I have a sony vaio pcg-fv25 and need to replace the cpu fan (has 2 fans), I need a manual to show this or instructions, can you help me out please? Cynthia
Overheating
When the CPU overheats then it will shut down (i.e. thermal
overload) and won't boot up again until it has cooled down. If this is the
problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged
with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure
the vents are clear and dust free. Use a small brush and can of compressed air
to do this.
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail. A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust. Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
my laptop is sony PCG-7173L. No thing display on screen and i even cant shutdown and there is no power led on power button and no sound of fan too....i cant go to advance boot option also..Please can any body help me...
This over heating issue is a common issue for this model of VAIO Computer. You will get a free service or replacement of parts(Battery) from the Sony Service Center. For more information please follow the link below.
VAIO Battery Replacement program
Hope this will help you. All the best.
Battery Replacement
that's the actual fan, brushes may need some fresh oil (like wd40), means opening the lappy back up and removing the fan and dropping some oil inside the fan bearing area (where the fan and hub connect)
this should stop the sounds and help the fan move freely.
though this is also a sign that the fan is unhealthy and will eventually need replaced.
hope this helps.
Hello Chris....i highly recommend you dont "pry" on anything and it have it serviced by a qualified tech. The vaio incorporates the heatsink and fan as a unit, It's a 2 wire fan that is temp. controled from 5v and up. You can take a vacuum and place at the ventilation opening and remove some of the dirt & dust that has accumulated inside, this will help. The cost is around 100 buxs for a new fan & sink...Sony part # 1-763-483-12. Attached is a pic of the unit..; Also note: a depleted battery will effect fan operation as well. Hope this helps and will fixya up....
My pcg-k33 was very noisy (fan) so I vacuumed the fan opening with a powerful shop vac. This helped alot. I think that the CPU temperature triggers the fan so keeping the cooling system clean is important. As well, there are openings on the bottom for air so it is important to keep the unit on a surface that doesn't impede airflow (on your lap is a bad idea)
