Question about Philips 55PL9773 55" Rear Projection Television
55pl9773 i think i could replace lamp driver/balast. what the p/n and how difficult would it be to replace . what it look like on55pl9773
  • travdoty Nov 19, 2008
    same thing happens to me
    Problem Solver:
55pl9773 philips dlp
yellow led blink on/off then go away,"shutdown???"
fans will not turn on, go to back off unit and open lamp door,lamp swith is off,turn tv on,now all fans are on and running,unit seem like working ,no picture or sound.if i close lamp door swith it shut down again,
replaced new lamp ballet ,it is same problem????
anyone have comment??
Posted on Apr 03, 2008
Only $99.00.
http://www.intl-lighttech.com/store/item_GTL-OS-69374
Posted on Aug 31, 2008
I have a Philips Cineos 55" 55pl9773/17 that has an issue with the picture where it is dark around the border or edges of the screen. Basically, to put it differently, the outside of the screen is...
open up the back of the tv and look to see if any of the capacitors on the power supply or video board are swollen or oozing out stuff....if so replace them and should work
May 04, 2011 | Televison & Video
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
The lamps keeps on blowing only had it 3 years from new ,the last lamp that blew the red light flashes 3 times and on the other lamp flashes once. thanks brian
This is because you have a bad lamp balast you need to change the balast as that is proving incorrect current to the lamp due toa faulty sensor on the balast.
I hope this information helps you please leave positve feedback and ratings for your free answer today.
Oct 24, 2009 | InFocus ScreenPlay 4805 Multimedia...
Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
May 02, 2009 | Samsung HL-S5087W DLP TV
Philips 55" tv
Yes I've had to replaced mine twice. here is the best price I found the second time I ordered it only $99.00.
May 15, 2008 | Philips 55PL9773 55" Rear Projection...
Sony DLP KDF-E60A20
Has anyone experianced a problem with sony DLP mod# KDF-E60A2 blowing lamp every 30 days? we replaced balast and lamp, still blows every 30 days or less.
Nov 26, 2007 | TruTech PLV16260 Television
55pl9774
I have this same problem. I replaced the lamp but the problem still exists. I had a repair place come out. They told me it was a bad new lamp. I tried another lamp but had the same problem. Now they told me it is the lamp driver/balast. I am not sure if I will have them repair it for $350+-. When they did the diagnosis, they didn't even bother to turn on the tv.
Nov 08, 2007 | Philips 55PL9773 55" Rear Projection...
TV lamp, sound.... don't come on...
The balast has a plug going directly to the lamp. There is also a thermal fuse coming off of the balast that lies above the lamp housing. Check for continuity. If open, replace.
Oct 03, 2006 | Panasonic PT-45LC12 45" Rear Projection...
Philips 55PL9773 55" Rear Projection Television Logo
262 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
