Question about Maytag MGR5751AD Gas Kitchen Range
Maytag gas range I'm not sure of the model #/range is nine years old
Oven takes an extremely long time to pre heat most of the time but there are a few times it pre heats quickly.
  • Anonymous Jun 09, 2008
    Oven takes a long time to preheat. Broil works fine and placing the oven to clean worked
  • 35 Answers
YOU OVEN IGNITER IS PROBABLY ONE STEP AWAY FROM GOING OUT.
SO REPLACE IT AND YOU SHOULD BE UP AND RUNNING.
Posted on Jan 17, 2008
Maytag MIR8890AS0 6.2 cu.ft. induction range w/true convection. Takes an hour or more for oven to pre heat, doesn't maintain heat. 4 yrs old. Induction top OK.
I don't know, but it sounds like one of the heating elements are burnt out/no longer working. I had a similiar problem 5 years ago.. they're pretty easy to replace yourself if you are handy and have a screw driver. I think the one for my stove cost $18 to replace (5 years ago) here's the trouble shooting guide online for you model:
Maytag Range Stove Oven MIR8890AS0Troubleshooting Repair Help
Dec 07, 2016 | Maytag Kitchen Ranges
There is gas to the burners on my old Hardwick range, but not to the oven.
perhaps you need to call someone to have the gas line cleaned going to the oven .have heard that spider webs can stop gas flow .it doesn't take much
Jul 22, 2014 | Maytag Crosley Hardwick Caloric Kenmore 8"...
Strong gas smell when oven is on
Bad heating element. Needs to be replaced. Depending on what you plan on replacing it with...call appliance repair shop with you model info and ask for quote to replace heating element.
Feb 10, 2013 | Kitchen Ranges
Oven takes forever to pre-heat and then doesn't keep the temp constant. turning on stove burner helps sometimes, and sometimes it works fine. do we need new thermostat or...? not sure if i have right...
Very common problem, I would replace the oven ignitor first as they get weak with time and cause intermittent burner lighting. Good Luck, Appliance Specialists
Dec 31, 2009 | Maytag MGR5750 Gas Kitchen Range
Oven takes a long time to heat up.
Hello. To go 12 years without issues is excellent. Now however you will have to make a decision to repair or replace. Be sure to get a firm estimate before you repair and compare that to the cost of replacement.
here is what may be causing your problem:
Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
Aug 15, 2009 | Maytag MGR5750 Gas Kitchen Range
Oven takes FOREVER to pre-heat
You probably have a bad heating element. Trip the breaker and make sure that all power is removed from the stove/oven. Remove the element, and test it for continuity. If it tests open, obtain a replacement from an appliance parts supply house. If it tests good, you should suspect either a bad switch or thermostat.
Regards, --W/D--
Jul 20, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Gas oven makes a fluttering sound when pre-heating and cooking
This is most often due to the ignitor bar aging. With time it draws less current and does not hold the regulator valve open all the way. You can confirm that the regulator is OK if the broiler works. Replacement for nearly all of these ovens is a universal part, about $35 at appliance parts stores, takes 5-15 minutes to change (depending on whether you need to pull the oven out to get to the connector).
Nov 30, 2008 | Kitchen Ranges
Oven does not heat to proper temperature
1. Do both coils get red hot? Try with bake @ 400F, then with broil to be sure. I recently had a bad lower bake coil, but the oven got hot slowly since the broil top coil comes on periodically to even up the heat in the oven. Replacing the lower coil was easy, about a 15-min job, but I had to pre-tap the screw holes on the coil terminals since my oven had extremely short wires.
2. If the coils are ok, the problem may be with the thermocouple or control board.
Oct 02, 2017 | GE Profile Spectra JGBP90 Gas Kitchen...
Viking Range
I'm having a similar problem. I don't know the exact fix yet, I'm just starting to research. Check this link: http://www.applianceguru.com/forum1/1916.html
It sounds like the ignitors are suspect. This may be a weak component for Vikings. This link recommends a Maytag replacement part.
Dec 08, 2007 | Viking VGSC366-6B Gas Kitchen Range
Maytag MGR5751AD Gas Kitchen Range Logo
217 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
