I have not used my printer for faxing. Horisontal black lines across the page appears when printing or making copies.I have not used my printer for faxing. Horisontal black lines across the page appears when printing or making copies.
im using an OKI OL810, no probs for years then all of a sudden black lines across the top of the page its been cleaned aligned so whats going on?im using an OKI OL810, no probs for years then all of a sudden black lines across the top of the page its been cleaned aligned so whats going on?
AnonymousMar 20, 2014
printer won't printprinter won't print
You can't post conmments that contain an email address.
Your problem is the black toner cartridge pickup drum has become scratched and is depositing "extra" black toner onto the paper prior to the fuser roller. you need to replace the drum and all should be ok then
Try printing the demo page, there's a man on there with a black tuxedo. If you see snowflakes on the black suit, you need a new hi voltage power supply circuit board. Also most of the generic toners don't work well in this machine.
Usually I've seen that happen when you use generic toners. There are 4 toner clutches down the right side, with the right cover off you can see which clutch is doing the grinding. Many of the generics are overfilled and hard to turn and will make the noise until you loosen them by hand turning them til they loosen up, or just replacing.
This is a very common problem with Samsung CLX-3160 and CLP-300 printers. The real problem is that the developer blades get dirty with the toner. Buying a new imaging unit will only fix the problem for a short period of time then it starts to get buildup on the developer blades. You need to clean the developer blades. If there are streaking on any color, then also needs to be cleaned.
To clean the developer blades, look to this link. http://losingambition.com/clp300imagefix/ It describes how to clean them. It only takes a few minutes to do once you get the developers out of the unit. Just be careful when you clean the edge of the blades. You need to make sure that the residue is completely removed from the edge. Also be sure that when you reinstall the blade that the little foam does not get trapped below the blade. Otherwise when you print the side where the blade is not properly installed will have too much color.
If you are afraid of messing your printer up, then you need to buy a new imaging unit. They go around $100.
I have a brand new HP pavilion, but it wont print from my HP deskjet. If i am lucky i get the first p[age and a couple of lines on page 2. My new laptop (ACER) is quite happy to print using the same cable. printer etc. Conclusion...HP pav is defective. Am I wrong?
printer won't print
