the first thing to replace would logically be the light bulb itself.
  1. Light assembly
If your refrigerator light does not power on and you have replaced the bulb, this is an indication that the light assembly may have malfunctioned and will require replacement.
  1. Light switch
If you notice that your refrigerator lights are not working, replace your refrigerator light bulb. If this does not correct the issue, proceed to check the power light switch.
  1. Door switch
If your refrigerator light is not working and it is not the bulb itself or the power light switch, the next thing to check is the door switch. This can be checked for continuity with an ohm meter. If there is no continuity present, the door switch will need to be replaced.
  1. Light socket
If your refrigerator light is not working after replacing the light bulb, check for a possible damaged light socket. If the socket is faulty, replace the part to get your refrigerator light to power on again.
  1. Light board
If the refrigerator light is not working the light board could be defective. The LEDs on this board are not repairable, so the entire board will need to be replaced.
Feb 15, 2015 | GE Refrigerators
2000 jeep grand cherokee none of the rear lights work
Check BackUp Module, generally is located in the rear quarter panel (drivers side).
Dec 23, 2012 | 2000 Jeep Grand Cherokee
My dashboard light for 2002 Ford KA not working, even after replacememt
Could be the small bulbs in the speedo unit have simply blown over time . You just remove the speedo unit and they tun about 90 degrees to unscrew . They cost a few pounds and you can get different colours these days.
Feb 19, 2012 | Ford Ka Cars & Trucks
The lights stay on all the time and won't shut off. The front ones work fine but not the back lights. Any idea's? thanks,
Unfortunately when the power pack stops working there is no solution.
Your power pack has electricity so that is not the problem.
The bulbs turn on, so the bulbs are ok.
That means the power pack has malfunctioned, and needs to be replaced.
I did find some tips to help folks preserve their power packs:
1) Match wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
2) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
3) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
4) When working on bulbs, unplug power pack or it may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
Nov 12, 2010 | Intermatic Malibu 121W Power Pack...
2007 chrysler town and country interior dome lights
if it is covered by a white plastic then inspect it carefully and look for slots where you can put tiny screwdrivers to pry the plastics off, then you can replace your bulb. just be careful not to break the plastic.
tnx 4 using fixya,
drcool
Sep 14, 2008 | 2007 Chrysler Town & Country LX New Cars
GE ZV750SY Kitchen Hood Logo
234 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
