Question about Epson AcuLaser C900 Printer
White line across page
I have a smudged white line appearing across the page (about one third of the way up) and black text looks smudged either side of it - do I need to change the photo conducter unit or is it something I can clean myself?
6ya staff
SOURCE:
How do I fix my Samsung Multi-function laser printer which has started to print smudged pages.
try to stop the sheet just before it enters the fuser and see if the marks are on the paper already. if not then it has to be the fuser if they are them you have another issue.
Jan 15, 2015 | Samsung CLX-3175FN Color Laser All-in-One...
White lines in my printing and sometimes smudges of black ink
Hi
First before you buy a new cartridge,try doing a 'printhead' cleaning on your machine.Sometimes the printheads need cleaning clogginl.
Mar 03, 2012 | Office Equipment & Supplies
Smudging with black & white text
try opening up the properties for the printer and finding the tab marked tools. once there use the alignment and cleaning tools see if that helps
Nov 11, 2009 | Office Equipment & Supplies
A series (10) vertical lines on print outs
See Charge roller my be dirty or Catriges PCU Units
Jan 22, 2009 | Ricoh CL3000E Laser Printer
Too much toner on paper which then smudges
Try reducing the print resolution using the menu buttons. Does it smudge with coloured prints? If so then the fuser unit is faulty. If it is only black that smudges it is likely to be the K Developer unit. Ensure that you are using genuine toners, not refills or third party as the quality of toner can cause similar results.
Jan 14, 2009 | Epson Aculaser C1100 Printer
Black lines on the right side of every copy
depending on what the lines look like it could be the charge roller or transfer roller.
A defect on the charge roll appears as black areas on the front of the test page, and as light gray areas on the test page.
A defect on the PC drum of the toner cartridge appears as white areas on a dark, full–coverage test print and as black areas on the "text only" test page.
I have also seen a line with a 'ridge' on the paper. This will appear almost like an embossed line. This was caused by the fuser roller being scored by debris.
Jan 12, 2009 | Dell 1710 Laser Printer
Striped line down right hand side of printout
all parts are ok just clean the printer it will work
Dec 02, 2008 | Samsung CLP 300 Laser Printer
I get a white line on the printed pages on my Brother MFC4800. The line is about 5mm wide and runs down the left hand side of the paper, cutting through the type. Can you help please
Try cleaning the optics and the charge corona. If you do not have the operators manual which outlines the proceedure, go to www.welcome.solutions.brother.com. The proceedure is in the CLEANING documentation. Make sure the wire cleaner is pushed all the way back to its home position. Otherwise, the white line may return if the cleaner is left in the expoure path. IF THE WHITE LINE APPEARS ON PRINTED PAGES GENERATED BY YOUR COMPUTER, THE WIRE CLEANER IS THE MOST LIKELY CAUSE.. IF THE WHITE LINE APPEARS ON PRINTS THAT WERE SCANNED USING THE BROTHER SCANNER, THE OPTICS MAY BE SMUDGED. LOOK FOR CORRECTION FLUID ON THE GLASS **** (THE NARROW SCAN GLASS). THIS IS THE USUAL CAUSE.
Jul 23, 2008 | Brother Office Equipment & Supplies
Epson AcuLaser C900 Printer Logo
196 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
